The Official Rock Band Discussion Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #541 of 12643 Old 12-12-2007, 09:04 AM
dboss's Avatar
I have a lot of trouble with the kick pedal. I find myself using my entire leg A LOT. My timing isn't very good just pivoting at the ankle for some reason.
PSN & Xbox 360 Gamertag: dboss007
dboss is offline
post #542 of 12643 Old 12-12-2007, 09:07 AM
Chris Rein's Avatar
Originally Posted by Rhyvven View Post
You state correctly DaverJ....For drummers it's called playing "heel up".
It's where basically the ball of your foot is in constant contact with the kick pedal and the heel of the foot remains "up" and off the pedal. The "pretty tricky" part is finding the correct amount of pressure to leave on the kick pedal.
At NO time, be it heel up or down (foot flat) should your foot leave contact with the pedal. And I do not mean just for real playing, that goes for the game too as stated in the tutorials I believe).
The heel up method will test your balance, "feel" for the pedal and work out the calf/shin and possibly the whole darn leg.
During one of the loading screens I think they also recommend leaving your foot (flat) and totally compress the pedal. THEN lift up and down to get the notes. But again, it takes mental timing to adjust for the "trip" up and quickly back down to get that note.
That's how I play. Half pressure, heel off the ground and using pivot and leg action.
I also found that sitting with my crotch facing the red drum helped with doing crashes with the green and made my foot feel more natural on the pedal. As mentioned, I found that the kit slightly forward helps as does the right height as the manual states. Also helps with speed on the red and red/yellow runs.
If you have not done so already, make sure you manually calibrate everything. It really helps.
Also, one nice way to practice (if at work at a desk!) is to have that nervous habit in your leg. Try keeping your heel off the ground and the ball putting pressure on the floor. Sit there and bounce your leg up and down in the nervous motion.
Chris Rein is offline
post #543 of 12643 Old 12-12-2007, 09:08 AM
DaverJ's Avatar
Quoted: 1323 Post(s)
Liked: 3721
Great tip Rhyvven, thanks!
As you were typing your response I was editing mine to replace "heal" with "pivot the ankle", but based on your reply I'm not sure if I'm as accurate now.
Can you re-read my comment above and let me know if I'm off-track please?
DaverJ is online now
post #544 of 12643 Old 12-12-2007, 09:38 AM - Thread Starter
GrooveRite's Avatar
Oh boy...I'm ALLL about the leg shakes at work at my desk!! lol I should have no problem getting all this down.......hopefully!
Gamertag: BaneAssassin
PSN: BaneAssassin
GrooveRite is offline
post #545 of 12643 Old 12-12-2007, 11:31 AM
DaverJ's Avatar
Liked: 3721
Yeah, I need to get a spare pedal for work.
post #546 of 12643 Old 12-12-2007, 11:44 AM
TRALFAZ's Avatar
Being an actual drummer, I can tell you that is how most drummers play the base and double base drums, even the high hat. Here's my "Rock Band" set-up.
I tried the demo setup at Best Buy, it's just not the same.
TRALFAZ is offline
post #547 of 12643 Old 12-12-2007, 12:14 PM
hiko13's Avatar
Originally Posted by logicalnoise View Post
I find it has more to do with your energy level...on the drums It's best to start playing early
Dead on with this...played Sandman over lunch and blew away my previous high (set last night) by over 30,000...which should tell you just how bad I was doing last night.
PSN: Thrillho
XBL: Herald of Woe
hiko13 is offline
post #548 of 12643 Old 12-12-2007, 12:28 PM
DaverJ's Avatar
Liked: 3721
I played Sandman last night on hard and almost lost it at the end because I was tired. It's one of those songs that, like Reaper, has a tricky ending ... and keeps going beyond the original song.
"Hey, the song should have faded out by now!"
post #549 of 12643 Old 12-12-2007, 01:54 PM
lovingdvd's Avatar
Quoted: 2859 Post(s)
Liked: 608
OK, so how many of you...
- have poked yourself in the eye with a drumstick while playing?
- have had a drumstick fly out of your hand during a "fill" section?
- have had a drumstick fly out of your hand twice during the same song?
- have decided to play "just one more song", but keep going until you finish set list after set list?
- have seen your otherwise "normal" friend turn into a devil-like creature while trying their hand at vocals?
- still have all the Rock Band boxes from the packaging piled in the corner of your room, too busy playing to actually clean up that mess?
All signs of a great game!
lovingdvd is online now
post #550 of 12643 Old 12-12-2007, 01:59 PM
thejokell's Avatar
You use a rack? Lame.
Steam/XBL/PSN: thejokell
thejokell is offline
post #551 of 12643 Old 12-12-2007, 02:05 PM
rdank's Avatar
You must have some rubber ankles too. I don't think I could play the hit-hat like that.
rdank is offline
post #552 of 12643 Old 12-12-2007, 02:42 PM
TRALFAZ's Avatar
LOL !! My hat is actually cable operated by remote pedal, easier placement with the double base. Love the rack by the way, tear down and set up is a breeze.
TRALFAZ is offline
post #553 of 12643 Old 12-12-2007, 03:27 PM
rdank's Avatar
My brother played drums. I often helped setup for gigs for a number of years. That rack setup looks a ton easier to put up and tear down. He'll be back in town during xmas. I'm interested to see what he thinks of Rock Band. He was damn good and majored in jazz/music theory.
rdank is offline
post #554 of 12643 Old 12-12-2007, 04:47 PM
SSpectre's Avatar
Quoted: 25 Post(s)
Liked: 37
When I was in a band our drummer had a rack. It was ridiculously easy to set up and take down.
