External HD vs Flash Drive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-21-2008, 09:11 AM - Thread Starter
rr330i's Avatar
Really just for music/photo storage and the occasional small home vid.
I was thinking of a 16g flash or a bigger USB HD.
Which would be better, quicker... or am i better just using the internal HD?
rr330i is offline
post #2 of 11 Old 12-21-2008, 10:02 AM
steven975's Avatar
Any one would be fine, really. The drive would hold more. Speed is a non-issue.
steven975 is offline
post #3 of 11 Old 12-21-2008, 01:07 PM - Thread Starter
rr330i's Avatar
thanks...
i just checked and i have 60g of memory left on the internal.
i have 2g of pictures, and 10g of music to move over... so i'd have plenty of extra space on the hd. I'll check out external pricing this week.
Do any of these external sources need special formatting?
rr330i is offline
post #4 of 11 Old 12-21-2008, 02:55 PM
steven975's Avatar
They need to be formatted FAT32.
You have to jump through some hoops to format a disk that way in XP and Vista, but most externals come pre-formatted as FAT32, though.
post #5 of 11 Old 12-21-2008, 06:28 PM
KingShorty's Avatar
for small files and movies, a flash drive would do just fine.
I have a 4gb flash drive that I use to move my TV shows from my pc to the ps3 and it works just nicely. I copy them over to the ps3 and delete them from the flash drive. I also delete the files of the ps3 when I'm done watching them.
KingShorty is offline
post #6 of 11 Old 12-21-2008, 08:37 PM
Martez's Avatar
Wouldn't it just be simpler to stream the files from your PC with TVersity (or something similar)?
PSN: Tezasaurus
Martez is offline
post #7 of 11 Old 12-21-2008, 09:25 PM
glum's Avatar
i have a 60gig external drive and an 8gig usb flash drive and use both with the ps3. i find the usb drive a little easier given that some external hard drives (like mine) need to have external power to work with the ps3.
glum is offline
post #8 of 11 Old 12-21-2008, 09:47 PM
Stryf3's Avatar
I have a 750GB external WD that I use to store HD content on. It's way cool having all of the HD movies on there to watch without ever inserting a disk!
I just made you up to hurt myself....
Stryf3 is offline
post #9 of 11 Old 12-22-2008, 02:32 AM
KingShorty's Avatar
It probably would be, but I'd still have to move around the files on the PC... so it really comes up to the same thing for me.
Don't want to add anymore clutter to my router.
post #10 of 11 Old 12-22-2008, 10:04 AM - Thread Starter
rr330i's Avatar
I have null river and streaming, but i've been having issues with the network dropping out. Very annoying and embarassing.
Would be nice to have it all at the PS3.
I'm not liking the way the PS3 stores the music, unless i'm not doing it right.
I want it sorted via Artist > Album > Songs.
I should be able to do this w/ the external. It seems the PS3 just has separate albums.
rr330i is offline
post #11 of 11 Old 12-22-2008, 12:01 PM
KingShorty's Avatar
The PS3's way of sorting music is horrendous. You can get it to sort via Artist, then it'll show all the songs by album but you won't get to see them in your nice folders.
Reply PlayStation Area
