mobile hotspot for internet connection on ps3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-21-2012, 07:05 PM - Thread Starter
Teenza's Avatar
can I use my mobile hotspot to connect to the internet with my ps3 ?
Teenza is offline
post #2 of 5 Old 11-21-2012, 07:41 PM
gregzoll's Avatar
Liked: 33
You could, but it will eat up a lot of data, if you are streaming movies or chatting while playing a game.
gregzoll is offline
post #3 of 5 Old 11-21-2012, 08:01 PM - Thread Starter
Teenza's Avatar
I bought ps3 used and it has somone elses info in it, can i reset to factory resettings ? it is not showing any available connections when I do the scan, except for the one that the other person used, and says that it is not available.
Teenza is offline
post #4 of 5 Old 11-22-2012, 05:38 AM
gregzoll's Avatar
Liked: 33
You can reset it back to factory settings.
Here is the instructions to do a hard/factory reset:
Hard Reset procedure for the PS3 (as instructed by Sony CS).
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
gregzoll is offline
post #5 of 5 Old 11-24-2012, 07:45 PM
sitlet's Avatar
Technically, yes. However that depends on a lot of factors. Are you on 4g? If so, you shouldn't have too many problems. If you are on 3g, you will run into a lot of problems. The main problems being latency (high ping) and unstable speeds. And if you are on Sprint, you can forget about it, you can't do anything with dial-up modem speeds.
sitlet is offline
Reply PlayStation Area
