PS3 Netflix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-10-2012, 07:43 AM - Thread Starter
AZAVJunkie's Avatar
Quick and skinny
2 PS3s
both hardwired.
One works perfectly with Netflix.
the other stop every 2-4 minute and I have to restart the movie.
BOTH hardwired.
I don't have great download speeds but ONE WORKS GREAT, the OTHER NOT GREAT.
Thoughts.
AZAVJunkie is offline
post #2 of 5 Old 11-10-2012, 10:47 AM
defdog99's Avatar
Quoted: 81 Post(s)
Liked: 53
Good question.
I know Sony had some PS3s with 7 core CPUs while some had 8.
But I'd guess a bad cable ? Maybe its kinked with intermittent performance.
They sell cable testers on amazon and newegg for cheap. I guess you wait for other to respond to this.
defdog99 is offline
post #3 of 5 Old 11-10-2012, 12:46 PM
blklightning's Avatar
Quoted: 12 Post(s)
Liked: 64
Bad NIC card, bad ethernet cable, bad port perhaps. Hard to say. Switch them and see if it stays the same. If it does, then it's a PS3 problem.
500 gigs FTL.
blklightning is offline
post #4 of 5 Old 11-12-2012, 09:40 AM - Thread Starter
AZAVJunkie's Avatar
Bad HDMI cable.
That'll teach me not to buy the 2 for one at Home depot.
Crappy HDMI cable wasn't syncing correctly...
go figure.
post #5 of 5 Old 11-15-2012, 08:43 AM
TornadoTJ's Avatar
Quoted: 1621 Post(s)
Liked: 510
Yep, you can get a better HDMI cable from Monoprice for probably 1/4 the cost from HD. Get the ones labeled "High Speed".
TornadoTJ is offline
Reply PlayStation Area
