mkv2vob for PS3 help - thank - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-02-2009, 04:51 PM - Thread Starter
Jon SS's Avatar
I am using mkv2vob to change mkv container to watch on my ps3 and wanted to use a usb to transfer the files.
I converted the file in automatic modes and it created a mpg file, I then copied the file onto a usb stick (into a VIDEO directory). When i put the USB stick in my PS3 the file did not come up under video (the directory was recognized but it said not files). Basically the PS3 could not see the converted mpg file. All worked fine when I converted the file again to avchd-usb format and copied the directory to usb and put the usb into my ps3 so I know the file can be played.
Can somebody tell me what I am doing wrong. I really want to be able to transfer a bunch of files to my PS3 hard drive and not have to watch via USB each time.
HT Room: Marantz AV7005 (replaced Parasound Halo C2), Parasound Halo A51 & A23, Monitor Audio GR60, GR Centre, GR10, GRFX, ASW210, Pioneer Elite PRO-141FD, PS3 & PS4, Pioneer Elite DV59avi.
Family Room: Yamaha RX-A2060, PSB Imagine T2, Imagine Centre, Monitor Audio MA700, Oppo Digital BDP-80, Sony KDL-55HX701
Jon SS is offline
post #2 of 5 Old 10-02-2009, 08:26 PM
randy5554's Avatar
Did you try pressing the triangle button when selecting the USB stick? Press triangle, then select "display all". Then highlight the video, hit triangle, and select copy.
randy5554 is offline
post #3 of 5 Old 10-03-2009, 12:54 AM
jbdawson's Avatar
Quoted: 37 Post(s)
You've got to make sure the usb stick is formatted to Fat32 and not NTFS before adding anything to it or the PS3 won't read
it.
jbdawson is offline
post #4 of 5 Old 10-03-2009, 05:28 AM - Thread Starter
Jon SS's Avatar
Turned out to a compatibility issue with the memory stick, it was not working with a Sandisk but worked with a Kingston USB.
Jon SS is offline
post #5 of 5 Old 03-30-2012, 12:39 AM
WannaKnowTech's Avatar
Quoted: 12 Post(s)
Hello im also having a problem. Lately when I convert the files, the last 3 to 10 minutes get cut off. Anyone know why?
WannaKnowTech is offline
Reply PlayStation Area
