4k upscaling comparisons? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By onlysublime
post #1 of 22 Old 09-19-2016, 12:43 PM - Thread Starter
Trixxstrr's Avatar
Has anyone done any comparisons of the Xbox One S doing upscaling to 4k vs letting your TV do the upscaling?
Trixxstrr is offline
post #2 of 22 Old 09-20-2016, 04:38 PM
Threefiddie's Avatar
Quoted: 89 Post(s)
Liked: 35
the xbox doesn't upscale games to 4k(only console that will is ps4 pro with the updated gpu). xbox only upscales to 1080p if the game isn't native 1080p just like the original xbox one. then your tv is doing the rest to upscale to 4k. 4k bluray, netflix, etc are only thing that are actually 4k.
Threefiddie is offline
post #3 of 22 Old 09-20-2016, 04:51 PM
Symtex's Avatar
Quoted: 105 Post(s)
Liked: 88
Xbox One S upscale to 4K.
Symtex is offline
post #4 of 22 Old 09-20-2016, 05:03 PM
Quoted: 89 Post(s)
Liked: 35
no. the xbox one s does not upscale games to 4k.
post #5 of 22 Old 09-20-2016, 05:04 PM
Symtex's Avatar
Quoted: 105 Post(s)
Liked: 88
It sure does. My tv is displaying at 3180x2160 @ 60hz on the Xbox One S. It was only 1080p on Original Xbox.
Symtex is offline
post #6 of 22 Old 09-20-2016, 05:05 PM
Quoted: 89 Post(s)
Liked: 35
lol no that's just what it's displaying at. the game is still 1080p and looks virtually no different than an original xbox one running same game on the same tv. there is nothing magical going on with that underpowered old gpu
post #7 of 22 Old 09-20-2016, 05:07 PM
Symtex's Avatar
Quoted: 105 Post(s)
Liked: 88
lol no. the game is still 1080p
Dude. The Xbox One S is upscaling the video signal to 4K. That's what game upscaling is. The source signal is being altered by Xbox One S to display in 4K. The same way X360 was doing it with 720p games when your output was set to 1080p.
Symtex is offline
post #8 of 22 Old 09-20-2016, 05:08 PM
Quoted: 89 Post(s)
Liked: 35
you don't get it. it's ok. again there is nothing magical happening with that ancient gpu in the xbox to make the game look any better. the game itself is still 1080.
post #9 of 22 Old 09-20-2016, 05:09 PM
emmons's Avatar
Quoted: 47 Post(s)
Liked: 24
xbox 1 s does upscale all games to 4k. as for what resolution your tv shows for info, if your feeding it a 1080p signal it will say 1080p. if you feed it a 4k signal this what it will say. you have no idea.
emmons is offline
post #10 of 22 Old 09-20-2016, 05:09 PM
Symtex's Avatar
Quoted: 105 Post(s)
Liked: 88
You don't get it
http://support.xbox.com/en-CA/xbox-o...-on-xbox-one-s
4K upscaling
When you set your console resolution to 4K UHD, everything on the console—Home, games, and apps—will display at 4K. 4K content is displayed in its native 4K resolution, and other content (like 1080p content) is upscaled to 4K.
To set your resolution and upscale everything to 4K, double-tap the Xbox button to open the guide, go to Settings > All settings, and then choose Display & sound > Video output. For TV resolution, select 4K UHD.
Symtex is offline
post #11 of 22 Old 09-20-2016, 05:10 PM
Quoted: 89 Post(s)
Liked: 35
jesus christ it's still a deadbeat sub 1080p xbox game. it looks NO different than an og xbox on the same tv being upscaled by the tv.
post #12 of 22 Old 09-20-2016, 05:12 PM
Symtex's Avatar
Quoted: 105 Post(s)
Liked: 88
You have to stop drinking the Sony koolaid. Whether you use checkerboard or any form of upscaling. It's still upscaling. There is no other way to describe it.
