Is there a ps3 remote that will work on the pc? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-07-2009, 07:22 AM - Thread Starter
spinksjinx's Avatar
I am using the Hulu desktop app and would like to get a remote, I have the ps3 bluetooth remote but I was thinking one of the usb ones likes the Nyko Blu-Wave would work. Any comments or suggestions?
spinksjinx is offline
post #2 of 3 Old 11-08-2009, 08:55 PM
dstarlin's Avatar
There is an app that will allow you to use the Bluetooth remote from the PS3 on the computer. It will emulate keystrokes. It is by a guy named Ben Barron, you may be able to find it on a web search. If you can't, PM me.
Dave
dstarlin is offline
post #3 of 3 Old 11-09-2009, 08:14 AM
jwpmol's Avatar
I use my logitech Harmony 1000 with ps3 converter on my ps3 and HTPC.
For PC uses I've partially set up the remote as Microsoft MCE Keyboard
jwpmol is offline
Reply PlayStation Area
