Problem with play and charge kit - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-01-2005, 07:21 PM - Thread Starter
alougher's Avatar
Quoted: 18 Post(s)
Followed instructions -- connected play and charge cable to USB port on back on 360. Connected to controller, red light stays on and eventually turns green (meaning charged). 30 mins into gameplay get the message "Controller disconnected". Then controller goes dead.
alougher is offline
post #2 of 14 Old 12-01-2005, 08:26 PM
xxThe Deanxx's Avatar
Have you tried regular batteries to isolate the controller from the kit?
Is there some interference in your home?
My New Xbox Live Gamertag: General Hazard
xxThe Deanxx is offline
post #3 of 14 Old 12-01-2005, 11:37 PM
Drew224's Avatar
This is totally off topic, but I remember reading that you could check your remaining battery in the dash and I haven't figured out how. Does anyone know how?
Drew224 is offline
post #4 of 14 Old 12-01-2005, 11:46 PM
Jasman's Avatar
There's a small battery indicator at the top of your half-screen dashboard.. from memory.. hit the guide button and look at one of the corners, maybe near the time.
Jasman
Jasman is offline
post #5 of 14 Old 12-02-2005, 12:26 AM
Drew224's Avatar
Jasman
Wow. I have totally been over looking that.
Drew224 is offline
post #6 of 14 Old 12-02-2005, 07:47 AM
wasko8's Avatar
Thanks Jasman, was also wondering where the heck that was. :D
wasko8 is offline
post #7 of 14 Old 12-02-2005, 08:41 AM
Lenster's Avatar
You connect to the usb port for the first controller in the front of the xbox 360. The play and charge can work without the 360 being on. However, you have to have the system on at first.
After you see the charging light go on you can turn off the system.
Lenster is offline
post #8 of 14 Old 12-08-2005, 06:48 AM
pace1313's Avatar
How long does it typically take for the controller to get fully charged (i.e. for the light to turn green)?
I tried charging my controller last night for the first time and, while the battery indicator on the dashboard displayed gradually more bars, the light on the charger stayed red for at least two hours, at which point I gave up and went to bed.
My concern is that I neglected to charge the controller before using it the first time, and I screwed something up.
pace1313 is offline
post #9 of 14 Old 12-08-2005, 07:09 AM
taintedzodiac's Avatar
I've heard six hours for a full charge when not in use. I've definitely seen it take over 3-4 hours, although I wasn't watching to see when it finally finished.
Join the Mobile Infantry and save the Galaxy. Service guarantees citizenship. Would you like to know more?
I'm doing my part. Are you?
taintedzodiac is offline
post #10 of 14 Old 12-08-2005, 08:42 AM
jasonstiller's Avatar
i was told that the 1st charge takes 6 hrs, after that its 4-5 hrs. Plug the usb into the front port not the rear one.
jasonstiller is offline
post #11 of 14 Old 12-08-2005, 10:31 AM
dbburns's Avatar
Quoted: 51 Post(s)
Liked: 71
It did take me four to five hours to charge my two controllers the first time. I haven't had to recharge them yet, so I don't know if recharge time is shorter after that initial charge.
Xbox/PS/WiiU gamertag: GoNats
Apple Game Center: iGoNats
dbburns is online now
post #12 of 14 Old 12-08-2005, 04:51 PM
mjwhitay's Avatar
Hey just a hint. If you have an ipod or something witha usb-wall charger, you can plug the plug-n-play charge kit directly into that. Works like a charm. I never have to unplug it since I have a car charger for the ipod and it charges as I use it for my in game music.
The 360 rock, BTW.
mjwhitay is offline
post #13 of 14 Old 12-09-2005, 07:30 PM - Thread Starter
alougher's Avatar
Quoted: 18 Post(s)
Thanks for the last tip, I have a USB wall charger that came with my Blackberry so I will try that. The only other thing I noticed was that I charged the battery pack, light went green un all, but a day or so later with minimal playing the controller died. I guess I've a dodgy battery pack after all.
alougher is offline
post #14 of 14 Old 12-09-2005, 08:15 PM
Posi's Avatar
Just a correction that it will work using the rear USB as well. Just in case for some reason someone really wanted to use the rear USB.
Posi is offline
Closed Thread Xbox Area
