1080P problem/compatability thread! - AVS | Home Theater Discussions And Reviews
post #1 of 654 Old 10-31-2006, 12:31 PM - Thread Starter
Super Moderator
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 27
Please post all 1080P questions/compatability issues here.
If you are having problems... please post them here! We're starting to see way too many 1080P threads popping up.
All new 1080P "problem" threads created after this one will be deleted.
Kyser
"Good... Bad... I'm the guy with the gun."
Ash - Army of Darkness
Kysersose is offline
post #2 of 654 Old 10-31-2006, 12:38 PM
JBran24's Avatar
Well, I've already posted extensively today on this subject. However, I might as well jump in if we are going to have one thread going. I've got a Samsung LN S4695D 1080p LCD TV. So far, 1080p via VGA is not working. I get a "mode not supported" prompt on my TV and can't even see the 360's dashboard to make any adjustments. Component cables work fine with 1080p, but you don't get the benefit of upconverted DVDs via component. Samsung has advised me to test the VGA input with a PC. I'll do that when I get home tonight.
JBran24 is offline
post #3 of 654 Old 10-31-2006, 12:50 PM
timothias's Avatar
I've been reading that owners of Sony sets are not getting 1080p over component or VGA.
I have a 46XBR3, plan on getting 360 for GOW, and this 1080p business is starting to worry me.
Can anyone else confirm Microsoft's inability to output 1080p on a SONY set?
PSN and XBox Live gamertag: JonesJohnson
Format Neutrality = Best
timothias is offline
post #4 of 654 Old 10-31-2006, 12:54 PM
TV Casualty's Avatar
Are you KIDDING me? This is the first I've heard of a Sammy set having problems also. Anyone else?
If this becomes a problem with other sets, MS really needs to start working on a fix, sooner than later. This could turn into a pretty embarassing situation.
We do not train to be merciful here.
TV Casualty is offline
post #5 of 654 Old 10-31-2006, 12:55 PM - Thread Starter
Super Moderator
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 27
I wonder what the issue is with Sony sets? Maybe the problem isn't on MS's end... There could also be user setting issue's with various sets. Double-check everything!
Regardless, I'm sure it is just a matter of time before it gets fixed. This is the first day of the update after all...
post #6 of 654 Old 10-31-2006, 01:42 PM
mboojigga's Avatar
Quoted: 95 Post(s)
Liked: 477
Do any of the displays actually state that they do 1080P over VGA and/or component?
The 5.0 is here
mboojigga is online now
post #7 of 654 Old 10-31-2006, 01:56 PM
Krevnik's Avatar
The XBR2/3 does not support 1080p over component. They state that in the manual... but they have 1920x1080 as a supported resolution for VGA. 1920x1080 has been done via PC using the VGA port, so to me it looks like something slightly out of range with the 360... it does /display/ something, but it isn't the whole screen.
Krevnik is offline
post #8 of 654 Old 10-31-2006, 01:59 PM
saeorange's Avatar
To preface I am using a vga cable to achieve 1080p on my Samsung LN-S4695. 1080p seems to be working great for games and all the content on my 360's hard drive, unlike the gentleman above. The upscaled 720p trailers look great. Unfortunately, when I try to stream 1080p WMV's from my PC, the xbox automatically pillarboxes the feed and I get horizontal compression. It is definitely not the files, as they are 16:9 1080p and display properly on my computer monitor. For reference, I am using HD WMV found on Microsoft's website. Any ideas or fixes for this problem?
saeorange is offline
post #9 of 654 Old 10-31-2006, 02:26 PM
StefanGagne's Avatar
40" XBVR2 here. VGA doesn't work.
Given I already preordered the HD-DVD drive and some discs to go with it, this is disappointing. Fortunately I can just connect the thing by component (since 1080i is roughly the same as 1080p when viewing 24fps movies) but I won't get 1080 games and I won't get upscaled DVDs if I do that.
I'm hoping MS will issue a patch. This is a very high quality set and I am not returning it to the store just because the 360 isn't producing a standard VGA signal (since it's been confirmed a PC connects at that rez just fine).
StefanGagne is offline
post #10 of 654 Old 10-31-2006, 03:03 PM
getnate12345's Avatar
Actually most of the 1080p videos on the Microsoft WMV showcase site are not full 1080p, they are anamorphic. It means they are encoded at 1440x1080 and streched during playback to 1920x1080. The pillars you see could be a bug in the Xbox360 video player. Can you try with known true 1920x1080 WMV?
Nate
getnate12345 is offline
post #11 of 654 Old 10-31-2006, 03:09 PM
volley's Avatar
To recap all of mine...Sony VPL-VW50 Pearl projector.
1080i works fine on component.
Up to 1280x768 works fine on VGA although washed out.
