MW3 - Assault, Support or Specialist? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-27-2011, 11:01 PM - Thread Starter
toofarzong's Avatar
What do you guys use most? I was excited to see IW implement these options. I feel it definitely helps with campers. I've always been a run and gun type of guy, so as of recently I've been using the Support Package. I'm way too antsy to camp and wait for the chain kills on the Assault Package. And I'm so glad they softened the power of the tuber weapons. I don't see the newb tubes nearly as much.
toofarzong is offline
post #2 of 6 Old 12-28-2011, 09:39 AM
malvado78's Avatar
Lots of talk here...
http://www.avsforum.com/avs-vb/showthread.php?t=1368795
malvado78 is offline
post #3 of 6 Old 01-01-2012, 11:53 AM
blklightning's Avatar
Quoted: 12 Post(s)
Liked: 64
there's a whole thread dedicated to that crap game.
500 gigs FTL.
blklightning is offline
post #4 of 6 Old 01-01-2012, 03:11 PM
NJ3118's Avatar
I use Assault now but from level 1-50 I used support.
I have a fever and the only cure is more Blu-Ray....
NJ3118 is offline
post #5 of 6 Old 01-02-2012, 04:20 AM
crippldogg's Avatar
Quoted: 37 Post(s)
Liked: 47
Been using assault more now just doing 3,5,7. Use support quite a bit when I play demolition and specialist once in a while
The Weekend Warriors
crippldogg is offline
post #6 of 6 Old 01-05-2012, 10:08 AM
xiaphin's Avatar
Support if you run and gun whole time and throw grenades everywhere like I do. Hardline Pro is a must
xiaphin is offline
Reply PlayStation Area
