HDMI audio connection issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-21-2012, 11:48 AM - Thread Starter
msyost's Avatar
My PS3 is connected to my Onkyo TX-SR673 via HDMI. When I initially connect the cables and turn the systems on, everything works fine. Then when I switch the source on my receiver over to my HTPC, then back to the PS3, I lose audio and am not able to get it back. Has anyone had this issue and know if its a PS3 problem or rather a receiver problem? Thanks.
msyost is offline
post #2 of 7 Old 02-21-2012, 11:49 AM
TornadoTJ's Avatar
Quoted: 345 Post(s)
Liked: 126
Sure sounds like a receiver issue to me. Weren't the Onkyo notorious for losing the HDMI sections?
TornadoTJ is offline
post #3 of 7 Old 02-21-2012, 11:53 AM - Thread Starter
msyost's Avatar
Perhaps. I've been searching but havent found info on this particular issue.
msyost is offline
post #4 of 7 Old 02-21-2012, 12:05 PM
CNPalmer's Avatar
Do you lose audio from both devices, your HTPC & the PS3?
Anyway to switch from your HTPC with audio running to the PS3 and see if you lose audio in that "direction"?
CNPalmer is offline
post #5 of 7 Old 02-21-2012, 12:13 PM - Thread Starter
msyost's Avatar
Audio always returns to the HTPC, the PS3 is only affected by switching.
msyost is offline
post #6 of 7 Old 02-21-2012, 12:16 PM - Thread Starter
msyost's Avatar
Btw I am using brand new hdmi 1.4 cables which did not solve the problem.
msyost is offline
post #7 of 7 Old 02-21-2012, 02:15 PM
TornadoTJ's Avatar
Quoted: 345 Post(s)
Liked: 126
Switch the inputs around, plug the HTPC into the port you have the PS3 in, and vice versa. See what happens.
Reply PlayStation Area
