360 Universal Code? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-09-2006, 06:21 PM - Thread Starter
block's Avatar
Does anybody know if there is a universal remote code for the xbox 360 that I can program into my DIRECTV remote to control the DVD features? I couldn't find this discussed anywhere. Thanks.
block is offline
post #2 of 7 Old 12-09-2006, 06:44 PM
Jetrii's Avatar
http://www.xbox.com/en-US/support/sy...ntrolcodes.htm
EDIT: AH...Doesn't list directTV...
Never argue with an idiot. They drag you down to their level then defeat you with experience.
Jetrii is offline
post #3 of 7 Old 12-09-2006, 07:34 PM
spinksjinx's Avatar
In the HD-DVD add-on manual it says it is only for televisions/MCE/360 wont work with things like that but I guess its worth a shot, try the automatic way by holding down ok/tv at the same time and then wait for the numbers only to light up and then keep pressing channel up and down until it shuts off and then push TV button again.
spinksjinx is offline
post #4 of 7 Old 12-09-2006, 07:36 PM
Jetrii's Avatar
http://www.amazon.com/Logitech-Advan.../dp/B000CCXCYC
Hmmm, that may help...From the Amazon reviews, it seems like you can use it for DirectTV too.
Jetrii is offline
post #5 of 7 Old 12-09-2006, 09:17 PM - Thread Starter
block's Avatar
Thanks, but maybe I need to rephrase this somehow. I have the universal remote that came with my DIRECTV DVR. I want to program it to control the xbox 360 dvd functions, not the xbox 360 universal remote to control my dvr functions. I was able to program it (directv remote) to use on the original xbox but can't seem to find a code for the xbox 360. Just wondering if possible and if there is a code to program it with. From the looks of it so far, Microsoft is forcing you to buy their remote.
block is offline
post #6 of 7 Old 12-10-2006, 07:39 AM
NoThru22's Avatar
Quoted: 366 Post(s)
Liked: 169
The codes for the Xbox 360 are probably newer than the remote you have and it would be up to DirecTV (or the manufacturer of the box) to put those into your remote. If they're not already built-in, you won't be able to add them. That Logitech remote is a great replacement for your PVR remote and all your other remotes too.
NoThru22 is offline
post #7 of 7 Old 12-10-2006, 08:57 AM
David1's Avatar
Check Remote-Central.com, if it exists thats the place to start.
DavidF
David1 is offline
Closed Thread Xbox Area
