Can't connect PS3 to the Internet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-29-2011, 08:56 AM - Thread Starter
Penske5150's Avatar
My PS3 can't even get an IP address. My cable modem runs into a "5 Port 10/100 Switch", from there to my PC and to my PS3. I've tried a couple of things like power cycling the modem and turning off media streaming on the PS3. Still the same thing, can't get an IP address.
Any other options besides replacing the "5 port 10/100 Switch" with a regular router?
Penske5150 is offline
post #2 of 6 Old 01-29-2011, 09:02 AM
soutthpaw's Avatar
Quoted: 12 Post(s)
did you try connecting directly to the modem
DJ
Vischeck Color deficiency goodies: 8.5% of the human population
soutthpaw is offline
post #3 of 6 Old 01-29-2011, 09:20 AM - Thread Starter
Penske5150's Avatar
I just did and it connected no problem. So should I get a router?
post #4 of 6 Old 01-29-2011, 09:26 AM
HawaiianHDaddict's Avatar
If you're going to have more than one device connected to your modem then you need a router to assign internal IP addresses to all of your devices.
HawaiianHDaddict is offline
post #5 of 6 Old 01-29-2011, 09:30 AM - Thread Starter
Penske5150's Avatar
I had a suspicion, but wanted more informed opinions than my own. Thanks for the advice.
post #6 of 6 Old 01-29-2011, 11:58 AM - Thread Starter
Penske5150's Avatar
Got the router and everything is working perfectly, worked for my netflix enabled blu-ray player as well.
Reply PlayStation Area
