mkv to mp4 , fast and easy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 32 Old 11-24-2007, 02:28 PM - Thread Starter
simen02's Avatar
Her is a link to program hat can convert mkv files into mp4 files in just one click. its fast and easy to use
http://sentry23.googlepages.com/home
simen02 is offline
post #2 of 32 Old 11-24-2007, 02:30 PM
darklordjames's Avatar
Liked: 94
Does MP4 work in Media Center 360? Or just in the dashboard?
darklordjames is offline
post #3 of 32 Old 11-24-2007, 02:31 PM - Thread Starter
simen02's Avatar
at the moment just in dashboard, but lets hope it will work in next update
simen02 is offline
post #4 of 32 Old 11-24-2007, 02:35 PM
Liked: 94
Just the dashboard is useless for me. My girl is used to XBMC, so MCE360 is an easy transition. Dashboard is too complicated.
post #5 of 32 Old 11-24-2007, 02:56 PM
the red worm's Avatar
mp4 works streaming video from a mac to a 360 with connect360
the red worm is offline
post #6 of 32 Old 11-24-2007, 10:33 PM
vertigo235's Avatar
Quoted: 123 Post(s)
Liked: 100
WOW, I tried this out and it went so fast I thought it couldn't be true.
Sure enough it works perfectly! Incredible!
No more waiting what seemed like hours for Encode360 to reencode!
Xbox Live: IamVertigo
PSN: IamVertigo
vertigo235 is offline
post #7 of 32 Old 11-25-2007, 09:40 AM
Moosebox's Avatar
Sweet program, a lot faster then encode360.
Anyone know if a USB 2.0 external drive is fast enough to stream HD movies directly to the 360.
Moosebox is offline
post #8 of 32 Old 11-25-2007, 10:58 AM
vertigo235's Avatar
Quoted: 123 Post(s)
Liked: 100
If my network connection is, it should be more than fast enough.
PSN: IamVertigo
post #9 of 32 Old 11-25-2007, 11:48 AM
Nox
Nox's Avatar
I'm confused here... Is this program supposed to create an .mp4 movie file from an .mkv?
I used GOTsent 23b6 and began converting an .mkv movie. All seemed to go extremely well. A movie file was being created in the output directory, but after the conversion everything was deleted automatically. There's no .mp4 anywhere.
Hmm... maybe it's because I'm using Vista. I'll give it a try on my XP machine.
-David
Nox is offline
post #10 of 32 Old 11-25-2007, 12:11 PM
vertigo235's Avatar
Quoted: 123 Post(s)
Liked: 100
There is a trade off, at least for now.
You can only result with a 2ch audio file.
Nox, try using the safe sync option, or make sure that AC3Filter is set up to output to a 2 ch audio file like Pro Logic II.
PSN: IamVertigo
post #11 of 32 Old 11-25-2007, 12:32 PM
Nox
Nox's Avatar
I'll try that.
Right now, though, I tried it in XP. This time the files were not deleted automatically. But, instead of an .mp4, I was left with seperate .h264 and .wav files.
The process is extremely fast. It took about 10 minutes total (I'm comparing this to the 2+ hours it takes to convert an .mkv to .wmv with WMEncoder... which I've been doing now for several months with fantastic results). Once this program matures, it looks to be a fantastic alternative to get .mkv on the 360/PS3.
-David
Nox is offline
post #12 of 32 Old 11-25-2007, 02:10 PM
vertigo235's Avatar
Quoted: 123 Post(s)
Liked: 100
I had a similar problem, maybe even the exact same problem. I updated AC3Filter and then made sure it was set for Dolby Pro Logic II and now it works fine. Also SafeSync worked too.
I may still use Encode360 to keep the 5.1, but in a pinch if I want to watch something right away this is a great alternative. I hope they find a way to make 5.1 work.
PSN: IamVertigo
post #13 of 32 Old 11-25-2007, 06:45 PM
Moosebox's Avatar
Hmm, my output is getting deleted upon completion... what am I doing wrong? :P
update: Looks like it was just the source file that was the problem. I tried it with a different file and it worked fine.
Moosebox is offline
post #14 of 32 Old 11-25-2007, 09:23 PM
chad473's Avatar
Quoted: 129 Post(s)
Liked: 147
I didn't have much luck with this program, but just remember that many mkv's don't play nice when converted to profile 4.1 for play on the 360 (like this program does). You may wind up with a file that doesn't play or has bad macroblocking. I found it very hit or miss. After much messing around, I've moved to using a laptop hooked up to the tv for mkv.
Vizio P50-C1 - My Calibration Settings
Xbox One S 2TB
PS4 Pro 2TB
chad473 is offline
post #15 of 32 Old 11-25-2007, 09:25 PM
vertigo235's Avatar
Quoted: 123 Post(s)
Liked: 100
Yeah it works better with some files than others, but certainly worth a try before going the long road (ie Encode 360).
PSN: IamVertigo
post #16 of 32 Old 11-28-2007, 06:40 AM
Shaner1's Avatar
Thanks for the post simen02. That program is great and worked fine for me the first time.
