100' cat 6 extension cable PS3 eye - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 07-12-2010, 12:12 PM - Thread Starter
sathyakamaraj's Avatar
Simple question: I guess its a right place to post..
Question is Can I connect PS3 eye with MonopriceUSB extender with 100' Cat 6 cable back to Ps3.
I hope it will work - if not whats the solution to connect the PS3 Eye to PS3 (located inside the closet)
Live till die
sathyakamaraj is offline
post #2 of 15 Old 07-12-2010, 12:44 PM
Greg_R's Avatar
I would suggest a powered Cat5e solution like this one. I have not had much luck with passive extenders. Given the price difference, it may be worth trying the passive solution and returning it if it doesn't work as advertised.
Greg_R is offline
post #3 of 15 Old 07-13-2010, 11:43 AM
General Custer's Avatar
Quoted: 13 Post(s)
Just finished running the cat 6 and setting up the mono price USB over Ethernet adaptor. It doesn't work with the eye. It's only USB 1 compatible. Stay away.
General Custer is offline
post #4 of 15 Old 07-14-2010, 10:39 AM - Thread Starter
thanks for the heads up
...so i need to look for USB2.0 or 3.0 extender?
Live till die
post #5 of 15 Old 07-14-2010, 07:56 PM
gtp-ftw's Avatar
good to know, that was my plan since my ps3 is hidden in a closet, hopefully someone finds a solution or its no ps3 move for me
gtp-ftw is offline
post #6 of 15 Old 09-28-2010, 12:41 AM
gtp-ftw's Avatar
bump^^
anyone find a solution? i would like to pickup move but my tv is a good 30 feet from my ps3.. and i cant run any new cables.. have several spare cat5 runs, behind it, i was hoping to find some sort of usb/ethernet extension that would work
gtp-ftw is offline
post #7 of 15 Old 09-28-2010, 01:17 AM
mhdiab's Avatar
Quoted: 60 Post(s)
Liked: 39
Look in the move thread. Can't link as I am on the iPhone. Last post had a good link. Alternative is active repeaters USB cable - monoprice has them 2.0 compliant
mhdiab is offline
post #8 of 15 Old 10-10-2010, 07:21 PM
jevehn's Avatar
For anyone looking for a good extension, I've had good luck with the monoprice 32' active 2.0 extension.
jevehn is offline
post #9 of 15 Old 10-14-2010, 12:06 AM
gtp-ftw's Avatar
looks good, too bad i have no way of fishing that through my finished walls
i really need a cat5/usb extension of some sort since i have several spare cat5 runs in the wall..
gtp-ftw is offline
post #10 of 15 Old 11-01-2010, 02:12 PM
rplenty's Avatar
#6149 33FT 10M USB 2.0 A Male to A Female Active Extension / Repeater Cable $10.20
Available at Monoprice.com I have used it on my PS3 to connect eye camera to PS3 USB port. Works perfectly as a 33' extension. I am using it with the Move controller games.
rplenty is offline
post #11 of 15 Old 11-02-2010, 07:45 PM
mcmushx15's Avatar
Agreed, the USB over CAT5/6 does not work. I used the active repeater and it works great. You can daisy chain the active repeaters.
mcmushx15 is offline
post #12 of 15 Old 11-29-2010, 08:08 AM
bigman69's Avatar
guys,
my PS3 is in an a/v closet about 20 feet away from my tv. Just ordered the Move bundle today.
Also ordered the 33ft USB extender from Monoprice. From those of you who have used it, do you notice any lag (or any other problems)?
It seems like one reviewer on Amazon who was using a similar cable, about 33ft, but from a different manufacturer, may have been noticing some lag. But his review seems kind of stupid, so maybe he's just crazy.
I'm sure you guys would notice lag, etc. with the Monoprice cable, right?
I want this to work so bad....please tell me its perfect....
THanks!!!!!!!!!!!
bigman69 is offline
post #13 of 15 Old 11-30-2010, 07:23 PM
Evan E's Avatar
Quoted: 107 Post(s)
Liked: 103
Speed of propagation in coaxial cable is generally about 65% to 80% of the speed of light. You'd have to have a reeeally long cable to notice any lag.
Evan E is online now
post #14 of 15 Old 12-01-2010, 11:42 AM
bigman69's Avatar
why is there a supposed 15ft limitation on USB cables then? Apparently runs longer than that suffer from dropouts and lag.
At least that's what I've been hearing...
bigman69 is offline
post #15 of 15 Old 12-01-2010, 12:07 PM
G-Bull's Avatar
It's because the copper wire inside the cable isn't 100% efficient, and it acts as a resistor. And the longer the cable, the more resistance. Resistance doesn't slow the data down, but it reduces it (some of the electrical energy is lost to heat). So the signal could be degraded enough that the devices cannot communicate properly.
G-Bull is offline
Reply PlayStation Area
