Why are original fat PS3's so Expensive? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 04-02-2012, 04:56 PM - Thread Starter
RonF's Avatar
Quoted: 257 Post(s)
Liked: 258
I guess I have been under a rock. Bought 80gb original PS3 about 4 years ago for around $400. The hard drive has gotten corrupted somehow, can't save any new photos from the wallpaper type scenic sites any more. Always says "file is corrupted.
I'm not a computer savvy person, though I imagine changing out the hard drive with another one and doing whatever is not hard. How much approximately to send to Sony to have them do? Where do you send. Should I just do that and keep this one?
I thought I would check with Amazon and see what new ones were going for and got this range of prices below. Why are the old ones so expensive now?? Do you give something up with the new slim versions? Not an avid gamer though I have thrown a few on over the years. I like the Bluray drive and the photo section of the PS3 for projection display and demo lists.
http://www.amazon.com/Consoles-Hardw...&node=14210711
RonF is online now
post #2 of 16 Old 04-02-2012, 05:07 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
changing out your hard drive involves 6 screws and 5 minutes of your time. it's as easy as easy gets. If you can run a blender, change the channel on your TV, you can replace a ps3's hard drive : http://www.youtube.com/watch?v=-B1mQ21XXLE
any 2.5 inch hard drive will work in the ps3. Get a 5400 rpm drive and you're done.
N8DOGG is offline
post #3 of 16 Old 04-02-2012, 05:09 PM
joeblow's Avatar
Liked: 233
The new ones are quieter, cooler, and would take care of all of your listed needs. As far as negatives go for getting a modern Slim unit, the main difference is that you lose the ability to play most PS2 games by not having an original model.
However, if a corrupt HDD is your only issue, they are easily replaced as mentioned above.
Los Angeles Lakers - 16 NBA Championships!
joeblow is offline
post #4 of 16 Old 04-02-2012, 06:04 PM
tgable's Avatar
Quoted: 17 Post(s)
Liked: 78
Supply?
All the old models are expensive new, they are not made. The original had 100% BC, which is still valued, but used they are not worth much due to being a time bomb.
Now playing: Bloodborne
Recently Finished: The Order: 1886, Dying Light
PSN & XBL: Scuzzlebutt33
tgable is offline
post #5 of 16 Old 04-02-2012, 06:26 PM
Threefiddie's Avatar
Quoted: 247 Post(s)
Liked: 121
my release day fatty is still chugging along.
** FOR SALE-Price reduced**Sony HW50ES + extra bulb + 5 pairs 3d glasses + Chief Mount **Click me**
Threefiddie is offline
post #6 of 16 Old 04-02-2012, 06:53 PM
TyrantII's Avatar
Liked: 833
My guess is those high price ones are factory sealed, brand new, never opened.
Or they're just people trying to scam the lazy and unwitting.
resale Phat prices have dropped considerably in the last year, both on ebay and trade in value. They're also dropping like flies. I wouldn't purchase one, especially for 500-800.
TyrantII is offline
post #7 of 16 Old 04-02-2012, 07:06 PM - Thread Starter
RonF's Avatar
Quoted: 257 Post(s)
Liked: 258
OK yeah....thanks I guess I could handle that. Is there any reformatting or anything else needing to be done with PS3 menu and remote once the drive is installed? How's the hard drive situation these days? I heard Frys had none a few weeks back still due to the flood. What size do you recommend and brand?
Thanks a bunch!!!
RonF is online now
post #8 of 16 Old 04-02-2012, 07:38 PM
confidenceman's Avatar
Liked: 37
All depends on what you use it for. If it's just for gaming, you don't need all that much space. If you use it to store/play media, you probably want a bit more. I've had a 320g for the past 4 years and haven't even passed the halfway point. I use it for game saves, game data, and downloadable games. As for brand, go with a major brand. None is especially more reliable than any another IMO.
