So, post your 360 screenshots and tv u r using - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 8018 Old 03-22-2006, 11:37 PM
wrxh8r's Avatar
Here is my 26" bravia v series with oblivion.Havnt quite got the settings where i want them.To busy playing
wrxh8r is offline
post #542 of 8018 Old 03-23-2006, 01:29 AM
Chris Rein's Avatar
Originally Posted by Chodite View Post
Here ya go (Mitsubishi 55" CRT) -
Holy crap! Your overscan is HORRID! You can't even see the visor, well, except for the tips at the bottom. Are you sure that A) Your 360 is set to Widescreen and HD. or B) that you're not zooming in on that? That's shocking!
Chris Rein is offline
post #543 of 8018 Old 03-23-2006, 06:11 AM
YoungC55's Avatar
Liked: 24
hey now. His TV is great. haha
Eh.
YoungC55 is offline
post #544 of 8018 Old 03-23-2006, 06:47 AM
MastaMind's Avatar
Originally Posted by kicks View Post
How can you have a dreamcast and not a PS2. Dreamcast died years ago and for good reason, it was garbage, no games to play, and that is what consoles are all about. So I know that Cast is just sitting there.
Spoken like a true gamer. The dreamcast had some awesome and original games ie. Cannon Spike.
MastaMind is offline
post #545 of 8018 Old 03-23-2006, 07:35 AM - Thread Starter
teckademic's Avatar
Quoted: 106 Post(s)
Liked: 104
can we get some GRAW pics because I keep going back and forth on how bright this game is supposed to be. Sometimes I think its too bright and sometimes too dark, so can I see some pics so that I can compare?
teckademic is offline
post #546 of 8018 Old 03-23-2006, 04:34 PM
anam8tr's Avatar
a little blurry.
anam8tr is offline
post #547 of 8018 Old 03-23-2006, 09:09 PM
Chodite's Avatar
Quoted: 43 Post(s)
Liked: 31
LOL
360 is definitely set to widescreen and HD (1080i)
Overscan is definitely an issue though. How do I go about fixing that?
Chodite is offline
post #548 of 8018 Old 03-23-2006, 09:21 PM
jdiehl's Avatar
LOL
The service menu, it's kinda tricky though.
I had a 65" Mits Platinum Plus back in the day (01-04) and it had a ton of overscan from the factory. I read up on accessing the service menu at another forum and was able to get it down to around 2-4% around all 4 sides.
Jon
jdiehl is offline
post #549 of 8018 Old 03-24-2006, 01:52 AM
Esosresik's Avatar
LOL
Are you absolutely sure nobody hit (I think it is called "format" on Mits TV's remote) the zoom feature? I would double check that first. It should be input specific so it may only be activated on the 360. That is an awful lot of overscan, I find it hard to beleive the factory would let a TV leave with that much overscan.
Esosresik is offline
post #550 of 8018 Old 03-24-2006, 02:52 AM
Statix's Avatar
I have a mits 62725 with a TON of overscan, 1280*720 native res, I have to run my pc at
1176*664 to compensate for overscan.
I don't think you can correct overscan on the dlps, can you?
Statix is offline
post #551 of 8018 Old 03-24-2006, 05:48 AM
ogbuehi's Avatar
Anybody know how to post hi res pics? My photos come out either too dark with no flash or a bright white spot in the middle with the flash on. I think it's becuase the photo's size has to be so low to upload.
ogbuehi is offline
post #552 of 8018 Old 03-24-2006, 06:43 AM
Chodite's Avatar
Quoted: 43 Post(s)
Liked: 31
Zoom is not enabled. And I actually checked the overscan % with a JPG someone on here posted and it was in the 'acceptable' level. But obviously it's an issue. It's a CRT btw, not a DLP as someone commented above.
Chodite is offline
post #553 of 8018 Old 03-24-2006, 06:48 AM
YoungC55's Avatar
Liked: 24
Ouch, well as you know Chodite. i have a Mitsu 55413.. scary..
I had mine calibrated, but not by imagescience (ISF).
I hope i dont have overscan.. i don't notice anything bad.
YoungC55 is offline
post #554 of 8018 Old 03-24-2006, 08:02 AM
Chodite's Avatar
Quoted: 43 Post(s)
Liked: 31
Some games show worse overscan than others for me. Obviously GRAW is one. 2K sports games are another. The "Press Start" at the top of the NBA 2K6 main screen is usually cut off. Other than that, I never notice it.
Chodite is offline
post #555 of 8018 Old 03-24-2006, 08:06 AM
jdiehl's Avatar
-pause the game
-no flash
-long exposure (ie. 1/2 second or longer, play around with it)
-use a tripod (or set the camera on a shelf)
-use the timer for the shutter so pressing it won't move the camera and cause blur
Jon
jdiehl is offline
post #556 of 8018 Old 03-24-2006, 08:50 AM
spyfy's Avatar
Chodite, you the same guy from MaddenMania? Anyways, fixing overscan is pretty simple. If you'll search here or over at *************** you'll find out how to get in the secret menu to fix it. If the press start on NBA 2K6 is partially cutoff then you're dealing with quite a bit of overscan.
spyfy is offline
post #557 of 8018 Old 03-24-2006, 10:48 AM
ogbuehi's Avatar
Thanks Jdhiel. I'll try that.
ogbuehi is offline
post #558 of 8018 Old 03-24-2006, 03:57 PM
danieloneil01's Avatar
Hey Chris Rein I have a 55" Mits also and never realized that I couldn't see that blue line that went around the whole image in GRAW until I played it on my PC monitor... My picture looks just like his.. Of course my HDTV is over 5 yrs old so maybe it's either that or Mits has a problem with it.... Model WS-88519
His tv is probably like mine and Zoom isn't a feature for HD...
