Rock Band 2 A/V PS3 (using HDMI and surround receiver), driving me nuts! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 05-13-2009, 10:35 AM - Thread Starter
PublicSectorTech's Avatar
I'm not sure where to put this thread but I will start with the Playstation area since I'm having problems with the PS3. Recently I got a new surround receiver (Onkyo TX-SR507) and so I moved the PS3 from component to HDMI. The PS3 goes through the surround receiver and from there, the video goes to the TV and the audio goes out to the speakers (obviously). I have the "Dolby Digital" option checked on Rock Band 2.
Now here's the problem-audio and video are waaay out of sync. Rock Band 2 has an internal program that's supposed to fix it, but it doesn't come close. I'm trying to do it manually but I'm not having much luck. Is anyone having this same issue using the PS3 with a surround receiver? BTW, my TV is a Sony XS955 analog CRT HDTV, and I'm using its HDMI input for video. Let me know if you were able to fix this annoying problem.
Twitter: Gizzmonic
PSN: Gizzmonic
PublicSectorTech is offline
post #2 of 17 Old 05-13-2009, 11:05 AM
TornadoTJ's Avatar
Quoted: 1717 Post(s)
Liked: 539
common problem that's been discussed here many, many times. Turn off Dolby Digital.
TornadoTJ is offline
post #3 of 17 Old 05-13-2009, 11:48 AM
mystik610's Avatar
Also try adjusting the audio/video sync on your Onkyo receiver. I think its under the hardware menu, but I'm not sure (at work right now and dont have access to my 606).
mystik610 is offline
post #4 of 17 Old 05-13-2009, 03:30 PM
odd-props's Avatar
additional processing causes lag.
analog out has the least amount of lag.
odd-props is offline
post #5 of 17 Old 05-15-2009, 08:07 AM - Thread Starter
Damn, that means my AV setup is gonna be more complicated. Do you know if there's a way to trick the PS3 into outputting component and HDMI at the same time. I'd hate to have to rejigger stuff every time I wanted to watch a movie.
Twitter: Gizzmonic
PSN: Gizzmonic
post #6 of 17 Old 05-15-2009, 08:29 AM
TornadoTJ's Avatar
Liked: 539
There is not a way to do that. Simply uncheck the Dolby Digital setting in Rock Band. That'll get you 95% of the way there, and will not cause you to need to make any cabling changes.
post #7 of 17 Old 05-15-2009, 09:36 AM
bdwright77's Avatar
Don't you lose some of the vocals / volume levels when unchecking DD on a 5.1+ system? I remember not getting anything out of my center channel when this was done.
bdwright77 is offline
post #8 of 17 Old 05-15-2009, 09:38 AM
TornadoTJ's Avatar
Liked: 539
Nope. The only bit change is that the crowd won't be as distinct in the rear channels. Won't make any difference in the actual gameplay though, other than the lag, especially in the vocals, will be gone.
post #9 of 17 Old 05-15-2009, 10:11 AM - Thread Starter
That's good enough for me, I'll give it a try!
I wonder why they even included that option if it was going to cause such problems!
Twitter: Gizzmonic
PSN: Gizzmonic
post #10 of 17 Old 09-08-2009, 03:54 PM
kikgon's Avatar
Does the audio quality suffer if you take off the Dolby?
kikgon is offline
post #11 of 17 Old 09-09-2009, 12:22 PM
TornadoTJ's Avatar
Liked: 539
Nope, just what he said right above your post.
post #12 of 17 Old 09-09-2009, 06:56 PM
funsocaltiger's Avatar
This is a super old post but I believe this is possible now with firmware 3.0.
funsocaltiger is offline
post #13 of 17 Old 10-23-2009, 11:29 AM
treepop's Avatar
I am considering getting an Denon avr-590 over my Denon avr-1709, due to the ability to have audio over HDMI.
Would audio over HDMI correct this problem? vs Audio over optical? or does the problem stem from something else?
treepop is offline
post #14 of 17 Old 10-23-2009, 01:46 PM
TornadoTJ's Avatar
Liked: 539
The lag issue is still going to occur. It doesn't matter about the connection, etc. The solution is simply turn off Dolby Digital within the game. It does NOT affect any other game, movie, etc.
post #15 of 17 Old 10-23-2009, 03:06 PM
treepop's Avatar
thats so weird
is this only on Denon's or on all receivers....if so....WHY OFFER IT!?
I like the audience around me I FEEL LIKE A STAR!!!!!!!!!!, but seriously I do like it
treepop is offline
post #16 of 17 Old 10-23-2009, 04:44 PM
dogdoctor's Avatar
Originally Posted by treepop View Post
thats so weird
It affects all AVRs not just Denon. But you need to learn how to manipulate the sound in the AVR to your liking. Turn off the DD and send stereo. Then on the AVR select either 5 channel stereo/dolby prologic and the AVR will redirect the sound to the surrounds as well. You won't get nearly the same clarity with the extrapolated dolby prologic as you would from a discrete DD 5.1 signal, but hey it's it better than nothing without the lag. If you send 5 channel stereo you will hear the exact same sound out of all the speakers, rather than with dolby prologic trying to calculate what should be coming out where.
Now don't let that stop you from going up to the new line of receivers. Audio over HDMI is just plain nice, no matter how you slice it. Have the new AVR and a new Slim just opens more doors of possibilities.
PSN ID: dogdoctor
dogdoctor is offline
post #17 of 17 Old 10-23-2009, 05:37 PM
tingham's Avatar
Quoted: 62 Post(s)
Liked: 31
I don't have any lag when playing in DD mode. I wonder why some people have this problem? Maybe it's a LCD issue? I play on a plasma, and I usually don't play in the DD mode. In my setup, 2 channel actually sounds better using the Dolby PLIIx or DTS Neo6 surround modes on my Denon.
Go Phillies! Go Eagles! Go Sixers! Go Flyers!
tingham is offline
Reply PlayStation Area
