Why is there all sorts of noise against dark backgrounds when playing 360? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-16-2007, 02:47 PM - Thread Starter
terryb28's Avatar
I have my 360 hooked up via the microsoft component cables to a panasonic 42px60u. I'm noticing a lot of what I would describe as noise or fuzz when viewing dark backgrounds(loading screens, weapons in RB6, anything black basically). It looks like tiny green and red dots(the size of one pixel) flying around. any idea what could be causing this?
XBOX: terryb28
PSN: terryb30
terryb28 is offline
post #2 of 14 Old 02-16-2007, 08:23 PM - Thread Starter
terryb28's Avatar
anyone else experiencing this?
XBOX: terryb28
PSN: terryb30
terryb28 is offline
post #3 of 14 Old 02-16-2007, 09:41 PM
johnbe's Avatar
Liked: 44
I haven't noticed this. I have rb6 but have yet to play it due to trying to complete other games. I have played on a Maxent plazma (currently) and a Panasonic AE900U. No problems on either. Sounds like it could be your cable connection. Make sure they are tight.
johnbe is offline
post #4 of 14 Old 02-16-2007, 09:49 PM
pdawg17's Avatar
Quoted: 13 Post(s)
Liked: 26
If you lower your brightness a few notches it should go away...
pdawg17 is offline
post #5 of 14 Old 02-16-2007, 10:05 PM
leftkidney's Avatar
I have noticed that problem and I thought it was a problem with my TV
now I am not saying this is the cause of the problem but all I know is I tried 3 M$ Component cables with the same result
then I bought the Monster Component cables no problem like I said I am not saying it was the M$ cables but without them no problems
there is a topic I started but I have had some people say the test is not accurate but here is is
http://www.avsforum.com/avs-vb/showthread.php?t=794799
I want the retro skin back please
leftkidney is offline
post #6 of 14 Old 02-17-2007, 01:59 AM
formulanerd's Avatar
i saw this same thing over component, i switched to the microsoft vga cables and it's gone now. so is a LOT of the tearing that was going on, along with some of the jaggies.
No trees were harmed forming this post, though many electrons were inconvenienced.
SERGEANT SERGEANT MASTER SERGEANT SHOOTER PERSON
Then:|A40|AX720|F1|K702|DT880|ES7|MS2i Now:|MS1|AD700|PC360|A30
formulanerd is offline
post #7 of 14 Old 02-17-2007, 05:28 AM
metalsaber's Avatar
Quoted: 1029 Post(s)
Liked: 844
I would also suggestion turning down or completely turning OFF the TV's sharpness control. Sharpness does not make a picture look better. Especially a HD one.
metalsaber is offline
post #8 of 14 Old 02-17-2007, 09:22 AM - Thread Starter
terryb28's Avatar
picture seemed pretty soft with the sharpness turned way down, but I'll give it a try. not sure why it would get rid of the noise/fuzziness I'm experiencing, but I'm no expert.
XBOX: terryb28
PSN: terryb30
terryb28 is offline
post #9 of 14 Old 02-17-2007, 09:23 AM - Thread Starter
terryb28's Avatar
thanks, I'll check out the monster cables.
XBOX: terryb28
PSN: terryb30
terryb28 is offline
post #10 of 14 Old 02-17-2007, 02:51 PM
Thrillhouse17's Avatar
Quoted: 157 Post(s)
Liked: 65
I have the exact same tv and have noticed the same thing today while playing. There is noise not only during the loading screens, but I noticed that there is noise during the game.
However I have only noticed it with that one game. Let me know if you figure out what it could be, or if you found a way to get rid of it.
Thrillhouse17 is offline
post #11 of 14 Old 02-17-2007, 06:18 PM
pdawg17's Avatar
Quoted: 13 Post(s)
Liked: 26
Have you tried what I said above? It worked for me and didn't have to buy expensive cables...I have a 9UK 50" and when I lowered the brightness the problem went away...to compensate for the slight drop in brightness I just raised the contrast (picture) a few notches...
pdawg17 is offline
post #12 of 14 Old 02-17-2007, 06:31 PM - Thread Starter
terryb28's Avatar
thanks for the input. I'll give it a whirl and report back.
XBOX: terryb28
PSN: terryb30
terryb28 is offline
post #13 of 14 Old 02-18-2007, 01:45 AM
wtfer's Avatar
Quoted: 236 Post(s)
Liked: 64
I'm pretty sure what your seeing is inherent to Plasma technoloy.
Every plasma panel has that, just turn down the brightness & contrast & it will lessen it.
wtfer is offline
post #14 of 14 Old 02-18-2007, 03:50 AM
leftkidney's Avatar
probley because your TV has a crappy scaller and video precessor that cant be turned off or bypassed
but VGA probally bypasses it since it is assumed that the VGA would have the video processing and other stuff done by the PC which would probally be pluged into it
TV makers put stupit "enhancements" on their sets that ruin the picture
the Samsung I think had this problem with the DNIe you couldnt turn it off and it would fail 3:2 test and deinterlacing the later models had this fixed it was put there to make the picture better but it made it worse really stupid if you ask me these so called "encahcements" always ruin the picture
Reply Xbox Area
