Live connection...is it me - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 01-03-2007, 11:13 AM - Thread Starter
djorijun's Avatar
Okay,
So I connected my live finally after having my box for 4 months, and I noticed when I try going to certain downloads pages or when I try to go into lobbies to play live my connection drops. Now mind you my connection is a crappy 300kbps and SBC is not giving me more because of the distance. I am a network technician and I did test the cable and it seemed fine at least I think so. Anyone else have issues like this, ever.
At this point I don't care who wins, just give me my HD already! - DJO
djorijun is offline
post #2 of 27 Old 01-03-2007, 11:22 AM
skogan's Avatar
I've never had that issue.
skogan is offline
post #3 of 27 Old 01-03-2007, 11:43 AM - Thread Starter
djorijun's Avatar
So it may be the cable, CRAP!!!
djorijun is offline
post #4 of 27 Old 01-03-2007, 11:53 AM
Teamhood's Avatar
same here, never had an issue
Teamhood is offline
post #5 of 27 Old 01-03-2007, 12:02 PM
assasyn's Avatar
I am having similar issues and it is leading me toward being a router problem.
assasyn is offline
post #6 of 27 Old 01-03-2007, 12:16 PM - Thread Starter
djorijun's Avatar
well I am connected to a switch, I may just try connecting it directly to the router.
Actually let me re-phrase my question I think it's an issue with live I actually don't drop the connection it looks like a server busy kind of deal. Like i'll get an error, could not connect to so and so, and when I try a second time it connects. Now has anyone ever experienced this.
djorijun is offline
post #7 of 27 Old 01-03-2007, 12:30 PM
exlink's Avatar
I had random disconnects from Xbox Live about a year after using it. I just opened some ports on my router and haven't had a problem since.
exlink is offline
post #8 of 27 Old 01-03-2007, 12:30 PM
TheSkeptiks's Avatar
This happens to me sometimes. In Gears of War mostly.
I'll try to join a game and it says connection to host can't be established...or something like that.
I just keep trying and then it'll eventually work.
Could be the games your trying to join has a bad connection...could be yours. I don't knwo much about this stuff.
TheSkeptiks is offline
post #9 of 27 Old 01-03-2007, 12:33 PM - Thread Starter
djorijun's Avatar
Thanks guys, that's what I was hoping it was.
djorijun is offline
post #10 of 27 Old 01-03-2007, 12:34 PM
Joshuha's Avatar
The Gears of Wars thing is usually because someone else took the slot you were holding when you went to join the match.
So I do a search match (or quick match) and get a game. If by the time I hit A to join and actually joining the game the slot I had seen when I was looking is taken by another player you get the connection to host cannot be established.
I find that if I hit A as soon the server info comes up I never get that error.
Joshuha is offline
post #11 of 27 Old 01-03-2007, 12:35 PM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 246
with only a 300kbps connection i would think that would be it. i run 6Mbs down and 768Kbs up and never have any problems.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
post #12 of 27 Old 01-03-2007, 12:48 PM - Thread Starter
djorijun's Avatar
HAHA well mine must be crap because my down is slower than my up.
djorijun is offline
post #13 of 27 Old 01-03-2007, 12:49 PM
Thanks Joahua...that makes total sense.
post #14 of 27 Old 01-03-2007, 01:49 PM
aronparsons's Avatar
You might want to check if your router is forwarding the ports necessary for Live to the 360. If your router has UPnP, it should be done for you; otherwise, Google for which ports to forward and do it manually in your router. Your connection speed isn't the problem, but your connection might have other problems such as packet loss that are of even more concern.
Xbox Live Gamertag: aron23
aronparsons is offline
post #15 of 27 Old 01-03-2007, 02:41 PM
Zeppo's Avatar
Aye. Make sure to do the Network test in the System blade and ensure the NAT test comes back as 'open' rather than 'moderate' or 'strict.' I've had lots of problems with firends who can't join the same room as each other in a big-room game, can't play head-to-head games, and sometimes can't even initiate a voice chat with each other. Invariably, it has to do with the NAT of their routers.
Then again, there are several games (2K games, EA sports games) where I will get dropped from a game with a friend, and yet still be connected to XBL, even able to continuously voice chat with each other as we are disconnected in the actual game. It's a real p.i.a. and seems to happen a lot with certain games when they first come out.
