SOCOM U.S. Navy SEALs Confrontation Discussion - Page 65 - AVS Forum | Home Theater Discussions And Reviews
Old 12-22-2009, 08:29 AM
Dan C OSG's Avatar
Originally Posted by Auditor_Kevin View Post
Thanks for the reply.
Are there lots of people playing the hostage extraction mode?
definately enough to find them
PSN: onemoretry
add me fools
Dan C OSG is offline
Old 12-22-2009, 08:30 AM
clintz's Avatar
I ususally play the medleys, which is a random mix of game modes and maps
clintz is offline
Old 12-29-2009, 01:22 AM
Kingram's Avatar
Quoted: 101 Post(s)
Liked: 58
+1
Kingram is offline
Old 01-20-2010, 12:59 PM
clintz's Avatar
For those of you that still play but don't fully understand how the CE and specializations work, I found this very detailed post on some other forums..
Okay, now that we've played post-DLC, we have an understanding of the CE points awarded in this game.
If you don't know what this means, let me try to explain. In your "Armory", you can now pick a "Specialization", both a Primary weapon type and a Secondary weapon type. CHOOSE WISELY!!!! If you change either of your specializations, you will lose all your CE points!!! **The one exception** is if you swap your primary and secondary specializations, you will only lose half of your CE points.
CE points are used to unlock attachments, special weapons, and enhanced stats for your specialization. Keep reading!
Once you have your Primary and Secondary Specializations chosen, you will gain CE points by using those type of weapons. For every kill you get with your specialization, you will earn 2 CE points. For every assist, you will earn 1 CE point. You only gain CE points in RANKED rooms. At the end of the match, you will see how many CE points you have earned by looking in the upper-right corner of the screen, to the right of the MVP of the match.
CE points earned for your primary specialization does not apply toward your secondary, and vice versa. Meaning, if you earn all your primary points first, you will need to use your secondary weapon type to get CE points to unlock things for that weapon type.
As you gain points, you can see how many points you have earned *total* by looking under Statistics under "Records". This doesn't give you a breakdown of CE points awarded between Primary and Secondary, it only gives you a grand total. You can see your progress of unlocking things by going into Armory and looking at Specializations. As you gain CE points, an orange bar will fill up showing how far along you are.
Once you reach Gold/Silver Star, you will not collect any more CE points for that weapon type.
YOU CANNOT HAVE MORE THAN 1 UNLOCKABLE WEAPON AT A TIME!!! If you change your Primary after you unlock a weapon, you will lose CE points, as well as attachments, enhancements, and special weapon.
I'd like to keep this thread updated with the points breakdown for the milestones for both Primary and Secondary of each weapon.
I'll start, since I know what I have...
Primary
* Assault Rifle
1. 300 Points - Custom Front Grip (can be used on ALL assault rifles, both commando and mercenary)
2. 600 Points - ALICE (Camo HK36, enhanced stats over normal HK36, can be used on both sides)
3. 900 Points - Gold Star (trophy and enhanced assault rifle stats)
* SMG
1. 300 Points - Custom Silencer (can be used on ALL SMGs, both commando and mercenary)
2. 600 Points - MOTOKO (Camo F90, enhanced stats over normal F90, can be used on both sides)
3. 900 Points - Gold Star (trophy and enhanced SMG stats)
* Pistol
1. 50 Points - Blue Laser (can be used on ALL pistols, both commando and mercenary)
2. 100 Points - GLADYS (Gold DE .50, enhanced stats over normal DE .50, can be used on both sides)
3. 150 Points - Gold Star (trophy and enhanced pistol stats)
