Getting sound from XBOX 360 to PC speakers - AVS Forum | Home Theater Discussions And Reviews
Old 01-05-2007, 12:39 PM - Thread Starter
atomhead's Avatar
I have the Cambridge Soundworks 2.1 Digital speakers. I am planning on using a VGA cable to get my display from the 360 to my monitor, however I am not sure how to get sound.
I am getting a VGA cable and this is the description of it (can't link yet):
# The unit can be used with TVs, PC monitors and projectors equipped with VGA input only.
# An optical input is also included, giving you the option of enjoying crisp digital sound.
It has digital input, and my speakers have a digital in connector so I am assuming I will connect the optical input from the cable to the input on the speakers but I'm not sure. Can someone confirm this is correct? I also have the subwoofer on the floor (this is where the input is) and the monitor is on the desk so they are about 4' apart, but it doesn't look like the input on the cable, and the sound output are going to split that far. I'm kind of confused what to do.
atomhead is offline
Old 01-05-2007, 01:34 PM
PridgNYC's Avatar
The Cambridge Soundworks speakers only support Coax digital input. The microsoft vga adapter only includes an optical output for digital, but it does include analog stereo outputs which you can use to connect to your speakers. There are red and white rca plugs you can use to connect to external speakers or a reciever. It also includes an adapter to convert the left and right rca plugs to a stereo mini plug. (suitable for plugging into your speakers) you may want to pick up a stereo rca extension cable (male on one side female on the other), as the rca plugs are integrated into the vga cable and will end up at the back of your monitor.
PridgNYC is offline
Old 01-05-2007, 02:54 PM - Thread Starter
atomhead's Avatar
Sounds like I will use the adapter to turn the RCAs into stereo mini plug.. so I guess if I can't find the microsoft issue adapter i'll just get that seperately.
Thanks for the help!
atomhead is offline
Old 01-05-2007, 03:07 PM
hookem12387's Avatar
Don't they have cables that are toslink(optical) to digital coaxial? I think I've seen em. That would give you true digital sound, but I don't know if it matters with a 2.1 set up anywy
hookem12387 is offline
Old 01-05-2007, 03:16 PM
longhorns's Avatar
It comes with the VGA cable from microsoft, surprised me too, it also comes with a VGA gender changer. pretty sweet right.
Absence of Evidence is not always Evidence of Absence
live together, die alone
Gamertag: Bigbev02-Tell me if you're from AVS.
Achievement Unlocked: You've found the red couch!
longhorns is offline