PSN & XBL ID: drop me a private message
confidenceman is offline
post #9 of 16 Old 04-03-2012, 06:13 PM
zBuff's Avatar
Liked: 38
The older models are also sort after for their SACD playing and ripping abilities
zBuff is offline
post #10 of 16 Old 04-03-2012, 06:17 PM
pokekevin's Avatar
Liked: 102
Simple. Sacd ripping capabilities
pokekevin is offline
post #11 of 16 Old 04-04-2012, 11:32 AM
djb5f's Avatar
Quoted: 139 Post(s)
Liked: 68
Just be careful not to strip the screws, I did on two of them (easily strippable) but was able to eventually get the hard drive pried free from the case.
djb5f is offline
post #12 of 16 Old 04-04-2012, 12:29 PM
jbug's Avatar
Quoted: 248 Post(s)
Liked: 127
When I had my fatty, I wasn't into SACD but just after it died I got into SACD (lol).
jbug is offline
post #13 of 16 Old 04-04-2012, 12:33 PM
mcclayton's Avatar
Quoted: 114 Post(s)
After having 2 60gb models die on me. I don't get it.
mcclayton is offline
post #14 of 16 Old 04-04-2012, 03:02 PM
Liked: 37
The folks buying them at this point probably know their way around the inside of a PS3 and can fix/replace broken stuff themselves.
post #15 of 16 Old 04-14-2012, 10:09 PM - Thread Starter
RonF's Avatar
Quoted: 257 Post(s)
Liked: 258
OM freaking G.....I have to vent. My fault but just have to vent.
So thanks to the advice given here above, I went to Frys and picked up a 500gb drive for $90 and put it in. Then I sat with my fast Mac Pro and cycled 20 times faster through the one web site that took me hours and hours and hours with the slow wireless cycling and pop ups etc with the PS3 over a couple years to save some great 16x9 scenics to the photo section. I found most of them again and saved to my hard drive on the Mac and then copied to a flash drive.
So I fire up the PS3, format the new drive and everything seems to be working OK. Did a firmware upgrade. Then copied one by one in pretty quick fashion the photos and then had to again go through them on the PS3 to save them to a play list so I could go through all of the group continuously in my theater with the projector, uninterrupted with the way the PS3 first organizes the saves by photo date metadata. Still all good because I don't have the delays of the pop ups etc.
Then I go to edit mode in the playlist where you click on one photo and drag it up or down to drop between two other photos and set up the order of the list that way. I was almost done with that when I got sloppy and dropped a photo not really between 2 others but I guess on top of or partially on top of one of the others.....and it locked up on me. Could not do anything or get out to power down by the remote.
So I go hold down the power button on the unit to force a quit and I get the message that I shut down incorrectly and may have corrupted my drive....it will have to check all the files and repair if it can. "Could take up to 3 hours". That was almost 2 hours ago and the progress meter is at 2%. Where is a banging my head into a wall icon when I need it like on my Lakers forum????
At that pace it will take 80-100 hours if it is consistent and probably no guarantee it will fix it.
OK thanks for listening.....I feel a little better
RonF is online now
post #16 of 16 Old 04-15-2012, 03:23 PM - Thread Starter
RonF's Avatar
Quoted: 257 Post(s)
Liked: 258
Fortunately it fixed itself overnight. It wound up actually being a good thing it happened.
When I first bought the fat 80gb PS3 if you dropped say a 1920x1200 pixel image into the photo section it allowed you to put up and move around a 16x9 overlay to crop to 1080P. Around the time 2 1/2 years in when the original drive stopped saving pictures and reporting the file was corrupted, that cropping stopped functioning too. It was like it was just inactive. Even last night after formatting the new drive and then doing the current firmware update the cropping was still not working.
But it is now which is great. You can even put a 2560x1600 rez photo in and move a smaller 16x9 rectangle around with the left joystick.
Whew!
Apologies to all the gamers who think this is boring as bleep......
RonF is online now
Reply PlayStation Area
