PS3 Games on YCbCr - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-27-2010, 09:00 PM - Thread Starter
JoseQ's Avatar
This may be a simple question, but I can't find where there may be a solution.
I need to set my PS3 to YCbCr for games. I know how to set it for video and it plays them fine, but the menus and games are not shown properly. I'm not too interested in BTB or WTW, I just want to have regular color (everything looks green in my screen).
My screen is a SIM2 HT300E projector, so the settings are very limited on that end. It actually displays them fine if I connect the PS3 directly to the projector, but I need to go through my receiver (Onkyo HT-RC180) to get sound. Likewise if I connect the output of the receiver to a monitor, it also displays everything fine. So there must be some miscommunication when going through the Onkyo to the SIM2 where it detects the display as being something it's not.
Is there any way to force YCbCr output for the games?
I have tried all possible combinations (I think) for the RGB Full Range / Super-White / etc. settings. I've tried other cables. I've tried everything I can think of.
Any help is appreciated.
JoseQ
http://www.tailormadeservers.com
Dedicated Servers for Every Need
JoseQ is offline
post #2 of 5 Old 12-27-2010, 10:32 PM
mcmushx15's Avatar
if everything is green, you may have your green and blue crossed. make sure you got the right connections set up and that on the ps3 end, its fully pushed in!
mcmushx15 is offline
post #3 of 5 Old 12-27-2010, 10:39 PM
HDTVblues3's Avatar
Do you have the manual?
Pge. 18:
The default settings are:
NATIVE (the machine's native primary colours)
HDTV, EBU, SMPTE-C, primary colours defined by the standards
AUTO, mode that applies one the standard settings described above
Would that help?
HDTVblues3 is offline
post #4 of 5 Old 12-27-2010, 10:53 PM
HDTVblues3's Avatar
Originally Posted by mcmushx15 View Post
What he said
Yeah, check for this first since it happens with all my RGB connections at least once.
post #5 of 5 Old 12-28-2010, 12:03 AM - Thread Starter
JoseQ's Avatar
I'm actually using an HDMI cable, not Component output.
JoseQ is offline
Reply PlayStation Area
