Any tip's on repairing scratched Blu-ray's? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 03-11-2009, 07:44 AM - Thread Starter
HDTVblues3's Avatar
Does anyone have any recommendations for repairing my MGS4 disc. It fell off my desk last year and I didn't notice until I stepped on it. It has very noticeable surface damage.
Since the way the BD discs are manufactured, I am hesitant to try the Brasso fix (after experimenting on Lunar [RIP]) until I'm sure it won't cause some kinda major defect or something.
I don't want to use a skip dr since the last disc I've tried it on, Lunar PS1, both wheels just seemed to cause more scratches, and the rubber from the wheel leaves a foggy smudge. Like the quality of the product has gone down or something.
btw - It wasn't on the floor until now, it's just that I just remembered about it.
HDTVblues3 is offline
post #2 of 19 Old 03-11-2009, 08:29 AM
Goatse's Avatar
Quoted: 68 Post(s)
Liked: 51
didn't know that blurays could get scratched. Never got a single rental with visible marks yet. I don't think there is any real way to repair the coating.
Goatse is offline
post #3 of 19 Old 03-11-2009, 08:48 AM
Dan C OSG's Avatar
+1
I have tired ot scratch them. finger nail no good, ground no good. IT took a 3" screw with a load of pressure.
PSN: onemoretry
add me fools
Dan C OSG is offline
post #4 of 19 Old 03-11-2009, 08:59 AM
RoguishClyde's Avatar
Try to use a micro-fiber cloth and buff it real good; that should work; most Blu-ray scratches are illusions. If that doesn't work; I would try some disk skip fixer stuff. Basicly it's liquid plastic that dries like car wax. Once crusted over; buff residue away and problem should be solved; I got this stuff from Gamestop it's like $7-$8 for a bottle but a little goes along ways. Good luck!
PSN Network: RoguishClyde
Dark Souls; I LOVE YOU!!!!
RoguishClyde is offline
post #5 of 19 Old 03-11-2009, 09:16 AM
Kingram's Avatar
Quoted: 101 Post(s)
Liked: 58
I have had a few game disc's (xbox,360)resurfaced at gamecrazy's ($2)and have all worked great but haven't tried Blu Ray.
Kingram is offline
post #6 of 19 Old 03-11-2009, 09:50 AM
NJ3118's Avatar
Originally Posted by Dan C OSG View Post
+1
I hope this was a blank BD?!?
I have a fever and the only cure is more Blu-Ray....
NJ3118 is offline
post #7 of 19 Old 03-11-2009, 11:05 AM
mproper's Avatar
+1
-7 (for every Blu-Ray I've got from NF that has been scratched to the point of skipping). Well, 3 of those were cracked, not scratched, which is really the fault of the post office machines, I believe. So -4 for the scratched ones. Of course, the data layer is shallower, so even though they are harder to scratch (due to the hardcoating) it doesn't take as bad of a scratch to cause problems.
I'm pretty sure people use NF discs as dog toys (i.e. Frisbees for a game of fetch). Can't believe you guys haven't seen a scratched one. Of course, it's still not as bad as the DVDs are/were.
I have no idea how to repair them though.
mproper is offline
post #8 of 19 Old 03-11-2009, 11:17 AM
jremy510's Avatar
You must have really bad luck. I've received a few scratched DVDs with Netflix, but all the BRs are pristine.
jremy510 is offline
post #9 of 19 Old 03-11-2009, 11:21 AM
mproper's Avatar
It's probably those no good hippie teens who keep walking on my lawn
I watch a LOT of movies, so 7 bad discs out of the couple hundred Blu-Rays I've probably watched over the last couple of years is really not that bad.
mproper is offline
post #10 of 19 Old 03-11-2009, 12:20 PM
jayoldschool's Avatar
Quoted: 12 Post(s)
Car wax. Works wonders on scratched discs. I use CanFlix (Canadian NetFlix), so I get lots of scratched up stuff. I keep a bottle of car wax and a cloth in my media cabinet.
If you REALLY want the best, use Meguiar's plastic polish/scratch remover. Available at car parts places in the detail section.
jayoldschool is offline
post #11 of 19 Old 03-11-2009, 12:40 PM
imdjenk's Avatar
There are numerous unethical solutions to your problem but I will not post them as I do not condone such activity... anymore.
*coughrebuynewfromgamestopwithinsurancereplacebadcopywithnew andreplacewithanothergameatwalmartcough*
*cough* *phlegm*
Excuse me, allergies.
"You went full ******, man. Never go full ******."
om [NOM] nom
imdjenk is offline
post #12 of 19 Old 03-11-2009, 01:59 PM
WiseGuy2k7's Avatar
Funny thing I did the exact same thing for HD DVD from canflix.. worked very well. Damn canflix always had problems wit scratched discs, i usually used the polish on dem b4 attempting to watch the disc.
