PS3ToothFairy IR Retrofit/Assembly for PS3 Bluetooth Remotes - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 462 Old 06-11-2011, 05:40 PM
sclawrenc's Avatar
Hello, Just wondering if and when you might have the bare model in stock?
Sean
sclawrenc is offline
post #452 of 462 Old 07-03-2011, 08:22 PM - Thread Starter
aymanme's Avatar
Hi Sean, sorry I must have missed your post. They are there right now (in the store).
Ayman
aymanme is offline
post #453 of 462 Old 10-07-2011, 05:11 PM
yragha's Avatar
Questions:
Does this work with the URC-WR7?
And for me to get this working with that remote I would need a ps2 remote (learning) and the toothfairy?
yragha is offline
post #454 of 462 Old 10-08-2011, 02:27 PM - Thread Starter
aymanme's Avatar
Originally Posted by yragha View Post
Questions:
There is no reason it shouldn't work with the WR7. I am a URC user and the database in my remote was able to control the PS2 (and thus, the ps3toothfairy). Check to see if the WR7 includes the Playstation 2 controls. I did have to add the power off which is the same as a sony dvd discrete power off. So maybe you only need a way to transmit/learn the discrete power off.
aymanme is offline
post #455 of 462 Old 10-20-2011, 10:03 PM
davey_fl's Avatar
Seems liKe you're out of both models. Will they be in soon?
Thx
davey_fl is offline
post #456 of 462 Old 10-24-2011, 11:27 PM - Thread Starter
aymanme's Avatar
Hi davey_fl, yes, probably within 1-2 weeks. I have a small stock of them. PM me if you need one. I just redesigned the unit (first time since 2008) and that took a bit longer than I thought -- it will still run the same FSM so all the same commands, macros, programs will work.
aymanme is offline
post #457 of 462 Old 02-04-2012, 03:52 PM
rsumi's Avatar
Hello,
I have the RTI T3-V+ remote and purchased the PS3 tooth fairy but not sure how to bind it with my remote using the PS3 bind BD remote feature.
I can't press 2 buttons at the same time because its touch screen and I don't think I can re-assign the buttons to 2 real buttons on the controller and press them at the same time because the remote won't scramble 2 different signals to send at once to the infrared.
Has anyone done this or have any suggestions?
~ Rich!
rsumi is offline
post #458 of 462 Old 02-12-2012, 03:56 PM - Thread Starter
aymanme's Avatar
Hi rsumi, sorry I just saw your message. You don't have to press 2 buttons at the same time (in fact, IR remotes can't do that at all). The ps3tf takes care of "pressing 2 buttons" for you. You just need to tell it which 2 and there is a special sequence to do that. It is in the manual on the site. But basically, what you do is
1) Press and Release Angle
2) Press and Release the 1st button
3) Press and HOLD the 2nd button
So for instance, if the 2 buttons are start and enter, you would do:
2) Press and Release Start
3) Press and HOLD Enter
So long as you hold the 2nd button, it will transmit both for you. This is how you pair the device.
Best
Ayman
aymanme is offline
post #459 of 462 Old 07-13-2012, 04:15 PM
jeremybunn's Avatar
How do I do the initial pairing, if I am using IRule with an Global Cache iTach IP2IR and do not have a harmony remote?
jeremybunn is offline
post #460 of 462 Old 07-17-2012, 10:22 PM - Thread Starter
aymanme's Avatar
For reference in case somebody else has a similar system ... here is what I replied with:
I have never used the irule but I would assume you can either put in hex codes or you can choose the "ps2" or "ps3toothfairy" as a device. If so, just choose one of those and then follow the pairing instructions. Let me know if that doesn't work.
aymanme is offline
post #461 of 462 Old 04-28-2013, 10:56 AM - Thread Starter
aymanme's Avatar
Ok so it has been almost 4 years since the first one was made / shipped .... In that time the volumes have dropped (mainly due to the advent of $100 BD players) such that it does not make sense for me to make them anymore. That and I have a new job, moved my family, etc .....
I really appreciate everyone who bought these from us ... it was lots of fun. Now I am trying to figure out what to do with the design files. My hope is that I can show others what it takes to build something from design, build, mechanicals ... and perhaps inspire somebody to build something cool.
aymanme is offline
post #462 of 462 Old 09-15-2015, 04:42 PM
arantius's Avatar
What happened with this? Are the design files available anywhere? I'd love to see them.
arantius is offline
Reply PlayStation Area
