My current projector and 360 set-up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-30-2006, 02:11 PM - Thread Starter
packerssuck69's Avatar
My current setup is:
A Infocus Projector ,95" screen, Xbox 360 & Hd-DVD player
It has Dvi,Vga,S-video Out.
I currently have it set to VGA split into RGB into the xbox.
I was wondering if it would Increase the picture quality if i had DVI to RGB?
Any advice would be Great.
packerssuck69 is offline
post #2 of 10 Old 12-30-2006, 04:22 PM
COACH2369's Avatar
Quoted: 970 Post(s)
Liked: 803
What are you using for an audio connection?
COACH2369 is online now
post #3 of 10 Old 12-30-2006, 05:55 PM - Thread Starter
Fiber thats hooked up to my Bose 321 system,
but i think im going to switch to DVI- to RGB
post #4 of 10 Old 12-30-2006, 06:07 PM
Davinleeds's Avatar
SP5000 with VGA and optic to Technics DD. It has not been better.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #5 of 10 Old 12-30-2006, 06:10 PM
ogbuehi's Avatar
Avoid any unnecessary transcoding if at all possible.
ogbuehi is offline
post #6 of 10 Old 12-30-2006, 08:59 PM
uzziah's Avatar
i'm baffled you didn't meantion WHICH infocus pj you have
uzziah is offline
post #7 of 10 Old 12-31-2006, 07:22 AM
S L O T H's Avatar
I know this probably belongs in the projector forum, but is the in76 coming down in price because of the hd70 and mits hd1000u? I wonder how the in76 stacks up against these bargain models...
S L O T H is offline
post #8 of 10 Old 12-31-2006, 08:45 AM
PatrickB101's Avatar
ouch some one baught bose
your best bet would just be to use the component cables honestly. transcoding bad times.
PatrickB101 is offline
post #9 of 10 Old 01-03-2007, 02:02 PM - Thread Starter
i have the Infocus Lp 70+ with dvi and vga outputs. im currently using vga but will be switch to Dvi for the xbox 360
post #10 of 10 Old 01-03-2007, 05:00 PM
NEO Dan's Avatar
I have the HD1000u and it is really great with the 360, I use a VGA cable on the 360, it works better than the componet cable that came with the 360. For the money I don't think it can be beat.
Dan
NEO Dan is offline
Reply Xbox Area