Now if there was only an easy way to get 5.1 integrated I would be all set. I know there are guides out there on how to use Nero to get 5.1 acc audio but I haven't been able to figure it out yet. (for the PS3)
Shaner1 is offline
post #17 of 32 Old 11-28-2007, 01:51 PM
taosun's Avatar
I'm trying to play an MP4 file on my hdtv using my son's xbox 360. I saved the file to a thumb drive and burned it to a data CD. The dashboard recognizes the file both ways but when I try to play it I get a message that I need to download an update to allow the console to play an MP4 file. I try the download and first it tells me that it has already been downloaded and suggests I look for it. To do that I have to start the game it was downloaded for which I don't know and neither does my son. The it asks if I want to download it again. I do and the download starts but then stops soon and I get a message to "try again later, status code: 80070005". I don't know what else to do. Any ideas?
taosun is offline
post #18 of 32 Old 11-29-2007, 11:27 AM
vertigo235's Avatar
Quoted: 123 Post(s)
Liked: 100
I don't seem to have much luck without choosing the safe sync option.
PSN: IamVertigo
post #19 of 32 Old 11-29-2007, 02:13 PM
venk's Avatar
It works ok on my 360, but how do I get my PS3 to recognize that there is a video file on the thumb drive? It is in the root directory of the thumb drive saved as an MP4 but the XMB tells me there are no files on the thumb drive.
venk is offline
post #20 of 32 Old 11-29-2007, 04:47 PM
kev0ut's Avatar
This is amazing... I was using River past video cleaner which was taking 12 hours to convert 1 gb MKV files... this takes about 10 minutes. I am blown away. I wish there was a way to set up a queue of files
kev0ut is offline
post #21 of 32 Old 11-29-2007, 09:34 PM
leftkidney's Avatar
there is 1 HUGE thing that is overlooked here
most all mkv files are AC3 5.1 sound
the 360 cant play that with mp4 only DD 2.0
so whats the point?
I want the retro skin back please
leftkidney is offline
post #22 of 32 Old 11-30-2007, 04:02 AM
MarkH's Avatar
This program will not work properly for me. It throws up all sorts of error messages every time I start a convert. ****e program, Ill stick with PS3 Video 9, it may take longer but its literally plug and play.
MY THEATRE ROOM, LIVING ROOM and BEDROOM SYSTEMS THREAD
http://www.avsforum.com/avs-vb/showthread.php?t=1105927
MarkH is offline
post #23 of 32 Old 11-30-2007, 11:16 AM
vertigo235's Avatar
Quoted: 123 Post(s)
Liked: 100
Can someone make a program to remux to WMV or even XVID now? Come on people get on this!!
PSN: IamVertigo
post #24 of 32 Old 11-30-2007, 02:05 PM
Shaner1's Avatar
so whats the point?
That's why I was using it for the PS3, not the 360. WMNicEnc is the only 360 encoder I use, it's the quickest and best one I've tried.
Shaner1 is offline
post #25 of 32 Old 11-30-2007, 04:10 PM
leftkidney's Avatar
yep I have said this before
the 360 is a huge failure as a Media Center Extender which it was marketed on, remember MS said it is not just a gaming machine, it is a Media Center Extender also
it has more limitations than anyother Media Center Extender out there, not to mention the ORIGINAL XBOX 1 modded running XBMC
really this is appalling that MS would release this like this and at this point havent fixed it to allow the playback of all and I mean all audio/video files. The XBOX 1 Modded running XBMC can play files my computer cant even play
WTF this is stupid and if I can install XBMC on the 360 I dont even care if I can ever play games again so long as I can play anything from my computer over the network like i can with my XBOX 1
and Emcode360 works fine other than it can take some time to finish sometimes
post #26 of 32 Old 12-01-2007, 09:26 PM
BuGsArEtAsTy's Avatar
Quoted: 386 Post(s)
Liked: 170
so whats the point?
Well, this software can output 2.0 audio, for playback on the 360.
BuGsArEtAsTy is offline
post #27 of 32 Old 12-07-2007, 11:40 AM
kilongs's Avatar
Thanks for the heads up, simen02. This works very well for me. Every mkv video that I've converted using this tool has played flawlessly on my 360. It really is "fast and easy".
XBL - kilongs
PSN - brewticus
kilongs is offline
post #28 of 32 Old 12-07-2007, 12:08 PM
mikepaul's Avatar
Quoted: 179 Post(s)
I haven't seen any interviews with Xbox personnel where anyone asked them why all the limitations, so I'm still going with "We'd be encouraging piracy if we played everything so we won't" being the reason.
I don't think DLink loses any sleep over their streaming media hardware, or any other manufacturer who has no side business providing codecs to the people making DVDs, old style or HD. Microsoft IS unique there, I believe, and I don't expect that what appears to be a protectionist attitude will change anytime soon.
Lucky for me streaming videos were a bonus with my new game machine, and converting to WMV9 on my PC while I play games is not a hardship...
LIVE: mikepaul
Evil intentionally does harm to innocent beings. Good will occasionally do harm to innocent beings, but it's not intentional. Try not to be Evil. Strive to be Good...
mikepaul is offline
post #29 of 32 Old 01-04-2008, 02:01 PM
quest3300's Avatar
Im pretty new at this can someone tell me what to put in the output space?
quest3300 is offline
post #30 of 32 Old 02-17-2009, 10:13 AM
matt83's Avatar
I can convert my videos to MP4 fine, using GOTSent, but I cannot get MP4 playback in Media Center. I can play the videos just fine from my flashdrive, which is fine for TV shows, but for movies quite a bit larger than 2GB (the size of my flashdrive) playing them from the flashdrive isn't an option. When I connect the 360 to my Media Center PC I get the following error message:
"Files needed to display video are not installed or not working correctly. Please restart Windows Media Center or restart the computer"
Any idea what is wrong?
matt83 is offline
Reply Xbox Area
