Just picked up this controller today for my PC. This thing is incredibly awesome. Any ways. I am using the wireless usb adapter for it as well if it makes any difference. My question is when using the Xbox app to customize profiles etc. Does the controller physically have to be hooked up using the cable when saving new profiles? Or can you do it wireless?
The elite doesn't have the Bluetooth radio like the newer One S controllers (and the design lab controllers). So you do need the wireless adapter if you want a wireless controller.
But in any case, the wireless adapter is much more reliable than Bluetooth and you can have multiple controllers at the same time if you want co-op gaming.
Ive gone through three of these so far. Either I'm way to hard on my joysticks, or they should stop using plastic.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
