Xbox One S Adds Ultra HD Blu-Ray with HDR - Page 104 - AVS Forum | Home Theater Discussions And Reviews
 1284Likes
post #3091 of 3162 Old 04-21-2017, 01:09 PM
Ozymandis's Avatar
Quoted: 160 Post(s)
Liked: 169
Angry
Originally Posted by michaeltscott View Post
The initial version of the app with its current UI was capable of streaming 4K HDR video (as can be seen in photos in this post); that version was apparently some kind of beta test, since only a subset of people got it. When it went into wide distribution the capability was removed. Though you can see the UHD badge on any items that you've put in your Watchlist or which you've watched recently (in the Watch Next row of Home) you will never receive UHD video when you play them. You also cannot browse them; there are no UHD rows in the UI.
I have no idea why they removed the capability; maybe it will come back some day.
It's bizarre, I had the version of the app which supported 4K back in December, and 4K was working without issue. Here we are, 5 months later, and there's no 4K, with an "updated" version of the app removing the higher resolution support. Not cool on Amazon's part to have such a long delay to reintroduce this feature.
EliFTW likes this.
Ozymandis is offline
post #3092 of 3162 Old 04-26-2017, 02:45 PM
Quoted: 291 Post(s)
Liked: 103
I have one more question, I can no longer see uhd content on amazon. It is only hd 1080p hdr. Any idea any one?
meduzadg is online now
post #3093 of 3162 Old 04-26-2017, 03:22 PM
mboojigga's Avatar
Quoted: 647 Post(s)
Liked: 882
It was never available except when they accidentally put the beta UHD Amazon app up. Amazon still hasn't officially released the app
The 5.0 is here
mboojigga is offline
post #3094 of 3162 Old 04-26-2017, 03:50 PM
michaeltscott's Avatar
Quoted: 2844 Post(s)
Liked: 1516
You mean that you no longer see the UHD "badges" on the UHD things you have on your Watchlist?
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #3095 of 3162 Old 04-26-2017, 05:03 PM
Quoted: 291 Post(s)
Liked: 103
Goliath for example has a uhd banner. But when I play it I can only get hd 1080p with hdr. The built-in app on my Samsung provides uhd hdr. Is it the Xbox or the vizio p series I just bought?
post #3096 of 3162 Old 04-26-2017, 07:16 PM
Liked: 1516
As we've told you a few times, the current Amazon Video app on Xbone S does not support UHD or HDR. It will display the badges if you have any of those versions of titles in your Watchlist on in the Watch Next row of Home, but when you play them it will not play the UHD version. The badge just indicates that UHD video exists for the title, not that the app on your device can play it. The badges appear in the UI for my first-gen Fire TV Stick, definitely not a 4K-capable device.
AFAICT, only Netflix, Hulu and the BD player app are capable of 4K video on the Xbox One S at this time. (I think that currently only Xbone S and PS4 Pro have 4K Hulu).
post #3097 of 3162 Old 04-27-2017, 04:53 PM
Quoted: 291 Post(s)
Liked: 103
Got it. Thank you.
post #3098 of 3162 Old 04-28-2017, 01:39 PM
PeterTHX's Avatar
Quoted: 477 Post(s)
Liked: 341
Don't forget Vudu.
My opinions do not reflect the policies of my company
PeterTHX is offline
post #3099 of 3162 Old 04-28-2017, 03:47 PM
Liked: 1516
Originally Posted by PeterTHX View Post
Don't forget Vudu.
You are correct, sir! I'd forgotten that version was released. So four things--Netflix, Hulu, VUDU and the BD player app.
post #3100 of 3162 Old 04-30-2017, 07:16 AM
BigCoolJesus's Avatar
Quoted: 1674 Post(s)
Liked: 1386
For some reason I cannot change my Bit Depth under the Xbox Display Settings...
I have an LG OLED C6 with Ultra HDMI enabled and when using Auto-Detect on the Xbox it says my TV supports everything except 50Hz, including 24Hz and 60Hz @ 10 bits. But when I go to Bit Depth it will only display 24/8 bit as an option. The only way I can select 30/10 bit is if I use manual settings but then I cannot use 4k resolution for some reason (it says 4k is only available if I use Auto-Detect).
Anyone else run into this problem?
BigCoolJesus is offline
post #3101 of 3162 Old 04-30-2017, 08:46 AM
steven_j05's Avatar
Quoted: 182 Post(s)
Liked: 85
Do you have deep color mode on lg turned on for the hdmi port your using
steven_j05 is offline
post #3102 of 3162 Old 04-30-2017, 09:18 AM
Liked: 1386
Yup.
Like I said, if I go to 4k Details the Xbox reports my display is compatible with every single setting including 10bit color. Not sure why it won't let me select 10 bit then...
post #3103 of 3162 Old 04-30-2017, 10:16 AM
tcat's Avatar
Quoted: 227 Post(s)
Liked: 104
I'm watching a Vudu movie which is hdr. Xbox says hdr, but my ef9500 doesn't seem to be in hdr mode (no pop-up and I can change settings). Am I missing something?
Sent from my Nexus 6P using Tapatalk
tcat is offline
post #3104 of 3162 Old 04-30-2017, 03:26 PM
Liked: 1386
Fixed my 8 vs. 10 bit issue
post #3105 of 3162 Old 04-30-2017, 03:35 PM
steven_j05's Avatar
Quoted: 182 Post(s)
Liked: 85
How
post #3106 of 3162 Old 04-30-2017, 04:19 PM
Liked: 1386
How
I had been using HDMI Out 2 on my Anthem receiver, which is HDCP 2.2/HDMI 2.0a compliant but lacks ARC capability. So just for the heck of it, I switched to HDMI Out 1 on the receiver and when I started my Xbox back up, the ability to select Bit Depth was available.
