Running PS3 through an Onkyo Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-29-2008, 01:22 PM - Thread Starter
isu1648's Avatar
I am currently running my PS3 via HDMI through my Onkyo TX-SR805 receiver. My guess is many people on here are running through an Onkyo. Like everyone else, via the HDMI, it sends the audio through Linear PCM. This gets the TrueHD and DTS-MA of the Blu-rays to the receiver.
My questions is this...
What DSP/Listening mode's are best used with these? It seems not all are available for each disc. For the most part i've used the ProLogicII Movie setting, but the manual indicates that the prologic is best for converting a 2-channel signal to a 5.1/7.1, so is it beneficial to use with something that is already 5.1?
What is the consensus on best DSP's to use for both Dolby TrueHD and DTS-MA sources?
isu1648 is offline
post #2 of 13 Old 11-29-2008, 01:48 PM
zetram's Avatar
The best thing to do is just try out each one on the same scene in a movie and on the same section on a game.
Sound is very objective so what sounds good to mebon my 705 may not sound so good to you
I use the thx 5.1 btw
PSN: Zetram00
MGO: Tez $$
zetram is offline
post #3 of 13 Old 11-29-2008, 02:21 PM
iamkoza's Avatar
for true hd and dts MA you shouldn't need any processing, the PS3 sends it via LPCM to the receiver, as long as your receiver says multichannel HMDI, you are set. you can confirm while watching a blu-ray by hitting select to see what audio the ps3 is sending... most blu-rays default to the hi-def sound provided your system can handle it. Although uncompressed PCM tracks tend to default to DD5.1 (at least my expereince)
iamkoza is offline
post #4 of 13 Old 11-29-2008, 02:53 PM
zetram's Avatar
you do need processing if you have more than a 5.1 set up, for matrixing.
PSN: Zetram00
MGO: Tez $$
zetram is offline
post #5 of 13 Old 11-29-2008, 04:34 PM - Thread Starter
isu1648's Avatar
yeah, forgot to mention, I am running it on a 7.1 system, and i know that some of the DSP's matrix to the 7.1 from a 5.1 track.
isu1648 is offline
post #6 of 13 Old 11-29-2008, 07:42 PM
zetram's Avatar
You may be better served in the Receiver forum. I think most 7.1 owner use the PL IIx.
PSN: Zetram00
MGO: Tez $$
zetram is offline
post #7 of 13 Old 11-29-2008, 11:17 PM
thebigdaddye's Avatar
if you using some kind of processing on your onkyo like prologicII or dsp then your not hearing loss less audio/ true HD /dts ma. on your receiver it should say multi channel and you should be able to hit the select button on you ps3 and see what audio is being sent to you receiver up in the right corner next to what the video format is. the audio part should say truehd, lpcm you will know the difference when you have it set correctly. also on the receiver if you hold down the diplay button on the receiver gives you some info as well
thebigdaddye is offline
post #8 of 13 Old 11-30-2008, 12:48 AM
ten7ryder's Avatar
if you have a 7.1 setup, try using THX Ultra2 Cinema. this and Dolby PLIIx is what i usually prefer when watching blurays.
ten7ryder is offline
post #9 of 13 Old 11-30-2008, 11:53 AM
jasonstiller's Avatar
PLIIx is the real deal. Thats what ive used since I bought my reciever 11 months ago. Great matrixing and great bass response imo. Ill have to try the THX Ultra2 though.
jasonstiller is offline
post #10 of 13 Old 11-30-2008, 01:03 PM
257Tony's Avatar
That isn't quite correct. Lots of newer AVRs will accept lossless tracks in 5.1 and be able to matrix them into 7.1, the onkyo 805 is one of them. I use my PS3 through my Onkyo 606 and use PLIIx for all the movies that have 5.1 tracks. When playing a BR disc with a native 7.1 track, the receiver should default to "direct" or "multi channel" which is exactly what you want, since no extra processing is needed. Also don't forget that some movies require you to manually select the lossless track in the menu, some will default to the legacy soundtrack.
257Tony is offline
post #11 of 13 Old 11-30-2008, 02:14 PM
andydumi's Avatar
This for 5.1 signal or less. If I receive LPCM then I put it on multichannel rather than direct, it sounds better.
andydumi is offline
post #12 of 13 Old 12-02-2008, 05:01 AM
b00tleg's Avatar
I just recently finished installing the onkyo ht-s1700 home theater in a box which comes with the onkyo 606 receiver. After hooking everything up I tried a few blu-rays and noticed the ps3 wasn't reporting that it was outputting in hd audio. Come to find out, I needed to go into the ps3 sound settings and enable all of the audio formats that I hadn't been able to use before upgrading to the onkyo receiver. You might try that if you haven't already.
b00tleg is offline
post #13 of 13 Old 12-02-2008, 07:05 AM
redbill's Avatar
I have the 705 and I use the "Pure" mode, I think its the same as "direct" but it turns the display off. I'm only 5.1 though, so no need to matrix.
redbill is offline
Reply PlayStation Area