Symtex is offline
post #13 of 22 Old 09-20-2016, 05:13 PM
Quoted: 89 Post(s)
Liked: 35
sony koolaid? it's the fact of it is what it is... and no sony koolaid here. those idiots forgot to put in a 4k bluray player.
pc ultrawide master race here.
post #14 of 22 Old 09-20-2016, 05:21 PM
Symtex's Avatar
Quoted: 105 Post(s)
Liked: 88
Than you should know better. There isn't any magic here. There is no higher res texture. It's not remaster for 4k. It's a pure signal interpolation to 4k. Depending on your TV, it can look better and reduce input lag.
I think it looks great on my TV but i do have a higher end TV set.
Symtex is offline
post #15 of 22 Old 09-20-2016, 05:22 PM
Quoted: 89 Post(s)
Liked: 35
you finally get what I was saying...
post #16 of 22 Old 09-20-2016, 05:33 PM
emmons's Avatar
Quoted: 47 Post(s)
Liked: 24
but you also said not like ps4. guess what the ps4 upscales all games. there have been 3 games that dev have said will be 4k native but with how weak the ps4 is doubt it. but the pro upscales 99% of all games to 4k.just like the xbox 1 s. guess who's drinking the sony koolaid now
emmons is offline
post #17 of 22 Old 09-20-2016, 05:34 PM
Quoted: 89 Post(s)
Liked: 35
i meant like how the ps4 pro will... calm down.
post #18 of 22 Old 09-20-2016, 05:35 PM
onlysublime's Avatar
Quoted: 675 Post(s)
Liked: 1138
this is wrong. It does upscale games to 4K.
The Xbox One S also has a true 4K frame buffer so technically it can render true 4K games as well. This has been confirmed by Eurogamer via Albert Penello, a top-level Microsoft executive. However, the GPU is not fast enough to do detailed 4K games. But if someone wanted a native 4K Pac Man game, they could do it. Neither the OG Xbox One nor the PS4 have a 4K frame buffer so they couldn't render a true native 4K game even if the programmers wanted to. The Xbox One S and PS4 Pro are the only current gen consoles with a 4K frame buffer.
onlysublime is offline
post #19 of 22 Old 09-20-2016, 05:36 PM
Quoted: 89 Post(s)
Liked: 35
forget it. yall clearly miss the technical part I was talking about. yall have at it. you can't make poop look like better poop after the fact. it's still the original intended poop.
it is effectively doing NOTHING. it's still the same thing the original xbox is showing. put both xbox's on the same 4k tv and you'll see the same exact thing. except for hdr exception.
post #20 of 22 Old 09-20-2016, 05:38 PM
Quoted: 675 Post(s)
Liked: 1138
it's you that's confusing what "technical" means. "technical" and "realistically" are different. The Xbox One S can render a true native 4K game if the programmers write such a game. Can't imagine what the frame rate would be but it would at least run. The PS4 and OG Xbox One cannot run native 4K games under any circumstances.
The PS4 Pro can't realistically run 4K games either. But technically it can. Just like the Xbox One S.
aaronwt likes this.
post #21 of 22 Old 09-20-2016, 05:42 PM
Quoted: 675 Post(s)
Liked: 1138
back to the original question... it depends on whether the AMD scaler is doing a better job or the scaler in your TV. You really can't know until you try it. There's no universal answer.
In fact, on my Vizio P50-C1 TV, some movies and games look better via the Xbox/AMD scaler. And some look better via the TV scaler. I popped in an anime DVD and the Vizio did a horrific job of scaling it. Same DVD with the Xbox scaler looked better (not dramatically but still better). Same for games. Rainbow Six Siege looks better scaled through the Xbox than my Vizio. But I thought Unravel looked better scaling through the TV than via the Xbox.
post #22 of 22 Old Today, 10:26 AM
AVS Club Gold
aaronwt's Avatar
Quoted: 4397 Post(s)
Liked: 2629
I just have my XBOne S output 4K. It looks fine. Although I can't say I've compared it to what my Sony scaler. But I would need to use some test patterns for that. So even if my TV is better, it's probably a minor increase. I'll continue to my my XBOne S upscale games and everything else it can to 2160P. And if I get a PS4 Pro, I will also have it upscale everything to 2160P.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
Reply Xbox Area
