HDMI to RCA sound? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-09-2008, 08:56 AM - Thread Starter
bidzer's Avatar
Quoted: 45 Post(s)
I'm using HDMI to M1 on my Infocus 7210 but I have no way of getting audio out to my headphones. Is there are switch box that has HDMI in from the 360 with RCA outs for headpone use?
I really don't want to use component out to get sond but it's looking that way. I don't have a HDMI capable receiver. Any help is appreciated.
bidzer is offline
post #2 of 4 Old 02-09-2008, 09:12 AM
FIVE ONE SIX's Avatar
i'm not familiar with your equipment, but the only way i would think that you can do it would be to either run the audio out (red/white) of your tv to a rca/mini adapter to your headphones, or do the same with the MS audio dongle that comes with the MS HDMI cable...
if you don't want to drop $50 on their cable, that's fine, spend $10 on the Monoprice VGA cable and modify that one, if you don't want to modify the component on you already have...
Xbox Live: KoNtRoL MaNiAk
FIVE ONE SIX is offline
post #3 of 4 Old 02-09-2008, 09:19 AM
257Tony's Avatar
He is using a PJ so that won't work. I think your stuck with either buying a new receiver (most expensive) buying the MS dongle (middle expensive) or hacking another cable (least expensive) The monoprice VGA cable would be a great option like FIVE ONE SIX said......
257Tony is offline
post #4 of 4 Old 02-09-2008, 09:44 AM
Valence01's Avatar
Or the MadCatz universal cable. That one will fit without removing or modifying the connector housing to coexist with the HDMI cable. Still need to do something to prevent the reboot issue though. Taping over the contacts for 26 and 28 would do it.
P.J.
Valence01 is offline
Reply Xbox Area
