Huge decrease in XBox 360 noise for $1.99 - AVS Forum
post #1 of 45 Old 02-25-2008, 08:54 AM - Thread Starter
Shape's Avatar
Quoted: 21 Post(s)
Liked: 75
I put 4 little rubber feet under my 360 last week. I put them next to the existing rubber feet. Since I did that, the amount of noise from the DVD drive and fans has dropped by a ton! This should also increase the cooling ability by increasing the space between the 360 and the shelf it sits on.
I got the feet at Radio Shack. The mall stores don't carry them. But the ones in the plazas that sell more electronic stuff have them.
$1.99 for 12 of them.
http://www.radioshack.com/product/in...entPage=search
And since you don't open the box, there is no issue with the warranty.
Basically, the feet help to dampen the vibration of the 7000RPM DVD drive and fans, quieting the console a lot.
Josh - GamerTag: ShapeGSX PSN: ShapeGSX
'97 Eclipse GSX - 11.825@117.55mph in the 1/4
Shape is offline
post #2 of 45 Old 02-25-2008, 08:59 AM
e_e_emarpea's Avatar
i had some felt things laying around. they were kinda thin so i used like 2 or 3 of them. lol. they work, but these things are way nicer.
Gamertag: esaesid
PSN: fistfulofsteel
Xfire: thediseas3
e_e_emarpea is offline
post #3 of 45 Old 02-25-2008, 09:01 AM
cfmustang's Avatar
I did the same thing the day I got my 360, except I did it for cooling purposes and I got mine at Home Depot. I never even considered doing it to help quiet down the noise.
Since I have never run it without the feet, I can't say if it made a difference or not.
cfmustang is offline
post #4 of 45 Old 02-25-2008, 09:06 AM - Thread Starter
Shape's Avatar
Quoted: 21 Post(s)
Liked: 75
Someone on another forum tried it and he didn't notice a difference. So if you try it, beware that you might not notice a difference. But hey, at least you are only out $1.99 if you try it, right?
My 360 sits on a glass shelf on a very open TV stand. So the vibration of the DVD drive isn't dampened at all by the shelf.
Shape is offline
post #5 of 45 Old 02-25-2008, 09:06 AM
Replicant Nexus6's Avatar
Good stuff. Thanks, Shape.
Ill try finding them via the local route seeing as how they are trying to charge 6 bucks to ship to RI
Gamertag= Nexus976lives
PS3= Nexus976
Wii= Be serious, now....
Replicant Nexus6 is offline
post #6 of 45 Old 02-25-2008, 09:08 AM
bassmonkeee's Avatar
Heh. I thought you were going to say you taped over all of the air vents.
PSN/XBL: bassmonkeee
Wii number: Who cares?
bassmonkeee is offline
post #7 of 45 Old 02-25-2008, 09:21 AM
efjay's Avatar
Or maybe even throw it out completely, definitely no noise problem then!
efjay is offline
post #8 of 45 Old 02-25-2008, 09:37 AM
Max Lomax's Avatar
If you have a Middle Atlantic rack system, get the shelf and faceplate for the 360 it comes with some rubber feet which helps a lot as well.
Max Lomax is offline
post #9 of 45 Old 02-25-2008, 09:39 AM - Thread Starter
Shape's Avatar
Quoted: 21 Post(s)
Liked: 75
Radio Shacks that are in malls will probably not have these. They no longer stock parts in those stores.
But the ones in plazas do stock them.
You can also get something similar at Home Depot or Lowes, I'm sure. Any number of stores carry similar feet.
Shape is offline
post #10 of 45 Old 02-25-2008, 10:42 AM
DaGamePimp's Avatar
Quoted: 54 Post(s)
Liked: 170
I have had the little rubber feet on the bottom of all my 360's since purchase , only I use some that are about 1/2 inch thick ( and as I recall they came from Target ) . This does help with cooling (more air flow under the console) but it certainly can help the noise level as well if you have vibration from the drive/fans .
-- Jason
DaGamePimp is offline
post #11 of 45 Old 02-25-2008, 11:30 AM
maximuslcd's Avatar
I'm guessing since you only used 4 of them you have 8 left? sure I'll take em
I may try to pick some up for 2 bux you cant go wrong
xbox live GT: xXmaximus prime
PSN: maximus_rr
I have to go, I have a meeting with the bobs, uhhh I wasnt aware of any meeting......yeah they called me at home
maximuslcd is offline
post #12 of 45 Old 02-25-2008, 01:56 PM
ebackhus's Avatar
What about those cork door stoppers? They're often used to keep cabinet door from slamming and also creates an air gap. They're available at most home centers for s few bucks.
ebackhus is offline
post #13 of 45 Old 02-25-2008, 02:27 PM
kylebisme's Avatar
I suppose I'll have to try this, my 360 sits on a glass shelf and the DVD drive often sounds like it is chewing rocks.
kylebisme is offline
post #14 of 45 Old 02-25-2008, 03:12 PM
darklordjames's Avatar
Liked: 93
I've got fat rubber feet on all of my consoles to help reduce the vibration. It really does help with disc noise guys! The only one that I didn't add them to is the original Xbox. They got it right with that one as it already had fat rubber feet.
darklordjames is offline
post #15 of 45 Old 02-25-2008, 03:15 PM
KoRn's Avatar
I got these from RadioShack instead.
http://www.radioshack.com/product/in...entPage=family
They work way better than the ones you posted. The ones you posted I had also tried them before. These bigger ones lift the system higher allowing even more air flow and it being more quieter.
