Help: MY PS3 won't take the disk in.... Disk drive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 12-15-2008, 02:43 PM - Thread Starter
MColeman's Avatar
My 60GB PS3 won't take the disk into the drive. You can push it in, but it won't pull it in. it's out of warrenty.
Anyone know what I can do to fix this? Do I need to buy an entire drive?
MColeman is offline
post #2 of 16 Old 12-15-2008, 02:49 PM
bdwright77's Avatar
it just sounds like the retracting arm of the PS3 is busted. will it eject properly?
bdwright77 is offline
post #3 of 16 Old 12-15-2008, 02:50 PM
KingShorty's Avatar
Call Sony... that's the best you can do buddy.
KingShorty is offline
post #4 of 16 Old 12-15-2008, 02:52 PM
kekborg's Avatar
My 60gig did the exact same thing in the summer...it fixed itself...I swear, it did if or a couple of days and then just started working fine again.
kekborg is offline
post #5 of 16 Old 12-15-2008, 02:53 PM - Thread Starter
MColeman's Avatar
It seesm to eject just fine....
I bet sony is going to want big $ to fix this...
MColeman is offline
post #6 of 16 Old 12-15-2008, 02:54 PM - Thread Starter
MColeman's Avatar
Good to hear.
MColeman is offline
post #7 of 16 Old 12-15-2008, 03:04 PM
bdwright77's Avatar
Hopefully not, but it may be their flat rate $149 fee. Maybe it just fixes itself like Kekborg's, but you never know.
post #8 of 16 Old 12-15-2008, 03:07 PM
BMLocal175's Avatar
Quoted: 22 Post(s)
Stick a butter knife in there... maybe you can jar something loose.
BMLocal175 is offline
post #9 of 16 Old 12-15-2008, 03:08 PM - Thread Starter
MColeman's Avatar
I'll make sure it's plugged in when I try this move.
MColeman is offline
post #10 of 16 Old 12-15-2008, 03:10 PM
steven975's Avatar
considering the most you can get is a +12V shock just leave it plugged in.
steven975 is offline
post #11 of 16 Old 12-15-2008, 03:58 PM
kekborg's Avatar
Good to hear.
http://www.avsforum.com/avs-vb/showt...ht=disc+sucker
Above is the thread I started when I had the issue. Looks like it was spring time when it hit (as opposed to summer). Like I said, it acted this way for a while (maybe it was longer then a couple of days) and then just started working fine again . After that episode, I have had no problems
kekborg is offline
post #12 of 16 Old 12-15-2008, 04:20 PM
KingShorty's Avatar
Don't trust Kek, he'll tell you one thing and then he'll wait til you turn around and then shoot you in the back of your head with a knife while you're looking!
post #13 of 16 Old 12-15-2008, 05:40 PM
kekborg's Avatar
Assuming he has eyes in the back of his head
kekborg is offline
post #14 of 16 Old 12-16-2008, 04:39 AM
PursuitGT's Avatar
Press eject, It wont go in because theres already a disk inside......
Just kidding im sure you have already thought of that, I hope!
PursuitGT is offline
post #15 of 16 Old 12-16-2008, 08:13 AM - Thread Starter
MColeman's Avatar
It was the first thing I thought of. But thanks anyway. Sometimes we miss the obvious.
MColeman is offline
post #16 of 16 Old 12-18-2008, 07:32 AM
Brandon B's Avatar
Quoted: 66 Post(s)
Liked: 45
Not to mention assuming you have the odd knack of being able to shoot someone with a knife.
Brandon B is offline
Reply PlayStation Area
