Can Xbox 360 output 480i through component cables? - AVS Forum | Home Theater Discussions And Reviews
Old 04-04-2006, 04:15 PM - Thread Starter
Pasoa2000's Avatar
Quoted: 16 Post(s)
Ok,
So I've my 360 since Sunday.
It goes Xbox360 -> Onkyo receiver -> SDTV
Those are component cables connecting
Question is, I get nothing but garbled picture. I had my original Xbox hooked up just like that and it worked fine.
So my question is, can the 360 output 480i through the component cables? I'd like to use the component cables simply for the better color saturation etc.
And YES, the component cable is set to "TV", not "HDTV"
Pasoa2000 is offline
Old 04-04-2006, 05:39 PM
rdank's Avatar
If you skip your receiver and plug it into the TV, wouldn't that give you your answer?
rdank is offline
Old 04-04-2006, 05:43 PM
Mathesar's Avatar
Quoted: 18 Post(s)
Ive hooked up my 360 to a Sony 27" standard def TV before and it worked fine (Component cables).
Mathesar is offline
Old 04-04-2006, 05:47 PM - Thread Starter
Pasoa2000's Avatar
Quoted: 16 Post(s)
Yeah but it's a PITA because the TV is so friggin heavy and it's in a cabinet.
Old 04-04-2006, 05:57 PM
Morkeleb's Avatar
Does the cable pass a signal through the components when switched to "TV" or just the composite cables? Keep in mind that I have not checked on mine so I'm not sure and I'm also assuming your talking about the switch on the 360's video cables.
Disclaimer:
The words above are based on loose facts mixed with my opinion, the latter of which is subject to change.
Gamertag Morkaleb
PSN Archathema
Morkeleb is offline
Old 04-04-2006, 06:15 PM - Thread Starter
Pasoa2000's Avatar
Quoted: 16 Post(s)
OK,
I stopped being a wuss and moved the cabinet.
And low and behold, when plugged directly into the TV's component input (bypassing the receiver), it displays just fine.
On a side note, the picture is DRASTICALLY better.
So what's going on here?
My original Xbox passed through the receiver just fine.....
Pasoa2000's Avatar
Quoted: 16 Post(s)
Yes it does, although there is 'something' going on between the receiver, the xbox and the tv.
Old 04-04-2006, 06:24 PM - Thread Starter
Pasoa2000's Avatar
Quoted: 16 Post(s)
OK I have no idea what's going on....
Just unhooked the cables from the TV, plugged them back into the receiver, plugged the components from the receiver back into the TV to make sure I'm not imagining things....
And NOW IT FRIGGIN WORKS.
Old 04-04-2006, 06:58 PM - Thread Starter
Pasoa2000's Avatar
Quoted: 16 Post(s)
OK,
Found the problem.
ID 10T error.
Basically, one the monster component cables from the receiver going to the TV had come ever so slightly loose.
I guess when in doubt, check the cables...
Old 04-04-2006, 08:57 PM
rdank's Avatar
D'OH!
At least you got it working. :)
rdank is offline
Old 04-04-2006, 09:35 PM
JMMHouston's Avatar
Out of curiosity, what model Onkyo receiver? I have a 797 with a 360 hooked between it and the tv.
JMMHouston is offline
