Hl-s5087w question regarding 360 ... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-16-2007, 02:08 PM - Thread Starter
saylor's Avatar
When I run my xbox 360 in 1080p on VGA it looks not so good, jaggy ... On componet 1080p it looks AMAZING, why ?? When I run my 360 at 720p on VGA it looks AMAZING but bad on 1080p, does anyone know why ??
I read that 1080i, sometimes look better ... Is this true ?? When my VGA setting is set at 720p my TV upscales great, but 1080p is like it is down-scaling.
Sorry for all the confusion and questions.
saylor is offline
post #2 of 10 Old 01-16-2007, 05:53 PM - Thread Starter
saylor's Avatar
Bump
saylor is offline
post #3 of 10 Old 01-16-2007, 06:17 PM
modiGTI's Avatar
I have the same set. I've been using VGA for a few months now, but imo, it has less jaggies compared to component for me. What kind of settings are you using?
Live/PS3: NovembersChopin
modiGTI is offline
post #4 of 10 Old 01-16-2007, 07:11 PM
andreo's Avatar
I have the 61" version of your TV. I've been running VGA since October and I've seen no difference in resolution between VGA and component for games.
When you use the VGA connection and hit "info" on the Samsung what does it display? Does it say that it's receiving a 1080p signal @ 60 Hz or something else?
Xbox Live: CaptCaveman
PSN: Captcaveman
Wii: some long number that I will never remember. Thanks Nintendo!
andreo is offline
post #5 of 10 Old 01-16-2007, 07:56 PM - Thread Starter
saylor's Avatar
Yes it says 1080p @ 60hz ... But like reflections and stuff don't look as good in 1080p, than they do in 720p with the TV upconverting.
saylor is offline
post #6 of 10 Old 01-17-2007, 07:31 AM
teckademic's Avatar
Quoted: 107 Post(s)
Liked: 106
can you confirm that it does accept 1080p through component? I am interested in buying this set soon.
teckademic is offline
post #7 of 10 Old 01-17-2007, 07:31 AM
jhferry's Avatar
Quoted: 35 Post(s)
I have this set, how are DVDs on VGA because out of the box I think DVDs look like crap over component with the 360 on this set.
jhferry is offline
post #8 of 10 Old 01-17-2007, 07:38 AM - Thread Starter
saylor's Avatar
DVDs look Awesome, via VGA ... It upconverts them beautifuly.
saylor is offline
post #9 of 10 Old 01-18-2007, 08:50 AM
F355FTS's Avatar
I have the HLS6187 yes dvd's over vga look almost like HD dvd's you have to get a VGA cable for this set.
Sounds to me like you might have a bad VGA cable. Mine looks much better with games on VGA set to 1080p vs component. Not a hugh diffrence but noticable.
F355FTS is offline
post #10 of 10 Old 01-18-2007, 09:36 AM
andreo's Avatar
The HL-Sxx87 series will accept 1080p through HDMI, VGA, and Component just fine.
PSN: Captcaveman
andreo is offline
Reply Xbox Area
