PS3 and updates - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-24-2012, 06:22 PM - Thread Starter
BIGGGDADDY72's Avatar
Does anyone know if its possible for ps3 to get an update to allow 3d depth adjustment,or if you have heard anything about an update that will allow this.
BIGGGDADDY72 is offline
post #2 of 3 Old 01-25-2012, 01:43 AM
bdoyledimou's Avatar
i think that is adjusted by teh "screen size" slider. I have a 120 inch projector screen, but spent a few hours experimenting and found that i got the best effect @ 88 inches. (larger or smaller provided a shimmer or hollow effect)
Some games (such as Socom 4) have a depth effect meter though.
PSN: Wrassle
360: Burnt of Wrassl
bdoyledimou is offline
post #3 of 3 Old 01-25-2012, 10:53 PM
aymanme's Avatar
I don't think there is anything in the regular software for the "3d effect" level. There is a slider in deblob 2. I usually play on 6-8 and not really sure I notice the difference between the 3. I'd like to find a way for it to keep my settings, it is annoying to go into the options menu and monkey with the game settings every time I want to play.
aymanme is offline
Reply PlayStation Area
