PS3 + Sony STR-DG800 = Linear PCM? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-23-2008, 07:08 AM - Thread Starter
Nailzaz's Avatar
Hi Everyone,
I have a PS3 and a (http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDG800 and have read that the best way to hear BluRay DVD's is using Linear PCM (as opposed to DD/DTS set-up in the PS3).
The problem I think is that although my receiver has an input for HDMI for the DVD (PS3), it also requires an optical input - the HDMI's are just pass-thru's.
I don't believe I can hear the Dolby True HD with this receiver - is this correct? Sorry is this seems like a novice question and I hope I'm wrong.
Thanks for any advice.
Paul
Nailzaz is offline
post #2 of 5 Old 11-23-2008, 08:03 AM
tokerblue's Avatar
Quoted: 199 Post(s)
Liked: 174
You're correct, the receiver that you have is HDMI passthrough, meaning you need to use optical for the audio. Unfortunately, you need HDMI for Dolby TrueHD and DTS-MA HD. The best you'll get over optical is Dolby Digital or DTS.
Set your PS3 to bitstream.
tokerblue is online now
post #3 of 5 Old 11-23-2008, 08:12 AM - Thread Starter
Nailzaz's Avatar
Thank you for the quick reply and confirming what I thought. Unfortunately I cannot afford a new receiver right now.
Just curious, is there a noticable difference?
Thanks again.
Nailzaz is offline
post #4 of 5 Old 11-23-2008, 08:21 AM
tokerblue's Avatar
Quoted: 199 Post(s)
Liked: 174
- It depends on your speakers and setup. The lossless codecs usually have better clarity and dynamic range. I think there is a noticeable difference, but I have a lot of friends that have listened to my setup who haven't noticed any difference.
post #5 of 5 Old 11-23-2008, 09:49 AM
Lord_Zath's Avatar
Quoted: 112 Post(s)
Liked: 109
The largest difference I've seen is on the rear channels - they are far more "alive" than on normal tracks.
Holding the fort on old games that play the same as the new ones, minus the $400 price tag.
Lord_Zath is offline
Reply PlayStation Area
