Help with setting up ps3 in Windows Media Center! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-25-2009, 07:08 AM - Thread Starter
tabascov's Avatar
Ok, So I spent hours last night trying to set up my windows media center and my ps3. The PS3 is hooked up to the internet, and my computer is, I just cant get the computer to locate the ps3. I used windows media player to set it up (under library, then sharing), and I cant get it to find the ps3.
any thoughts??
I dont even have my firewall turned on, so it cant be an issue with that.
tabascov is offline
post #2 of 8 Old 02-25-2009, 07:11 AM
Mobius_570's Avatar
Which OS on your PC are you running? And do you have UPnP enabled? Is Media Streaming option enabled ont he Ps3 side under settings?
This link may help also.
http://www.neogaf.com/forum/showthread.php?t=158357
PSN: Mobius570
XBL: Mobius570
Wii: Some silly number I can't locate
TWW
My Gaming Rig
Mobius_570 is offline
post #3 of 8 Old 02-25-2009, 07:34 AM
Shape's Avatar
Quoted: 67 Post(s)
Liked: 88
I made a thread in the XBox section on how to fix common Media Player streaming issues:
http://www.avsforum.com/avs-vb/showthread.php?t=802391
It applies to the PS3, too.
Josh - GamerTag: ShapeGSX PSN: ShapeGSX
'97 Eclipse GSX - 11.825@117.55mph in the 1/4
Shape is offline
post #4 of 8 Old 02-25-2009, 11:50 AM
Bryan_P's Avatar
I tried for hours one night to get WMP to successfully stream to the PS3 to no avail. After about 3 hours I downloaded the PS3 Media Server and was up and running a few minutes later.
Bryan_P is offline
post #5 of 8 Old 02-25-2009, 01:10 PM
Nox
Nox's Avatar
Windows Media Center isn't compatible with the PS3, but media sharing through Windows Media Player 11 is. Check out this guide to help you set it up (there's even a video how-to for reference):
PS3 and Windows Media Player 11 Media
-David
Nox is offline
post #6 of 8 Old 03-29-2009, 09:34 AM
BVfan's Avatar
Originally Posted by Nox View Post
Windows Media Center isn't compatible with the PS3, but media sharing through Windows Media Player 11 is. [/url]
Maybe somone should tell Kim Kommando... From her column in our Sunday paper
"You may already have everything you need to stream video to your television.
The Xbox 360 (from $200) streams content from Windows Media Center. Sign up for Xbox Live Gold ($50 annually) to access Netflix movies.
A better option is the PlayStation 3 ($400). It also works with Windows Media Center. A built-in Web browser lets you view any online content."
I thought maybe something had changed so I came to the forum to get the real story. I guess I should know the newspaper is full of disinformation all the time.
BVfan is offline
post #7 of 8 Old 03-29-2009, 09:49 AM
boblinds's Avatar
Liked: 35
Forget Windows Media Server entirely and use PS3 Media Server:
http://ps3mediaserver.blogspot.com/
boblinds is offline
post #8 of 8 Old 03-29-2009, 09:52 AM
Shape's Avatar
Quoted: 67 Post(s)
Liked: 88
She's wrong.
Shape is offline
Reply PlayStation Area
