PS3 to Macbook (or any other laptop) via bluetooth? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 03-28-2008, 05:40 PM - Thread Starter
liquidsense's Avatar
Is it possible to connect my Macbook Pro or IBM Thinkpad (or any other laptop for that matter) to my PS3 via Bluetooth, such that I can use the keyboard to type messages on the PS3?
I've tried scanning for devices on the PS3, but cannot seem to pick anything up. I am very new to the PS3, so, I'm not sure that I'm doing it right. (I haven't paired anything to the PS3 before).
liquidsense is offline
post #2 of 12 Old 03-28-2008, 06:56 PM
serversurfer's Avatar
That's a good idea, but I don't think it will work. I don't think there's any technical reason why it couldn't, but laptops just don't advertise themselves as input devices AFAIK.
PSN: serversurfer
serversurfer is offline
post #3 of 12 Old 03-28-2008, 08:08 PM
bobbyslav's Avatar
I tried pairing my PDA to use as a remote but no luck either
bobbyslav is offline
post #4 of 12 Old 03-28-2008, 11:34 PM
blklightning's Avatar
Quoted: 12 Post(s)
Liked: 64
is there a way to hook a ps3 up to the net through a laptop? i hate having to disconnect my laptop when i want to play cod4 online. i know i could buy a router, but if this could be done, it would be cheaper and more convenient. (download a lot of **** on my laptop, that's why it's inconvenient)
500 gigs FTL.
blklightning is offline
post #5 of 12 Old 03-29-2008, 02:03 AM
If you have a Mac, just go to SysPrefs->Sharing>Internet Sharing. Tell it to share your Internet from ethernet to computers using AirPort.
If you're using Windows, you might be able to install some software to do it, but I have no idea what that would be.
Edit: I'm assuming your PS3 has a wireless card.
PSN: serversurfer
post #6 of 12 Old 04-01-2008, 02:40 PM
Quoted: 12 Post(s)
Liked: 64
yep.
500 gigs FTL.
post #7 of 12 Old 04-01-2008, 04:12 PM
Protopet's Avatar
Would the wifi be secured? (WPA-2)?
Protopet is offline
post #8 of 12 Old 04-01-2008, 04:14 PM
The only security option is WEP, either 40- or 128-bit.
PSN: serversurfer
post #9 of 12 Old 04-01-2008, 04:19 PM
Protopet's Avatar
128-bit is best?
I could get this to work with my PS3?
Protopet is offline
post #10 of 12 Old 04-01-2008, 04:48 PM
It should work just fine, 128-bit is better, but I don't know if the PS3 supports that. (The online manual doesn't say, and my 20 GB doesn't have wireless, so I can't check it myself.)
So yeah, you can do it, but it will be "reasonably secure," instead of "very secure." IOW, it will keep out casual leechers, but if someone reallywants to get in to your network, and they know what they're doing and have the proper tools, they probably could.
Basically, 40-bit WEP should be fine, assuming you're not trying to safeguard plans for stealth bombers, etc.
PSN: serversurfer
post #11 of 12 Old 04-02-2008, 01:50 PM
mdv
mdv's Avatar
My 40G PS3 is using WPA-2.
Mark
mdv is offline
post #12 of 12 Old 04-02-2008, 02:06 PM
Sorry, I meant when you're setting up Internet Sharing on a Mac.
Macs can connect to WEP/WPA(Personal/Enterprise)/WPA2(Personal/Enterprise), but out of the box, they can only set up a WEP network.
PSN: serversurfer
Reply PlayStation Area
