playstation 3d display - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-02-2012, 05:55 PM - Thread Starter
adam45's Avatar
I was think of getting the PlayStation 3d display and I was wondering how people like it. Is the monitor worth getting or should I consider getting a different monitor. I mainly use my current monitor (Samsungt240hd) for my PS3, but I do use my computer on it for 10 to 20 minutes a day. Also how does the monitor's picture quality 3D and 2D compare to other TV's on the market and how good is it when you're using it for a computer. Any help is appreciated
adam45
adam45 is offline
post #2 of 9 Old 08-03-2012, 07:24 AM
jgentry30's Avatar
From what I read when I was thinking of purchasing one of these, there have been some problems with it lasting a few months and then dying. If you look at the reviews on Amazon and Newegg, there were enough problems reported by different people that it may make you think twice about it and going a different route. From what I've seen on display and playing around with it in Best Buy, I thought the 3D was pretty solid on it for gaming, but not worth the hassle of having to deal with faulty equipment...
jgentry30 is offline
post #3 of 9 Old 08-03-2012, 08:26 AM - Thread Starter
adam45's Avatar
when i was reading the reviews there were about the same amount of people that said that they had there's for several months and it worked and others said that within a month it broke, so i was kind of confused on if i should get one. The reason why I was considering getting it is that it is on sale for $200 so I thought it might be worth it. if anybody has one of these how do you like it and how well does it perform.
thanks for the help.
adam45 is offline
post #4 of 9 Old 08-03-2012, 08:56 AM
DaverJ's Avatar
Quoted: 1035 Post(s)
Liked: 3467
Don't forget to search this forum for topics previously discussed, like this one.
DaverJ is online now
post #5 of 9 Old 08-03-2012, 10:21 AM - Thread Starter
adam45's Avatar
i did look at the other PlayStation 3d display posts but i was wondering how people like it and if people have had any problems with it, because looking at some reviews some people had there's die with in a month but i'm not sure if it is a big problem with most of the displays or only with a small portion of them.
adam45 is offline
post #6 of 9 Old 08-04-2012, 07:40 AM - Thread Starter
adam45's Avatar
well thanks for the help I decided to get the display with a four year warenty from best buy.
adam45 is offline
post #7 of 9 Old 08-04-2012, 06:40 PM - Thread Starter
adam45's Avatar
I've had it for a couple of hours and it's great the screen is really good and games look great in 3d so far i really like it.
adam45 is offline
post #8 of 9 Old 08-06-2012, 11:58 AM
jgentry30's Avatar
Glad you're liking it, hope you got one of the 'good' monitors, but at least you've got back up with the warranty...
post #9 of 9 Old 08-06-2012, 12:35 PM - Thread Starter
adam45's Avatar
Thanks, after looking at the reviews I decided it was well worth the extra $30 for the warranty that I got.
adam45 is offline
Reply PlayStation Area