D.I.N.K
Double
Income
No
Kids
danieloneil01 is offline
post #559 of 8018 Old 03-25-2006, 11:17 AM
maingon's Avatar
my HD tv does that too with ghost recon, never bugged me though, I think i perfecr it with out the blue visor, some games dont seem to have any problems with over scan or its not noticeable.
maingon is offline
post #560 of 8018 Old 03-26-2006, 04:56 PM
Sasquatch321's Avatar
Sony 42A10 on standard video settings.
Gamertag: Elder Sasquatch
Sasquatch321 is offline
post #561 of 8018 Old 03-27-2006, 02:26 AM
wrxh8r's Avatar
When i first started it up with training i thought that, but once you begin playing the majority of the time is fine.The extreme times with poor vis just show off the realism really.
But heres three lighting angles to show off how angle to the sun effects it.
bravia v series
wrxh8r is offline
post #562 of 8018 Old 03-27-2006, 08:43 AM
Shok's Avatar
Does anybody have the best settings for the Sony 42A10 when hooked up to an X360 ?
Shok is offline
post #563 of 8018 Old 03-31-2006, 12:56 PM
mello 1's Avatar
Originally Posted by mello 1 View Post
I made a new version. I moved the Pure AV from the bottom left to the top middle shelf. That allowed me to squeeze the columns tighter. I'm a little worried about overheating because of how much space some components are at. For example, The directv receiver, the Denon, & the Pure AV have approximately 1/2" of space on each side. I got rid of the middle shelf for easy access to the back of the denon plus more ventilation space. The other shelves have approximately 3" of space above for all the components except for the Denon. I don't plan on putting glass doors in front.
Behind each component is a cutout for cabling & ventilation. The only difference is that I made separate openings behind the Denon to keep track of the wires. I even put smaller holes for each speaker wire.
I also made a variation of the setup where the top board has about the same amount of space as on the sides of the TV. The board on setup_2 is flush with the top of the TV.
Do you guys think that the PureAV is overkill? That one is priced at $750. The only reason I chose it over the cheaper ones is that it has Phase 6 PureFilter Circuitry which I have no clue what that is compared to the Phase 4 & lower versions. Little help here.
I added a 3D version that I made with Bryce & photoshop. Has anyone seen any reviews for the Infinity Cascade Series Seven speakers?
mello 1 is offline
post #564 of 8018 Old 04-02-2006, 11:05 AM
DFul4d's Avatar
I just got some new speakers, Infinity Beta 50s. My set is a KDL-V40XBR1 (Sorry my camera sucks)
DFul4d is offline
post #565 of 8018 Old 04-03-2006, 05:36 AM
govschmo's Avatar
Originally Posted by DaGamePimp View Post
Here is my current living room HT set-up , constant height 10' diagonal Da-Lite HiPower Model C with Mitsubishi HC3000u DLP Projector . I left the light on for the pic in order to see the set-up , I pretty much have total light control in the room even though it has white side walls and ceiling .
---------- Jason
Looks good.
What changes to your setup did you need to do when changing from a 4805 to your new pj as far as location?
Did you change the location of the mount, or is the throw similar?
govschmo is offline
post #566 of 8018 Old 04-03-2006, 06:01 AM
MisterNJ's Avatar
Phillips 50" Plasma with Ambient Light---I suck at taking pictures.
I have a quick question--should I have my 360 run in 720p or 1080i?
Xbox 360 Gamertag: MisterxboxNJ
MisterNJ is offline
post #567 of 8018 Old 04-03-2006, 08:31 AM
chris5977's Avatar
Just got a Sceptre 42" 1080p LCD. It's replacing a 1st gen 50" Samsung. The Sammy was a good TV, but I am amazed at how much better the black levels and color are on the lcd. Note how the light pouring in from the window has no effect on picture quality. This a great gaming TV.
This is PBS for comparison's sake.
PSN Gamertag: chris5977
In War: Resolution
In Defeat: Defiance
In Victory: Magnanimity
In Peace: Good Will
Winston Spencer Churchill
chris5977 is offline
post #568 of 8018 Old 04-03-2006, 10:50 AM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Originally Posted by govschmo View Post
Looks good.
Thanks .
The HC3000 has a different throw than the 4805 for both offset and distance . I had to move the mount back and the screen sits lower . I did not have this size screen with the 4805 however , I was only using an 84" 16:9 screen with the 4805 .
--- The upgrade to the HC3000 was substantial for HD gaming and other HiDef sources but for DVD viewing there really are very limited benefits (even though my DVD source is a fully tweaked HTPC) . As a matter of fact I now notice all the flaws in DVD's much more often (vs. viewing on the 4805) .
--- The Xbox 360 on a 720p DLP is just fantastic and the immersion of a screen this size is astounding (even though it does sacrifice some image quality vs. a smaller screen) .
--- If you are considering an upgrade to 720p then take a look at the IN76 , I think the offset is similar to that of the 4805 (not sure about the throw however) .
------------- Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #569 of 8018 Old 04-03-2006, 02:14 PM
Trendy8's Avatar
My set was the same way as well. Toshiba 57hx83 CRT Rear Projection. Only bad on HD material. I actually had a service tech come out and fix the overscan just last weekend since it's still on warranty. All he did was go into the service menu and adjust the height and width.
Trendy8 is offline
post #570 of 8018 Old 04-04-2006, 07:40 AM
Stryker412's Avatar
Liked: 26
Some of you guys have some jaw dropping setups. Hopefully someday I will too, but for now here's my current setup. (images load slow, sorry)
Stryker412 is offline
Reply Xbox Area