Zeppo is offline
post #16 of 27 Old 01-03-2007, 03:14 PM - Thread Starter
djorijun's Avatar
I did the test last night and the NAT did show open.
djorijun is offline
post #17 of 27 Old 01-03-2007, 04:01 PM
FourDoor's Avatar
Here is my story: My launch 360 would alway disconnect me from Live when I first logged on. So the scenario was, power on 360, auto-log in, launch game, go into multiplayer. At this point, I would either drop off of live or be able to play for 5mins and then get logged off. It's not that I was dropped from the game server, I lose connected to XBL completely. And this only happened when I jumped into multiplayer games. The remedy to this was to force a sign out of my gamertag and then log back in to XBL after I get dropped.
My connection was/is cable modem -> switch -> 360. The 360 was not receiving any special treatments. After replacing that 360 and keeping the same connection settings, I am no longer being dropped from XBL which convinces me that it was my original 360 that was the problem. My new 360 does not have this problem at all and also does not freeze every so often like my launch 360 did. My connection setup remained the same so it was not my network config.
Reading your post, it sounds worse than my original problem as I was only getting dropped when I went into multiplayer (regardless of game). Try placing your 360 in a DMZ on your router and see if that helps with the drop-out issues.
FourDoor is offline
post #18 of 27 Old 01-03-2007, 07:08 PM
uzziah's Avatar
if you want to test your speed try speakeasyspeedtest
uzziah is offline
post #19 of 27 Old 01-04-2007, 09:28 AM - Thread Starter
djorijun's Avatar
Okay so I fixed it, I tested my cable with my super expensive cable tester and it said all was fine no issues or anything. My cable is less than 300ft which is a good thing, after 300 ft you need a switch (which i was connected to mind you) and no dice, I used my cheap 2 dollar swapmeet cable tester and it said there was a connection loss in the cable, (I'm guessing the cable was bad somewhere in the middle) I switched out the cable and BAM!!!! I was connected.
djorijun is offline
post #20 of 27 Old 01-04-2007, 10:06 AM
shahram72's Avatar
I have had random dropped connections with the 360 since I got it. I never had problems with the original xbox. PGR3 was unplayable most of the time, TDU is unplayable. Gears gives me problems sometimes, but a sign out and sign in cures that. My router is set up fine, something wrong with software or hardware design I think.
Shahram
Are you capable of independent thought, or do you need the government and mass media to do that for you?
Xbox Live Gamertag: Shahraminator
shahram72 is offline
post #21 of 27 Old 01-04-2007, 11:13 AM
NoThru22's Avatar
Quoted: 366 Post(s)
Liked: 169
You need to test your speed AND more importantly, your latency.
NoThru22 is offline
post #22 of 27 Old 01-04-2007, 11:45 AM
Quoted: 146 Post(s)
Liked: 246
Completely agree. Having a big pipe is nice but it won't help much if you're playing people from Japan.
post #23 of 27 Old 01-04-2007, 12:16 PM
NoThru22's Avatar
Quoted: 366 Post(s)
Liked: 169
I'm talking about his latency to local servers, not distant ones. The extreme run of cable to his house may be causing excessive latency, which would be responsible for the drops. 300k is more than plenty to maintain a connection, but not if he's clocking 150 ms+ latencies.
NoThru22 is offline
post #24 of 27 Old 01-04-2007, 03:54 PM
jpb3wvu's Avatar
I actually had to speak to my ISP and have them rewire from their switch up the road to my house b/c of packet loss. It took them a week but they did it no questions asked after their 3rd tier support in CO (I am in WV) looked at the data and saw the packet loss.
jpb3wvu is offline
post #25 of 27 Old 01-04-2007, 07:02 PM
vhato's Avatar
I assume you are using a Fluke. These measure Attenuation, Near end cross ralk, cable length, etc. If you had a loopback on the cable and it passed, its time for a new Fluke. Especially when you found the problem with a cheap old continuity tester. I would be pi$$ed off!!!
Glad you got it working
vhato is offline
post #26 of 27 Old 01-05-2007, 04:09 PM - Thread Starter
djorijun's Avatar
So i'm back fellas! So I also found out I must have my firewall turned off on my router. It stopped working after it was fixed, but when it first worked I ended up connecting to my Vista media center pc so that I may do the whole media thing. after I got that working I went to work as normal, came back home and it didn't work again. I checked my Vista box to see if it was getting an internet connection and it wasn't, I checked my xp box and my mac and those were getting a connection...WTF!!! So I removed the firewall from my router and both the 360 and the vista box got a connection. Can someone ellaborate on this please?
djorijun is offline
post #27 of 27 Old 01-05-2007, 04:51 PM
vhato's Avatar
What kind of Router do you have and if UPNP is Enabled in it, then a software screwup on one of the PC's caused the problem.
vhato is offline
Reply Xbox Area