1920x1280 on VGA only gives a 1024x768 screen and very dark.
1080p on component does not work.
Sony manual states that 1080p will not work on component.
Sony manual does state that it will take a 1920x1080 fV:60Hz.
This is tested and works from a PC.
Tried all of the input variables including Computer, Component, and RGB I believe it was. Only 'computer' outputs a display. I am using the 'Microsoft' branded VGA cable directly to the projector.
volley is offline
post #12 of 654 Old 10-31-2006, 03:11 PM
AVBill's Avatar
If you are bothered by Microsoft's lack of HDMI support (which I personally am), might I suggest you politely contact Microsoft's Xbox360 hardware support and politely let them know of this fact.
Microsoft Xbox360 Hardware Support
http://support.xbox.com/eform.aspx?...ts&locale=en-us
Microsoft is company that listens to its customers. The more of us that clamor for HDMI support, the sooner it will arrive. Please tell Microsoft politely that VGA and component 1080p support does not work for a large number of popular 1080p TVs. The Xbox 360 is the only mass-market device I can think of that outputs 1080p over component while lacking HDMI. Many people complained about the original Xbox's large controllers, and they came out with a smaller version. Microsoft thought about skipping Xbox compatibility with the Xbox 360, but when people complained they came up with a partial emulator solution. Microsoft does listen, just make sure to contact them so that they will hear you. I already contacted Microsoft support about this awhile ago.
Be clear on this, this is NOT Sony's fault (or JVC). Many 1080p TVs do not accept 1080p over component, and VGA support for computers is not usually the primary application. Microsoft needs to address this issue, not TV manufacturers.
My A2000 Settings for the S3 TiVo, PS3, Xbox 360, and Nintendo Wii.
My A2000 Lag Test & A2000 Lag Timing Estimations.
AVBill is offline
post #13 of 654 Old 10-31-2006, 03:18 PM - Thread Starter
Super Moderator
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 27
The impatience of people over a "slight" increase in resolution. You can expect that if there is a real problem on MS's part that it will be addressed in a patch. Did everyone really expect that this would work for every display in the world without any issues?
Luckily a lot of displays/projectors accept 1080P over Component, it seems that many Sony displays do not. Give it some time guys... it's not like you're missing out on everything entirely.
post #14 of 654 Old 10-31-2006, 03:32 PM
saeorange's Avatar
Nate
I'd love to. Any suggestions as to where I can find such a file?
post #15 of 654 Old 10-31-2006, 03:55 PM
At the bottom half of this page are several clips that claim 1920x1080 WMV-HD: http://www.hd-channel.com/535457979d...45797ab0ac9930 (german site)
post #16 of 654 Old 10-31-2006, 04:14 PM
mcallister's Avatar
Agree 100% give it some time
mcallister is online now
post #17 of 654 Old 10-31-2006, 04:32 PM
Unfortunately "time" is not something that all of us can afford - I'm currently still in my 30 day return window, but knowing how notorious Microsoft is for delaying updates/patches, I'd at least appreciate a word that it's being worked or that they are aware of the problem.
I didn't expect it to work with "every display in the world," but with one of the two or three most popular name brand's flagship line? Uh, yeah, I kind of figured that would be checked before they released this update.
Story has been posted on Kotaku, so hopefully that will get someone's attention.
post #18 of 654 Old 10-31-2006, 04:58 PM
liltalkm's Avatar
Quoted: 43 Post(s)
Liked: 71
Samsung LNS4695D 46" 1080p LCD
1080p via component -- WORKS!!!
1080p via VGA -- WORKS!!
Woo Hoo.
But I did learn that this set does not accept 720p via VGA.
I have my 360 in the family room connected at 720p via VGA to my 61" Samsung HLN model DLP.
I also have it connected to the 1080p Sammy LCD in the bedroom via component at 1080i. I liked it this way as the 360 remembers the settings for each connection type it was last connected to. So, I never had to adjust them. When it was connected VGA to the DLP, it remembered 720p. When I connected it to the LCD via component, it knew 1080i.
So, I pick up a second VGA cable for the LCD. Quickly grab the updated 360 and take it to the bedroom for 1080p. Component was set to 1080p and the set quickly synched. VGA on the other hand was tricky as it remembered its 720p setting from the VGA connection to the DLP in the family room. The LCD was saying "mode not supported". I could not see the dashboard.
So, I took the 360 back to the family room. Set the settings to the lowest setting via VGA and took it back to the bedroom. Once reconnected to the LCD at its lowest setting, I could then get in the dashboard. Updated to 1920 X 1080 and the LCD synched right up.
Glad it works!
But, for anyone that is using VGA on multiple displays now, make sure that before you move it, to use a resolution that is acceptable by both displays before re-connecting it.
It is a bit of a p.i.a., but it works non the less.