PSN:The_Wise_Guy
XBL:DirtySanWiseGuy
Steam:The_Wise_Guy
BF4 PC:The_Wise_Guy
WiseGuy2k7 is offline
post #13 of 19 Old 03-11-2009, 02:24 PM
gooki's Avatar
The big issue is BD uses a substantially different coating than DVD, CD, HDDVD and nearly every other type of optical disc ever made. It's also sufficiently different to clear coat paints used on cars etc.
I'd go with the micro fiber cloth suggestion. And if that doesn't work, do want you want, but I'd hazard a guess the only economical way to fix it is to have it replaced.
International HDDVD Screenshot Archive (Full 1080p Images): www.hdmovies.co.nz
gooki is offline
post #14 of 19 Old 03-13-2009, 12:10 PM - Thread Starter
HDTVblues3's Avatar
Thank you all for your responses. I tried quoting more but I'm new @ quoting on forums.
Yeah, I dropped Uncharted and Casino Royale a couple times handling them too delicately and they were fine
That's like with the disc buffers. I'm not ready for that kind of technique yet on a BD. But I'd be willing to try on a cd or dvd.
*cough* *phlegm*
Whoa, sorry I didn't get that. You, okay?
Here try some of this
That's why I was handling Uncharted so lightly. It feels so soft on the sides, I'm afarid of damaging them even tho i know they can handle a little more abuse.
post #15 of 19 Old 03-13-2009, 12:19 PM - Thread Starter
HDTVblues3's Avatar
The scratches are there unfortunately. I think a chair might have slid over it at least once. I can feel them and when you look at them it's kinda scary considering it's MGS4 CE.
I'm gonna think on some of your suggestions. I'll either buff it with a chemical, or take it to GameStop (if they're safe).
My Lunar disc (guinea-pig) was attempted with Brasso Creamy. So, now I'm gonna re-try with Braso original.
I'm gonna try and get a pic of the MGS4 disc.
post #16 of 19 Old 03-14-2009, 01:38 PM
BuckoNZ's Avatar
Quoted: 28 Post(s)
I too thought blu-ray were supposed to be more robust in the "scratching" dept. However, I find that many movies I get from a rental service here in NZ - although there doesn't appear to be that much scratching - seem to skip. Probably 1 in 4 would do this?
Television: LG SUPER UHD 4K TV 55'' [55UH850T] / Receiver: DENON AVR-X2300W / Blu-Ray Player: OPPO UDP-203
Main Speakers: KLIPSCH KG 2.5 / Centre Speaker: KLIPSCH KV 1
Surround Speakers (x4): CAMBRIDGE AUDIO Minx 22 / Sub-Woofer: ENERGY XL-S8
BuckoNZ is offline
post #17 of 19 Old 03-14-2009, 02:23 PM
iamkoza's Avatar
I've gotten a few dud blu-rays from NF, I blame the post office as they love to cram my mail into the box.
iamkoza is offline
post #18 of 19 Old 03-14-2009, 02:29 PM
moepoker's Avatar
Quoted: 302 Post(s)
Liked: 115
Get a bigger mail box.
PSN ID= moepoker
XBL ID= moepoker
moepoker is offline
post #19 of 19 Old 04-22-2013, 05:25 AM
TotalDiscRepair's Avatar
Blu-ray is more susceptible to damage, because the data layer is only covered by a thin protective layer. The protective layer is scratch resistant, but not scratch proof.
If a light-medium scratch occurs, it can usually be repaired because scratches often range between 5-20µm deep.
The protective layer is about 100µm thick, and many disc repair machines polish the surface away at a rate of 1-5µm/min.
This means that most Blu-ray can be repaired in a matter of minutes on a compatible machine (which is most of them). Plus, several repairs can be made before the protective layer is too thin.
When it can't be repaired:
* A really deep scratch that has damaged the data layer.
* If the disc is cracked.
* When the protective layer is already too thin from several previous repairs.
* If the repair machine is not compatible.
There many stores out there with disc repair machines capable of repairing Blu-ray - you just need to ask your local gaming, music or video store, or search for Disc Repair Listings.
If you looking to buy such a machine, you just need to search for a Disc Repair Machine - the manufacturer will tell you if it is Blu-ray compatible.
Although some people claim to have success with manual cleaning using gentle abrasives, if the damage is anything other than very light, you will not be able to get a consist level of repair and generally either make the damage no better, or possibly worse. There's a good reason why stores spend good money on professional machines - because they know manual methods and cheap machines don't do the job fully.
TotalDiscRepair is offline
Reply PlayStation Area
