Help with moving Demo to second PS3 - AVS Forum | Home Theater Discussions And Reviews
Old 11-21-2012, 01:56 PM - Thread Starter
Sonyxbr's Avatar
I have the demo for Sonic Generations on one of my PS3s and I would like for it to be on my other PS3. It is no longer available as a demo in the PS Store. It is possible for me to move it? If I signed up for PS+ could I move it to my cloud and then pull it back down on the other PS3 or will that only work for data and not applications?
Sonyxbr is offline
Old 11-21-2012, 02:55 PM
Zookster's Avatar
Quoted: 643 Post(s)
Liked: 470
Did you check to see if Sonic Generations demo still shows up in your download list? You should still be able to download from there if so. (I assume this isn't a 60 minute trial version that Plus subs are entitled to, because once you download it and use it, that's it.)
You definitely can't transfer the demo through the PS Plus cloud storage regardless.
The only other thing is to do a full back up of the PS3 that has the demo, and then restore it to the second PS3, essentially making it a clone of the first and wiping out everything else on it.
Ultimately, it may be easier just to buy the game.
Zookster is offline