The little things make a big difference sometimes.
post #3107 of 3162 Old 04-30-2017, 04:28 PM
steven_j05's Avatar
Quoted: 182 Post(s)
Liked: 85
Yea it's crazy all this 4k stuff is so picky.
post #3108 of 3162 Old 04-30-2017, 04:48 PM
Liked: 1386
True. But I have yet to have a single HDCP handshake issue so in my mind 4k is going 10000x smoother then when I had the Xbox 360 HD-DVD player back in 2008 lol
post #3109 of 3162 Old 05-07-2017, 03:38 PM
Nickff's Avatar
Quoted: 350 Post(s)
Liked: 221
Which HDMI cables are you guys using to achieve full 4k/10 bit/60hz (the whole enchilada)? I don't need a long run...10ft tops.
The first set of 18gbps cables I tried (https://www.monoprice.com/product?p_id=13590) didn't work.
Nickff is offline
post #3110 of 3162 Old 05-07-2017, 04:03 PM
UHD Addict
aaronwt's Avatar
Quoted: 6420 Post(s)
Liked: 3966
The first set of 18gbps cables didn't work.
I use Monoprice premium certified cables. I paid around $4 for the ten foot ones on sale.
Sent from my Galaxy S6 using Tapatalk
MALICIOUS ONE likes this.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #3111 of 3162 Old 05-07-2017, 04:34 PM
mboojigga's Avatar
Quoted: 647 Post(s)
Liked: 882
High speed Amazon cables which were a pair for $5. I use with a 2015 65" Vizio M 4k, 980Ti PC, HDMI Bi-Directional Switch and Xbox One S
The 5.0 is here
post #3112 of 3162 Old 05-07-2017, 05:21 PM
sjchmura's Avatar
Quoted: 1530 Post(s)
Liked: 603
My old non certified 4 and 6' monoprice are working fine also. Must be since they are short
DocACE911 on Steam, XBOX, PS4
"Kill Cancer or Die"
Custom Z9 Game Settings For SDR and HDR
Sony 75" Z9, Denon X4200, Definitive Technologies BP7002 + 9.1 ATMOS, PSV 18" sub
Loving Wife and 4 year old Son who tolerate this expense!
sjchmura is offline
post #3113 of 3162 Old 05-07-2017, 05:58 PM
Liked: 1516
I'm using old non-certified cables which are all working fine; most are 3- and 6-foot, I think that there's one 10. Of course I do not have an HDR capable television, so 4K@60Hz SDR is the most I've asked of them.
post #3114 of 3162 Old 05-08-2017, 09:24 AM
DaverJ's Avatar
Quoted: 1331 Post(s)
Liked: 3732
HDR+4K+60fps pushes the 18GB/s bandwidth to it's limit.
If you can, 6" seems to be the sweet spot for the length HDMI cables were designed for. Many have luck with 10", but that's pushing it... aim for 6" if you can. Also, going direct from the device (game console) to the TV is recommended.
I've used certified Monoprice and this Zeskit cable with good results.
Good luck!
DaverJ is online now
post #3115 of 3162 Old 05-08-2017, 09:37 AM
steven_j05's Avatar
Quoted: 182 Post(s)
Liked: 85
Any cable premium certified will work. Other than that you'll have to test. I use hdmi cables from DIRECTV all 6ft and no problems. Swapped all my hdmi cables with them.
post #3116 of 3162 Old 05-08-2017, 10:40 AM
UHD Addict
aaronwt's Avatar
Liked: 3966
Good luck!
One of my S boxes uses a 10' cable, an HDMI switch, and then a 3' cable. All HDMI cables in my UHD setup are the Monoprice Premium Certified ones.
steven_j05 likes this.
post #3117 of 3162 Old 05-08-2017, 03:33 PM
Nickff's Avatar
Quoted: 350 Post(s)
Liked: 221
Swapped out the Monoprice Ultra-Slim Active 18Gbps cables for some cheap AmazonBasics 18Gbps cables and all is well...the One S shows all 4K/HDR possibilities as "checked". A 3-ft cable to the AVR and a 10-ft cable to the display.
Thanks for all the help and suggestions!
Sony XBR-65A1E | Denon X6300H | Klipsch RF-7ii (x2), RC-64ii, RB-51ii (x4) | SVS PB12-Plus | Xbox One S | WDTV Live | Sony BDP-S6200 | Harmony 670
Nickff is offline
post #3118 of 3162 Old 05-14-2017, 10:20 PM
MelloFellow13's Avatar
Quoted: 132 Post(s)
Liked: 178
I'm sad to say it but I'm really dissatisfied with the UHD playback on the X1S. I thought that the Dolby Atmos update would finally give me all I needed in a player but I have had lots of issues with stuttering playback and poor color range and motion issues... the TV is not at fault since I tested other players on it and it's only the Xbox which has these problems. Anyone else feeling the same way?
LG 65E6P
Pioneer 5020FD
MelloFellow13 is offline
post #3119 of 3162 Old 05-15-2017, 04:15 AM
IntenseImage's Avatar
Quoted: 67 Post(s)
Liked: 44
Nope, mine has been solid
Sent from my SM-G955U using Tapatalk
IntenseImage is offline
post #3120 of 3162 Old 05-15-2017, 07:27 AM
tcat's Avatar
Quoted: 227 Post(s)
Liked: 104
It has Atmos playback? Is the update out?
jeperer likes this.
tcat is offline
Reply Xbox Area