Looks great btw.
Later
Speakers: Martin Logan Montis, Stage X, Dual Depth I Subs, Vanquish in ceiling (surrounds) | Processor: Marantz AV7702 | Amp: Three Moon Simaudio 400m monoblocks,One Moon Simaudio 330a | Sources: DirecTV HR34, HTPC, Mac Mini, Oppo BDP-103, PS4, PS3, Xbox One, Wii U | Television: Panasonic 65VT50 | Remote: Logitech Harmony Ultimate
liltalkm is online now
post #19 of 654 Old 10-31-2006, 05:05 PM
Woo Hoo.
Glad it works!
Looks great btw.
Later
Cool. I'm tempted to exchange my XBR2 for a 4095D if we don't hear anything about this in the next week or two - how bad is motion blur and overscanning?
post #20 of 654 Old 10-31-2006, 05:09 PM
jeff_hanna's Avatar
My Samsung HL-S5087W DLP works in 1080p mode via the VGA connection. I'm sure it works on the component connection too, but I switched to VGA since Microsoft (via Major Nelson) is saying that DVD upscaling will only work over the VGA cable.
The only issue I have is that the image is pulled in about a 1/4" from all sides. I've not seen that happen on either the S-VHS or Component inputs on my TV. I've no idea about either of the HDMI inputs, as I don't have any HDMI devices at the moment. Hopefully there's some way I can adjust the picture to fill the frame.
jeff_hanna is offline
post #21 of 654 Old 10-31-2006, 05:37 PM
bigkev4123's Avatar
jeff, use the p.size button on the remote and you can adjust it to get rid off the borders
bigkev4123 is online now
post #22 of 654 Old 10-31-2006, 05:43 PM
liltalkm's Avatar
Quoted: 43 Post(s)
Liked: 71
Have not really played with it (too many trick or treaters), just made sure it worked.
Dashboard looks great though. Did not notice any overscan.
Later
post #23 of 654 Old 10-31-2006, 05:51 PM
jsheffield's Avatar
1080P over VGA on the Westinghouse LVM-37W1 works perfectly, though I did have to re-autosync.
jsheffield is offline
post #24 of 654 Old 10-31-2006, 06:02 PM
woohoo7676's Avatar
I currently have a Sony GDM-W900 monitor which I have connected to my 360 using the VGA cable. When I attempt to enable the 1920x1080 resolution mode, the screen goes black as if it were unable to support the resolution. I've double checked the monitor specifications and tested the resolution using my PC, and it should work.
Might this be related to the other Sony 1080p problems going on, and does anyone have any advice as to how I could go about solving this? Any help would be greatly appreciated
Tommy
woohoo7676 is offline
post #25 of 654 Old 10-31-2006, 06:09 PM
SAVholic's Avatar
I tried 1080p via component in my LVM-37W3 westy and the colors look wash out and it shows some color shading between blue & green especially in motion. will get VGA cables tomorrow.
"My English is not very good looking" - Celia Cruz
SAVholic is offline
post #26 of 654 Old 10-31-2006, 06:17 PM
mikecoscia's Avatar
Sharp Aquos 37D790U
Component: 1080p works fine
DVI: Have to use a VGA adapter, every rez works EXCEPT 1080p. Which is odd because a pc sending a 1080p analog signal works fine. Something is def up with the way MS is throwing out this signal.
mikecoscia is offline
post #27 of 654 Old 10-31-2006, 06:21 PM
XavierYZ's Avatar
1080p over component or VGA isn't working for the HP MD5880n, although component is apparently supported on the HDTV
My HT setup updated april 27/09
Click Here
XavierYZ is offline
post #28 of 654 Old 10-31-2006, 06:26 PM
jeff_hanna's Avatar
D'oh! I have been using my Harmony XBox360 remove for so long I forgot about the P.Size button on the Samsung remove. Thanks for reminding me!
post #29 of 654 Old 10-31-2006, 06:48 PM
CyberScott's Avatar
Quoted: 12 Post(s)
I own a Samsung HL-6168W. 1080p, 720p work fine over VGA for games and DVD's.
CyberScott is offline
post #30 of 654 Old 10-31-2006, 07:51 PM
JBran24's Avatar
Woo Hoo.
Glad it works!
Looks great btw.
Later
Hallelujah!!! This was my exact situation! I have a Westy LCD in the bedroom. I moved the 360 in there and tested the VGA. It worked; no problem. I set the resolution down from 1280 x 720 to 640 x 480. I moved the 360 back to my Samsung 1080p TV and the VGA worked. All I had to do was up the resolution back to 1920 x 1080 and .......Whoomp! There it is! Thanks for the tidbit. It was a P.I.A but I am just glad it works.
JBran24 is offline
Reply Xbox Area
