Extending range of XBox 360 Wireless Controller - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 98 Old 12-11-2012, 01:06 PM
znelbok's Avatar
Thanks for this info
The petition has merit, even though our thoughts are probably correct, but it may prompt them to add the drivers ( or a similar solution) to the new box.
Mick
Illawarra Smart Home
The Integration Specialists
znelbok is offline
post #92 of 98 Old 04-03-2013, 06:50 AM
As1081's Avatar
Has anyone started the petition? With more and more people implementing a whole house A/V system with a centralized location for equipment, I don't understand why the Xbox wouldn't have the capability to extend range of the wireless controllers. Microsoft needs to provide the drivers within a software update so the USB receivers will also work with the XBox 360 directly. Look how old this thread is and still no solution...come on Microsoft, this is 2013, connectivity anywhere is expected!
As1081 is offline
post #93 of 98 Old 06-03-2013, 02:53 AM
disallowautoaim's Avatar
Hi guys,
I had the same problem but I finally got a solution. I am replying here because this seems to be the only place on the net that is still talking about this. Unfortunately this solution only works for the PC and not the Xbox 360
I have a PC that is hooked up to my TV in another room via a really long HDMI cable and others. The problem was that the wireless controller would cut out depending on where I was in the room. I tried first to go the route of the RJ45 to USB converter. Please save your money and don't do this! The wireless receiver for windows needs to be plugged into a USB port with less than 5m of USB or RJ45 cable, this is due to the limitations of USB power over (long) distances. The wireless receiver will power on but it will not link to the controller. Add to this the pain in the ass of the wireless drivers that come with this thing and you have yourself a fun weekend. mad.gif
Anyway, I bought a powered USB hub that is connected via a really long USB cable. I again plugged in the wireless receiver and still nothing. I reinstalled the drivers and finally this thing could control my PC from the front room. Now the thing about the drivers is that there is a specific, long-winded way of installing it... and you must do this every time you switch the wireless receiver to a new USB port. I can't find where I originally found this from but kudos to the guy who figured it out. Do these steps exactly as they are written and it will work.
Uninstall any drivers you've tried to install already - go to device manager and uninstall the driver for the "unknown device" (which is just uninstalling the device really, seeing there is no driver) and also uninstall any driver software through control panel. LEAVE THE DEVICE PLUGGED IN.
  • Restart PC.
  • Download and install the latest driver from the Microsoft Site.
  • Restart PC.
  • Go to device manager - you'll notice it still shows up as an unknown device. Right click on it and go Update Driver.
  • Click "Browse my vomputer for software".
  • Click "Let me pick from a list of drivers on my computer".
The list will take a while to load. Select Microsoft, then on the right, select Xbox Wireless Receiver for Windows (there might be multiple versions, go with what looks like the most recent one - mine was 2.1.0.1349) and click next. It will warn you about possible incompatibility, install it anyway.
It will ask you to restart. Do it.
Once restarted, go to device manager and you should notice a new slot - "Microsoft Common Controller for Windows Class", and under it, "Xbox 360 Wireless Receiver for Windows". Yay!
Now try pairing your controller with the receiver. Click the button on the receiver, then hold the big xbox button on the controller until it turns on and press the very small "connect" button on the forward side of the controller (the side with the triggers), while the receiver light is still flashing. Your controller light should spin for a fraction of a second and then Sync up and the first quadrant should stay lit. Yay! (if not, some people have had success by unplugging their USB devices and restarting and plugging in just the receiver first, then it syncs, then try their other USB devices again).
Anyway, that's how to extend the wireless range via USB cable & powered hub on the PC. Good luck.
disallowautoaim is offline
post #94 of 98 Old 10-12-2013, 12:09 PM
curttard's Avatar
Quoted: 136 Post(s)
Liked: 37
Why is the receiver on the 360 so terrible?
I can use the 360 wireless controller with the PC wireless receiver to control PC games from literally anywhere in the house. PC with receiver in the basement, and there are no problems at all using the wireless controller from the top floor of the house, i.e. with two floors between me and the PC.
But with the 360 itself, I can't even make it to the top of the basement stairs before I lose sync.
curttard is offline
post #95 of 98 Old 01-24-2014, 01:11 PM
Hollllow's Avatar
Hello, I know this thread is old but I am building a new house and all of my video / audio devices will be placed in one place. I will need to extend my USB up to 35 meters and I want to use the XBox 360 Wireless Controller with my PC. disallowautoaim - you said that the USB by Ethernet extender didn't work properly, but did you try to extend the USB and connect it to the powered USB hub and then connect the XBox 360 Wireless Controller adapter to the hub? Because I'm reading about the USB Ethernet extender and it sounds like it suppose to work.
Hollllow is offline
post #96 of 98 Old 01-27-2014, 03:12 AM
> But did you try to extend the USB and connect it to the powered USB hub and then connect the XBox 360 Wireless Controller adapter to the hub
Yup that is exactly what I did but I used a really long USB cable and not the USB/LAN converter
It may do, however it will be need to be connected to a USB powered hub in order to provide enough power to the wireless dongle. I don't know if the method I think you are suggesting works...(i.e. USB/LAN converter -> USB hub -> wireless dongle.... I just did the long USB cable -> USB hub -> wireless dongle) but please post back your results! Best of luck.
post #97 of 98 Old 01-28-2014, 06:28 AM
Hollllow's Avatar
Ok, when I will try that I post back. Thanks
Hollllow is offline
post #98 of 98 Old 09-27-2015, 09:34 AM
SRTpusher's Avatar
Depending on the needs it may be cheaper to buy a second system for multi-room. You can also play head to head in the same house with no screen peeking.
That's what I did
As for extending one unit, relocate the game system and use a wireless HDMI to send the signal to the rack.
SRTpusher is offline
Reply Xbox Area
