PS1/PS2 game Original Soundtracks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-07-2012, 11:48 AM - Thread Starter
shoopdopp's Avatar
For those that own any and have listened to them on high-quality speaker setups, do any game OSTs from the PS1/PS2 era sound higher in quality than the in-game music itself?
I'm not talking about ones with certain tracks that were altered or remixed/remastered for the OST, but tracks that are essentially the same as the in-game tracks. Since the stored in-game audio back then was likely compressed in a Lossy manner, I'm wondering if some soundtracks could get 'unlocked' somehow when they're recorded to Lossless Stereo CDs.
shoopdopp is offline
post #2 of 6 Old 01-07-2012, 01:50 PM
darklordjames's Avatar
Liked: 94
PS1 was still using FM synth for the most part, so it was pretty much a MIDI track telling the audio hardware what to play back in real time. The CD is basically just a recording of that.
PS2 tended to use pre-recorded music compressed down to low/mid-bitrate MP3/MP2 or an equivalent. Yes, a CD recording of that could be better, or it could just be a recording of the already lossy MP3. It depends on which source the CD originated. For the most part though, there are very few non-Xenosaga/non-Square games that had soundtracks worth a damn on the PS2.
darklordjames is offline
post #3 of 6 Old 01-07-2012, 03:06 PM
TyrantII's Avatar
Liked: 833
Not always so on PS3. Several games used CD audio, although I'm not sure on the bitrates/quality. In the same format no less, you could pop them into a CD player and play them like a normal audio CD.
TyrantII is offline
post #4 of 6 Old 01-08-2012, 07:58 AM - Thread Starter
shoopdopp's Avatar
Thanks for info. As far as the PS2 goes, OSTs from Square/Xenosaga stuff are precisely ones that I was interested in.
darklordjames, in your opinion do you think Squaresoft/Enix would have just made their OSTs using the compressed in-game tracks as the source, or would they have taken a step further and went with their originally recorded sources for the in-game tracks?
Also, do you own any PS2 OSTs and an okay audio system where you may be able to tell a difference?
post #5 of 6 Old 01-08-2012, 08:43 AM
Liked: 94
Square soundtracks tend to be of great quality. Human ears suck though.
post #6 of 6 Old 01-08-2012, 08:48 AM
TyrantII's Avatar
Liked: 833
One way to check would be using a program called Spectro to see if there's any frequency cut off, as is typical with lossy compression. But that would require having the audio CD's.
TyrantII is offline
Reply PlayStation Area