KoRn is offline
post #16 of 45 Old 02-25-2008, 04:30 PM
perpetual's Avatar
You guys might want to check out Home Depot as well. They sell rubber feet like those as well, and they have a larger selection.
360 gamertag------>Perpetual
PSN------->Perpetual1
perpetual is offline
post #17 of 45 Old 02-25-2008, 05:33 PM
newfmp3's Avatar
Quoted: 145 Post(s)
Liked: 158
monoprice.com 30 foot component or hdmi cables...noise gone.
newfmp3 is offline
post #18 of 45 Old 02-25-2008, 05:39 PM
FIVE ONE SIX's Avatar
the RS ones work really well, i use them for other things too, like on the base and tops of speakers stands and base of speakers if i have to put them on a table, they work much better than the cheesy felt pads that are supposed to do the same thing...
and like someone else said, even if it doesn't make it noticably quieter, it still does help it ventilate much better for only a few bucks...
Xbox Live: KoNtRoL MaNiAk
FIVE ONE SIX is offline
post #19 of 45 Old 02-25-2008, 07:13 PM
257Tony's Avatar
wut?
257Tony is offline
post #20 of 45 Old 02-25-2008, 07:20 PM
Chief Ediri's Avatar
Maybe you went deaf in one ear, decreasing the sound?
I don't know, but I seriously rubber helps a system to be less noisy.
Chief Ediri is offline
post #21 of 45 Old 02-25-2008, 07:24 PM - Thread Starter
Shape's Avatar
Quoted: 21 Post(s)
Liked: 75
Did you try it before criticizing it?
Tell you what, mount your car's exhaust to your car's unibody using metal brackets instead of the rubber isolators that are normally used. It isn't like rubber could help a system be less noisy.
Shape is offline
post #22 of 45 Old 02-25-2008, 07:34 PM
Morkeleb's Avatar
Originally Posted by 257Tony View Post
wut?
Turn your 360 on the walk 30 feet. Plus it might be in a closet.... or downstairs even better.
Disclaimer:
The words above are based on loose facts mixed with my opinion, the latter of which is subject to change.
Gamertag Morkaleb
PSN Archathema
Morkeleb is offline
post #23 of 45 Old 02-25-2008, 07:34 PM
newfmp3's Avatar
Quoted: 145 Post(s)
Liked: 158
wut?
lol.
I solved my noise issue with my 360 by getting 30 foot cables, sticking the darn thing in another room downstairs, and with the wonderful wireless controllers, I game up stairs....noise free.
newfmp3 is offline
post #24 of 45 Old 02-25-2008, 07:41 PM
Liked: 93
"I don't know, but I seriously rubber helps a system to be less noisy."
The 360's DVD drive spins rapidly, creating vibration. In the default configuration, that vibration is passed from the 360 to the surface that it sits on. Since most people use materials that are lighter than concrete or marble to place their components on, the surface amplifies the vibrationg noise of the 360. The rubber feet help to reduce the transfer of vibration to the resting surface, therefore reducing the amplification of the noise. The end result is less noise from the 360's drive.
Besides, you "seriously rubber"? What does that even mean?
post #25 of 45 Old 02-25-2008, 07:57 PM
Arcticfox400's Avatar
yeah then you can keep it in an deepfreeze in the basement, thats what i had to do when the fan in my obox died
GT: Arcticfox400
Currently playing Halo 3 and COD4
Arcticfox400 is offline
post #26 of 45 Old 02-25-2008, 08:25 PM
kylebisme's Avatar
So I got the little pads, still sounds like it is chewing rocks when it reads a disk, but it is quieter.
post #27 of 45 Old 02-25-2008, 10:19 PM
I will buy some this weekend then. I will be back with my results.
Also, I made a typing error. I meant to say that I don't think rubber will help it at all.
post #28 of 45 Old 02-26-2008, 05:51 AM
cap_167's Avatar
To the people who have purchased the rubber feet, do you guys have it set up vertically or horizontally and have you noticed any difference in noise because of the way it's sitting?
cap_167 is offline
post #29 of 45 Old 02-26-2008, 06:53 AM
Pretty funny. I know what you mean by "chewing rocks". Thats actually the sound of a bad drive. Mine would make that noise whenever it would spin up, spin down.
Sad to say it completely stopped reading discs. Had to get a replacement.
PS3= Nexus976
post #30 of 45 Old 02-26-2008, 07:28 AM
Vincent Kennedy's Avatar
I would if they had a shelf/faceplate that would hold my HD DVD drive on top of the Xbox 360 like I have it now. I do not want to use 5U of space for my Xbox! (3 for Xbox, 2 for HD DVD Drive)
If you cannot tell the difference between HD and SD on a large screen TV get your frackin' eyes checked!
XBox Live: Vinny516
Vincent Kennedy is offline
Reply Xbox Area