* Sniper Rifle
1. 200 Points - Custom Bi-pod (can be used on ALL sniper rifles, both commando and mercenary)
2. 400 Points - TILLY (Camo SR-25, enhanced stats over normal SR-25, can be used on both sides)
3. 600 Points - Gold Star (trophy and enhanced sniper rifle stats)
* Shotgun
1. 100 Points - Custom Front Grip (can be used on ALL shotguns, both commando and mercenary)
2. 200 Points - VERA (Camo USAS 12, enhanced stats over normal USAS 12, can be used on both sides)
3. 300 Points - Gold Star (trophy and enhanced shotgun stats)
* Machine Gun
1. 200 Points - Custom Scope (can be used on ALL machine guns, both commando and mercenary)
2. 400 Points - GLORIA (Camo MK .48, enhanced stats over normal MK .48, can be used on both sides)
3. 600 Points - Gold Star (trophy and enhanced machine gun stats)
Secondary
* Assault Rifle
2. 450 Points - Silver Star (trophy and enhanced assault rifle stats)
* SMG
1. 300 Points - Custom Silencer ( can be used on ALL SMGs, both commando and mercenary)
2. 450 Points - Silver Star (trophy and enhanced SMG stats)
* Pistol
2. 75 Points - Silver Star (trophy and enhanced pistol stats)
* Sniper Rifle
2. 300 Points - Silver Star (trophy and enhanced sniper rifle stats)
* Shotgun
2. 150 Points - Silver Star (trophy and enhanced shotgun stats)
* Machine Gun
2. 300 Points - Silver Star (trophy and enhanced machine gun stats)
CUSTOM ATTACHMENTS (Unlock #1)
Assault Rifles - Custom Camo Front Grip (Equips on ALL Assault Rifles).
SMGs - Custom Suppressor (Equips on All SMGs). Gives 2 bars quieter than standard suppressor.
Pistols - Custom Blue Laser (Equips on All Pistols). Gives 4 bars of accuracy to weapon.
Snipers - Custom Bipod (Equps on All Snipers).
Shotguns - Custom Camo Front Grip (Equips on ALL Shotguns).
Machine Guns - Custom Scope (Equips on All Machine Guns). Low scope with 4x & 10x zoom.
CUSTOM WEAPONS (Unlock #2)
Assault Rifles - "ALICE": A Gold HK36, better damage and range. Tends to give more headshots than normal(?).
SMGs - "MOTOKO": A Gold P90 with slightly better damage, weapon range and speed.
Pistols - "GLADYS": A Gold DE.50 with 1 additional bar of damage.
Sniper Rifles - "TILLY": A SR-25 with Snow camo. Has faster fire-rate, 1 bar more accuracy, 1 bar quieter.
Shotguns - "VERA": A USAS with more damage, higher firing rate and lower encumbrance.
Machine Guns - "GLORIA": A Silver Mk.48 with 1 more bar of damage and 1 more accuracy.
CLASSIFICATIONS
Depending on your configuration for weapon specialization classes your "Classification" will change. Classifications can be seen by going into a game room, highlighting a players name, and it will show their Primary and Secondary specialization, if they "starred" it, and their Classification name.
Juggler - Sniper / Assault or Assault / Sniper
Ninja - SMG / Sniper or Sniper / SMG
Duelist - Assault / Pistol or Pistol / Assault
Assassin - Pistol / Sniper or Sniper / Pistol
Split Decision - SMG / Assault or Assault / SMG
Short n Sweet - Pistol / SMG or SMG / Pistol
Cowboy - Pistol / Shotgun or Shotgun / Pistol
Watchman - Assault / Shotgun or Shotgun / Assault
Boomer - Machine Gun / Shotgun or Shotgun / Machine Gun
from http://osghubforum.com/viewtopic.php?p=2077
clintz is offline
Old 01-20-2010, 01:06 PM
CHAVAN30's Avatar
sounds cool but i never play in ranked rooms
**edit** i picked up an Alice in 1 game and wondered what the heck it was!
CHAVAN30 is offline
Old 01-20-2010, 01:07 PM
clintz's Avatar
I never did before they released the CE stuff, but honestly I prefer the ranked rooms now
clintz is offline
Old 04-16-2010, 07:49 AM
GRAVESY079's Avatar
CLASSIFICATIONS
Also
Trooper - Machine Gun / Assualt.
will see what else you are called with the MG and pistol, sniper, smg later
GRAVESY079 is offline
