Connecting a PS3 to a XPS one PC - AVS Forum | Home Theater Discussions And Reviews
Old 09-04-2009, 04:19 PM - Thread Starter
Larhalt's Avatar
The computer had a DVI to A/V adapter i think it was, so i connected the ps3 to it but couldnt get it working.. the pc didnt register any external device connected..
is there a way to connect it to the XPS ONE via hdmi or A/V?
thanks any help will be appreciated
EDIT:Sorry for the confusion, this is the adapter im trying to use:
http://support.dell.com/support/edoc...YU285am0MR.pdf
do you think it could work with the PS3 A/V cables? i tried but i think i forgot to change the ps3 resolution since i was using hdmi with my tv..
Larhalt is offline
Old 09-04-2009, 04:40 PM
PvtChurch's Avatar
First of all what is it you're trying to do exactly? Second, please define A/V. DVI doesn't carry audio signals so whatever you're referring to A/V as is wrong since that stands for Audio/Video. Do you mean VGA? Component? Composite? What type of DVI connection does your computer have? DVI-A? DVI-D? DVI-I?
Always remember: The pessimist is never disappointed.
PvtChurch is offline
Old 09-04-2009, 04:48 PM
steven975's Avatar
well, no computer available to consumers has a DVI or HDMI input that is compliant with HDCP (encryption), which the PS3 puts out full time.
You can only connect it to a TV card via composite video (the yellow/white/red). that's it.
You might be able to use a PC monitor...if it supports HDCP and 1280*720 or 1920*1080 resolution.
steven975 is offline
Old 09-04-2009, 04:52 PM - Thread Starter
Larhalt's Avatar
sorry my bad i mean vga to a/v.. but im not sure since the output was rounded with like 5 pins.. it was not shaped like a rectangle like vga input suppose to be so i dont really know what kind of input was it... the pc had an adapter to connect the audio video cables to it.. so i did and could not get the ps3 display to work on the monitor
EDIT: this is the pc im talking about
http://www.dell.com/us/en/home/deskt...ne&cs=19&s=dhs
here you can see how it looked from the back
http://www.dell.com/content/products...IwI3JlZ2lvbg==
i think the adapter went in the 10 pin connector for hdtv input devices.. then i connected the a/v cables to it
Larhalt is offline
Old 09-04-2009, 05:54 PM
eddy_winds's Avatar
Try this:
http://www.youtube.com/watch?v=-LGyGBJIf5Q
My mom works for Sony, and she brought home a copy of "Starhawk BETA"
I quickly slipped it into my trusty PS3, and started playing.
GOOZEX Game/Movie Exchange
eddy_winds is offline
Old 09-04-2009, 06:23 PM
bdoyledimou's Avatar
So your PC has a proprietary 10 pin HDTV input, that attaches to some sort of dongle that you "should" be able to attach your PS3 too...
BUT the cable that ships with the XPS only supports S-Video, or composite RCA inputs.. so you will have to contact Dell and get a Component or an HDMI dongle (if it even has one).
Then you haev to open the "TV" app and select that input..
No, the monitor does NOT act like a TV and have multiple input modes.
PSN: Wrassle
360: Burnt of Wrassl
bdoyledimou is offline
Old 09-04-2009, 06:29 PM - Thread Starter
Larhalt's Avatar
this is the adapter im trying to use with my ps3 a/v cables:
thanks for the input guys and sorry for the confusion...
i think maybe i forgot to reset my ps3 resolution since i was using hdmi cables with my tv.. but i wont be able to try again until tomorrow...
so do you guys think its possible with that adapter? and maybe i just did something wrong?
Larhalt is offline
Old 09-04-2009, 06:50 PM
steven975's Avatar
yea, it's possible with that adapter. But it will only support 480i resolution. It will look like crap.
Old 09-04-2009, 06:54 PM - Thread Starter
Larhalt's Avatar
yeah i know itll be standard definition and itll suck compared to hdmi with an hdtv but cant use anything else ATM.
good to hear thanks.. i think the problem was i forgot to reset the resolution on my ps3.. silly me.
Larhalt is offline
Old 09-04-2009, 07:00 PM
PvtChurch's Avatar
I'm still not entirely sure what it is you're trying to do? It sounds like you want to stream media from your PC to your PS3 but that wouldn't require connecting a video cable between the PC and the PS3. If that's not what you're doing then I can only assume you're trying to use a laptop monitor as a screen for your PS3 which isn't actually possible unless you're running through a capture card.
Old 09-04-2009, 07:05 PM - Thread Starter
Larhalt's Avatar
no, im not trying to use it to stream media.. im trying to use the PC monitor to dispay the ps3.. im trying to do it with the adapter i linked.. its not a laptop its an all in one desktop PC..
Larhalt is offline
PvtChurch..
He is trying to use his Dell XPS 24 ALL IN ONE (a pc and monitor in one unit) as a monitor/display for his PS3.
It has a Video in breakout box, but it only supports component and/or s-video (not HDMI even though it is refered to as a HD Component Input).
PSN: Wrassle
Old 09-04-2009, 07:08 PM - Thread Starter
Larhalt's Avatar
Originally Posted by bdoyledimou View Post
PvtChurch..
yeah this^^^.. i wasnt sure if it was possible cuz i failed when i tried.. but im trying to remember if i changed the ps3 resolution when i tried which i think i didnt..
Larhalt is offline
Old 09-04-2009, 07:27 PM
PvtChurch's Avatar
Oooo ok. Well that makes a lot more sense. If I recall correctly isn't there a way to reset the PS3's settings on startup (something like hold the power button for 5 seconds) and it will reset the output resolution to 480i. That would probably fix your problem if you think the video output setting are incorrect for this monitor.
Old 09-04-2009, 08:46 PM - Thread Starter
Larhalt's Avatar
yeah thats want im gonna do thanks^^^.. hope that fixes the issue..
Larhalt is offline
