did my ps3 die? - AVS Forum | Home Theater Discussions And Reviews
Old 11-28-2012, 10:24 PM - Thread Starter
generalpride66's Avatar
I was hoping i could get some help from the avs before i start searching around the internet. So i was playing black ops today when suddenly the ps3 (not slim model an old one) suddenly shut off and the red light was flashing after waiting a minute i hit the button and the light stopped flashing red and went steady red. After that i attempted to turn on again... it turned on for a quick second then went back to flashing red with nothing appearing on screen, any help or advice, thanks fellas!
generalpride66 is offline
Old 11-28-2012, 10:41 PM
confidenceman's Avatar
Liked: 37
Reflow or sell it. A reflow (do a google search) will only delay the inevitable, but it might let you rescue your saves if you haven't backed them up recently.
The old phat PS3's are ticking time bombs. They aren't built to last and started dropping like flies over the last couple years. I'd sell it ASAP (even if it's not working, people will pay decently for the old PS3s). Then I'd buy a newer model. So far so good on these newer ones. *fingers crossed*
PSN & XBL ID: drop me a private message
confidenceman is offline
Old 11-29-2012, 07:02 AM - Thread Starter
if i buy a new one is there anyway i can transfer the data from the old dead to the new one?
Old 11-29-2012, 09:56 AM
TornadoTJ's Avatar
Quoted: 1613 Post(s)
Liked: 510
Not a dead one, no.
TornadoTJ is offline
Old 11-29-2012, 06:21 PM
TyrantII's Avatar
Liked: 833
http://www.avsforum.com/t/1353745/if-you-have-a-phat-sell-it-a-warning-from-refurb-land
TyrantII is offline
Old 11-29-2012, 06:41 PM
blklightning's Avatar
Quoted: 12 Post(s)
Liked: 64
The old PS3s are reliable as you can expect from electronics these days. Mine's 4 and a half years old and still working like a champ. And between games and Netflix, it gets used plenty.
500 gigs FTL.
blklightning is offline
Old 11-29-2012, 06:50 PM
jayoldschool's Avatar
Quoted: 12 Post(s)
Hope you keep it backed up, because it will die. Probably sooner than later.
jayoldschool is offline
Old 11-30-2012, 11:17 AM
Liked: 37
You're one of the lucky few. I'd wager that most of us early adopters here have long since replaced our phat PS3s.
Old 11-30-2012, 11:35 AM
Paulo Teixeira's Avatar
Quoted: 78 Post(s)
Liked: 44
My 80GB PS3 "phat" is still working perfectly fine without issue. Have their been any type of statistics that shows rather people constantly using Folding@Home decreases the longevity of the PS3 compared to people who either hardly or never use it?
Paulo Teixeira is offline
Old 11-30-2012, 01:30 PM
60SXRD's Avatar
My January '07 built 60G is still working just fine. I take it apart and blow out the dust bunnies every year or so. I have PS+ so my saves are backed up just in case.
Cheers,
Jeff
LG 65UHD/Denon/OppO/HTPC/PS4/NHT/HSU/7.1
PSN: Krondorian
XBL: Midkemian
Twitter: @Krondo_jd
60SXRD is offline
Old 11-30-2012, 05:23 PM
TyrantII's Avatar
Liked: 833
Go check out a breakdown vid and take a look at the cooling system of the Phat PS3. Then realize they frequently are putting out 100C+, hotter than most gaming laptops.
With the tin solder problems, it'll fail eventually. If there's a trade in deal that makes a new system cost about as much as a crappy refurb, I HIGHLY suggest you take it.
From a guy thats gone through 2 PS3's and very expensive SXRD Sony television in just the past 5 years. Sony hardware QA from 07-08 crap.
TyrantII is offline
