mkv to wmv-hd with DTS - AVS Forum | Home Theater Discussions And Reviews
Old 09-24-2007, 11:56 AM - Thread Starter
jat1964's Avatar
Hello
Have been converting using the encoding pack with some fantastic looking results on the 360....The problem i am having is converting a .mkv file with dts sound to wmv-hd using wmnicenc...i get no sound.....it's works fine with 5.1 ac3 soundtracks.....Please Help!!!!!
Cheerz
James
jat1964 is offline
Old 09-24-2007, 08:50 PM
Marc D Carra's Avatar
Quoted: 38 Post(s)
Liked: 44
Can you playback the MKVs with DTS with the media player? If not then it's a setting in AC3 filter. Had the same issue when encoding a file with DTS in TmpgEnc 4 Xpress.
Just curious, what settings give you best results when converting to WMV?
Marc.
MDC
Marc D Carra is offline
Old 09-25-2007, 08:28 AM
AdamPS's Avatar
You can try a program called Encode360 at www.dcunningham.net. It has taken pretty much everything I have thrown at it.
AdamPS is offline
Old 09-25-2007, 12:46 PM - Thread Starter
jat1964's Avatar
Thanks for the replies....it was my 1st post !!!
setting i use in wmnicenc for audio "Windows media audio professional"
"384 kbps, 48 kHz 5.1 channel 24 bit CBR"
Video "Windows Media Video 9 Advanced profile"
vbr Quality "96/97"
Burn as a data disc...playback via xbox360/Pioneer Plasma picture is very good sound also....
Will check encode 360 and ac3filter setting....anybody using wmnicenc and dts sounds????
Cheerz James
jat1964 is offline
Old 09-25-2007, 04:27 PM
noremacyug's Avatar
Quoted: 48 Post(s)
if you want you can easily convert the DTS track to an AC3 track. here's a tutorial i wrote up over at xbox-scene regarding this.
http://forums.xbox-scene.com/index.php?showtopic=623114
also, i'm not trying to highjack here. but what are you guys using to encode with. i have the latest version of tmpgenc 4.0 xpress and the output is great. my only problem is that first few minutes of the video stutter. it's as if it has a dropped frame rate. after the first ~5 mins it clears up and the rest of the video is smooth as butter. i have racked my brain with this problem and no one else has been able to solve the issue either.
God Bless America
Guy
noremacyug is offline
Old 09-26-2007, 10:52 AM - Thread Starter
jat1964's Avatar
Hello
Many thanks for that...will give it a go....the guide i have been using is here..... http://www.avsforum.com/avs-vb/showthread.php?t=853878
Good results with .mkv and ac3 sound....no stutter at the start.....looks very good via 360/plasma....
cheerz James
jat1964 is offline
