HD DVD Meltdown! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-31-2006, 10:07 PM - Thread Starter
romanr's Avatar
At first my HD DVD player was having problems reading a disk it had played fine the day before. After a couple of ejects/reboots the HD DVD player now displays a Red eject light (normally it is green). I'm thinking this means the player has over heated so I have unplugged it to see what it does after it cools down. Anyone else seen this? And yes I have adequate ventilation and this puppy has been playing fine for about a month now.
romanr is offline
post #2 of 5 Old 12-31-2006, 10:34 PM
Doctor Krypton's Avatar
I had this problem. I had the HD DVD unit on top of the 360. I since moved it off to the side and it has not had the problem since.
Doctor Krypton is offline
post #3 of 5 Old 12-31-2006, 10:59 PM - Thread Starter
romanr's Avatar
After a cool down period everything came back OK. I do have mine on top of the 360 so I will look to move it , thanks Doc.
romanr is offline
post #4 of 5 Old 01-01-2007, 05:24 AM
Mustang1's Avatar
yes, move it.
Mustang1 is offline
post #5 of 5 Old 01-01-2007, 11:33 AM
HeadRusch's Avatar
Quoted: 126 Post(s)
Liked: 94
You can also put a couple of spacers inbetween the units......so long as there is a half inch of air or more between the two you shouldn't see overheating issues. The Xbox case bleeds heat, so any case-on-case touching is a bad thing..
Xbox Live / PS3 / Steam: HeadRusch1
Keeping the world safe from the evil antics of Bernie Tanaka and Mel Fujitsu since 1986
HeadRusch is online now
Reply Xbox Area
