please help! PS3-Onkyo 606 issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-22-2012, 04:31 PM - Thread Starter
o0dafuq0o's Avatar
Sorry if this has been asked before. I searched both this forum(not very effectively I think) as well as Google and found no solution. All I find is solutions to unrelated issues. I'd also like to apologize if this is the wrong place for this question. but Google brought me here via a different thread about a PS3 and an Onkyo 606
So, here's my problem.
I get no audio through TV during gameplay while the receiver is off. Same goes for a movie that is more than 2channel(5.1 etc). Now this issue hasn't always been. I used to be able to use both surround sound while the receiver was on, or simply power off the receiver and continue playing using the TV's speakers.
I still get sound through the TV while the receiver off for a few things, menu sounds, music, and even video so long as it's 2channel.
I don't know if things changed with an update or what. Not a recent FW update though, as this has been an issue for some time. I did have the receiver unhooked awhile back for, for a common repair. So I'm thinking that perhaps I'm missing a simple solution. Something like my settings being wrong somewhere along the line. Though I have tried set all my settings as they were before.
I have found that if I manually set the PS3 to 2channel only, it will pass the audio while the receiver is off. But I dont want to have to constantly adjust my PS3 audio setting every time, depending on whether I want to use surround or not. I did not have to do that in the past. I was able to select "HDMI Auto" thus enabling everything, and that was that. Receiver on = surround. Receiver off = TV's speakers
Thanks to any who can help
o0dafuq0o is offline
post #2 of 7 Old 09-03-2012, 09:35 AM - Thread Starter
o0dafuq0o's Avatar
anyone
post #3 of 7 Old 09-04-2012, 10:24 AM
greeno's Avatar
Liked: 25
question:
* how do you have things hooked up? what's connected to what?
greeno is offline
post #4 of 7 Old 09-04-2012, 10:37 AM
confidenceman's Avatar
Liked: 37
It sounds to like your TV can't/won't downmix 5.1 to 2 channel. Since you have the AVR set to HDMI passthrough, the AVR does nothing to the signal (like downmix to 2 channel). Sounds to me like all your TV can do is take the front 2 channels of the PS3's multichannel signal (which is why you can hear stuff in the PS3's XMB/menu screen).
If I had to guess, I'd say there's a setting on your display somewhere that got rejiggered when you disconnected and reconnected your AVR to it. Maybe a sound setting on your display for that specific HDMI connection? Or a setting for 5.1 sound rather than 2 channel?
Really not sure without more info. But those would be my guesses.
PSN & XBL ID: drop me a private message
confidenceman is offline
post #5 of 7 Old 09-05-2012, 10:21 PM - Thread Starter
o0dafuq0o's Avatar
Thanks for the reply. I appreciate it
it is a problem only with things that are 5.1 or 7.1
any video on the PS3 HDD that's 2channel works as well
I had looked through the TV's menus but couldn't find anything. maybe I just overlooked it
Tv is a Samsung HLT6187SAX
post #6 of 7 Old 09-06-2012, 07:43 AM
greeno's Avatar
Liked: 25
again, how do you have it hooked up?
greeno is offline
post #7 of 7 Old 09-07-2012, 07:56 PM - Thread Starter
o0dafuq0o's Avatar
sorry
I just have it PS3>HDMI>Onkyo606
PS3 set to HDMI-auto
I can't think of anything(TV, AVR, PS3) being set different than it was before, when it worked
Reply PlayStation Area
