How to transfer HD movies on flash drive to PS3? - AVS Forum | Home Theater Discussions And Reviews
Old 02-26-2011, 10:35 PM - Thread Starter
yellowboy06's Avatar
Hi, I recently got a 32 GB flash drive and downloaded some movies and converted them to work with the PS3.
I made a folder on the flash drive called "PS3" then inside of that, a folder called "VIDEOS" like you are supposed to but, when I put the flash drive into my PS3 no flash drive shows up under the video section?
My one concern is that when I tried to put the 22 GB HD movie on to the flash drive it said that it was too large and I soon found out that-that was because the flash drive was originally FAT32, and with FAT32's you can only add 4GB MAX at a time. So I formatted the drive to NTFS and then the movie was able to be put on the flash drive. But then it didn't sow up like I told you?
Anybody know what to do?
yellowboy06 is offline
Old 02-26-2011, 11:17 PM
zervinb's Avatar
The PS3 will not recognize your NTFS-formatted flash drive. It has to be formatted to FAT32 for it to be recognized. This is a limitation of using USB drives on the PS3. If you wish, you could transfer the file over a wired/wireless network instead of using the USB drive.
zervinb is offline
Old 02-27-2011, 08:49 AM
steven975's Avatar
if you need to format a drive in Windows to FAT32, you'll need to do it via command line if you want anything bigger than a preset limit.
make a shortcut to CMD. Run it as an administrator. "format n: /fs:fat32" where n is the drive letter of the drive you want to format.
steven975 is offline
Old 02-28-2011, 07:34 AM
RemoWilliams84's Avatar
Quoted: 56 Post(s)
Liked: 300
They are right. It will have to be formatted to Fat32. You'll also have to break that HD movie into 4 gig chunks to go on the Fat32 drive. Sounds like you'd be better off streaming to your ps3 using ps3 media server or tversity or something.
Xbox Gamertag/PSN ID: RemoWilliams84
"I started out with nothing, and I still got most of it." -Seasick Steve
RemoWilliams84 is offline
Old 03-01-2011, 09:30 AM
Justin-Dawson's Avatar
If you don't want to stream and your PS3 has a big enough hard drive, you can also just copy the file to your PS3 through your network (from your computer not a USB drive).
I myself hate streaming from my computer since it requires me to wire a connection to my PS3 for HD movies (wireless doesn't cut it for me). To get around it I bought a network drive that streams through DLNA. I put all my movies on there and it then shows up as a media server on my PS3. The best part is that it has a gigabit wired connection to my gigabit router which is also wired to my PS3... which is also gigabit. Works great and I think you can get nework drives for like $150 now... mine was 220 like 2 years ago.
Justin-Dawson is offline