SSpectre is offline
post #555 of 12643 Old 12-13-2007, 09:29 AM
Lord Flatus's Avatar
Quoted: 36 Post(s)
Liked: 35
I got a 2nd replacement guitar, but it's still iffy. The overdrive seems to fire itself off sometimes, but the strum bar is quieter than the first replacement. I sure hope they make the wireless one a "deluxe" version, as I would pay more for a wireless Strat that worked well and kept working. Heck, I'd pay extra for wired one that kept working well as I like the guitar.
I'm back to using the guitar pick, which I find really helps me keep time alt-strumming the long sections.
Lord Flatus is offline
post #556 of 12643 Old 12-13-2007, 10:23 AM
LandShark22's Avatar
Wow the wireless strat is going to be $79? Yikes I guess I can live with the wire
LandShark22 is offline
post #557 of 12643 Old 12-13-2007, 10:40 AM
nyboy42's Avatar
Originally Posted by DougPr View Post
If they'd ever get to finishing that "Who's Next" album, that would bring a whole lot of DLC joy to me.
OHHH MAAAAN im so drooling for Who's Next to be released.....please release real soon...i cant wait anymore
nyboy42 is offline
post #558 of 12643 Old 12-13-2007, 11:25 AM
lovingdvd's Avatar
Liked: 608
Wasn't it originally rumored to be released within a week of the game's release? What is the expected date now?
post #559 of 12643 Old 12-13-2007, 11:37 AM - Thread Starter
GrooveRite's Avatar
Let me tell you guys something.....
I was just at Bestbuy on my lunch break checking out stuff in their gaming section and what do I see as soon as I get there?? A brand new Rockband Kiosk with Klipsch Synergy surround sound set up. I see this guy trying out the guitar with about 5 to 7 people looking on watching him play. As soon as hes done, I ask him if I can get on the drums while he plays guitar. He said sure and I hear people saying...."Whoa, both of them are going to play?!?!" lol. So, I pick Foo Fighters Fly and I start jammin on the drums. By the time I'm done, there are about 18 to 20 people crowded behind us watching and all I hear are people asking the BB drones where they can purchase this game. The best thing HRMONIX has done (especially over this holiday) is having these Kiosk set up (and putting up new ones when need be) because they practically sell themselves.
PSN: BaneAssassin
post #560 of 12643 Old 12-13-2007, 04:29 PM
Mcklein's Avatar
Believe it or not i live the wire one better...its like the 360 is the amp...lol
Mcklein is offline
post #561 of 12643 Old 12-13-2007, 05:52 PM
Quoted: 36 Post(s)
Liked: 35
The only thing I don't like is the rats nest of cables when trying to put away the four-person band setup without completely breaking down all the connections. It's fugly.
post #562 of 12643 Old 12-13-2007, 06:03 PM
cesslinger's Avatar
Ha, that is just like a real band though.
GT Chuck81
cesslinger is offline
post #563 of 12643 Old 12-13-2007, 08:37 PM
JuiceRocket's Avatar
Quoted: 50 Post(s)
Liked: 41
True! Now if they could only add that zap you sometimes get when you've got your guitar ready, lean to the mic to sing, and realize you're not entirely grounded! Fun stuff!
-JR
JuiceRocket is offline
post #564 of 12643 Old 12-14-2007, 06:17 AM
WizarDru's Avatar
Ain't that the truth. I would LOVE some wireless stuff, for the guitars at the very least. Hopefully they'll be out in a month or two.
WizarDru is offline
post #565 of 12643 Old 12-14-2007, 06:21 AM
thejokell's Avatar
Current eta is February.
post #566 of 12643 Old 12-14-2007, 06:32 AM
rdank's Avatar
As mentioned before, it's pretty much the same price to buy the bundle and get $30 or whatever back from Gamestop. Although, it might not be a $30 value anymore to GS.
rdank is offline
post #567 of 12643 Old 12-14-2007, 01:15 PM
lovingdvd's Avatar
Liked: 608
+1.
Fortunately I happen to prefer my wireless guitar from GH 3 over the strat from RB, so for times when I'm just playing solo on guitar there's no wires to deal with.
post #568 of 12643 Old 12-14-2007, 04:02 PM
Mcklein's Avatar
I dont trust the release dates on some of these sittes but amazons claims january 31 for the wireless...
http://www.amazon.com/Rock-Band-Xbox..._bxgy_vg_img_b
Mcklein is offline
post #569 of 12643 Old 12-14-2007, 07:17 PM
chad473's Avatar
Quoted: 129 Post(s)
Liked: 147
effin' GG&HT on drums. made it to 85% and just lost all coordination.
edit: finally! I'm sure it looked ugly as hell but I finally got it.
Vizio P50-C1 - My Calibration Settings
Xbox One S 2TB
PS4 Pro 2TB
chad473 is online now
post #570 of 12643 Old 12-15-2007, 09:08 AM
lovingdvd's Avatar
Liked: 608
Police pack is incredible. Well done master recordings. Wow. I'm a big fan of GH II as well and wish they could deliver some quality DLC like this.
Reply Xbox Area
