Backup PS3 HD and restore on new PS3? Best practice? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-12-2012, 06:32 AM - Thread Starter
Webmonkey's Avatar
Quoted: 60 Post(s)
Liked: 32
Hi guys!
I would like to replace my fat 40GB PS3 with a new 500GB super slim - I understand that it should be possible to copy all PS3 HD content such as same games etc to an external USB drive and then restore it on the new PS3 - is this correct?
In case so, I would like to know of any pitfals etc - I do not want to loose my saves etc.
What is the best practive to do this?
Webmonkey is offline
post #2 of 14 Old 12-12-2012, 07:33 AM
TornadoTJ's Avatar
Quoted: 1723 Post(s)
Liked: 539
Use the Data Transfer Utility to copy one system to the other.
http://manuals.playstation.net/document/en/ps3/current/settings/transferutility.html
Webmonkey likes this.
TornadoTJ is offline
post #3 of 14 Old 12-12-2012, 10:50 AM
Radio81's Avatar
Quoted: 215 Post(s)
Liked: 81
What I found easiest (although somewhat time consuming if you have a lot of DLC) was just to sign up for a month of PS+, and then upload all of my saves to cloud storage. I've tried the HD transfer utility...the last time I could not get it to complete the transfer.
Then just sign in on your new playstation, and download your games saves, add-ons, etc.
Radio81 is offline
post #4 of 14 Old 12-12-2012, 10:52 AM
TornadoTJ's Avatar
Liked: 539
I"ve done the data transfer several times with no issues. I have a boatload of games installed on my HD, to think of having to re-download and install those seems a task I would not want to undertake.
post #5 of 14 Old 02-11-2013, 10:25 AM - Thread Starter
Webmonkey's Avatar
Quoted: 60 Post(s)
Liked: 32
First of all, I want to give you a long forgotten Thanks! :-)
Now that the PS4 announcement is imminent, I have decided to forget about buying another PS3. Instead, I am considering buying an SSD disk for my laptop and then putting the 500GB HD from it into the PS3.
Will the "System Restore" tool in the PS3 be able to copy all content to external HD and then I can restored it on the new 500GB drive??
post #6 of 14 Old 02-11-2013, 02:43 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
I second this....having the cloud saves as an intermediary is the absolute safest way to go about this. You could just redownload everything else from PSN as well.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #7 of 14 Old 02-11-2013, 03:30 PM
Mattdoc's Avatar
How does one do that?
I have plus, and some games are already saved there, but not all.
Also, do you delete the saves from your hard drive (and only keep them in the cloud)? or do the saves stay on both (for back-up purposes its on the cloud, but not as a primary save spot)?
I was hoping to free up space on my HD, thought I could start there.
And do you ever delete and re-download games and demos? or can they also be saved in the cloud?
Mattdoc is offline
post #8 of 14 Old 02-11-2013, 05:51 PM
blklightning's Avatar
Quoted: 12 Post(s)
Liked: 64
It's a gigantic waste of time. No game data or PSN games are part of the backup.
500 gigs FTL.
blklightning is offline
post #9 of 14 Old 02-12-2013, 09:33 AM
brakel's Avatar
Liked: 45
The system backup and restore works great. You do have to have a drive that is in plain old FAT32 and it has to be large enough to backup everything. You can't pick and choose items in order to make the backup smaller. I used it when I updated my slim to a 1TB drive. Also have the latest PS3 firmware update on a USB stick for easy updating once you boot up the console with your new drive in it.
PSN brakel
brakel is offline
post #10 of 14 Old 02-12-2013, 09:38 AM
MaxDam77's Avatar
Quoted: 95 Post(s)
Liked: 74
That's exactly what I did. It was very easy that way.
Some games don't let you backup on an external HDD (rockband, Assassins Creed 2,...) but the cloud storage let you do that.
PS+ is the best way to go.
MaxDam77 is offline
post #11 of 14 Old 02-15-2013, 01:37 AM - Thread Starter
Webmonkey's Avatar
Quoted: 60 Post(s)
Liked: 32
Somekind of "copyprotection issue" ? i first thought that everything, especially saved games would be backed up.....
post #12 of 14 Old 02-15-2013, 10:18 AM
brakel's Avatar
Liked: 45
Everything will backup when using the backup and restore utility. I think he was talking about manually backing up game saves to a USB drive. That doesn't work for all games.
PSN brakel
brakel is offline
post #13 of 14 Old 02-15-2013, 11:59 AM
MaxDam77's Avatar
Quoted: 95 Post(s)
Liked: 74
I didn't used a USB, but an external HDD.
My PS3 didn't let me do a full back up because of my rockband and assassins creed 2 save files.
If you have game saves for these games or others of the same kinda copy right protection,...you won't be able to do a back up. It will get interrupted.
PS + cloud will let you do that.
It was so much easier.
MaxDam77 is offline
post #14 of 14 Old 02-15-2013, 04:00 PM
Quoted: 175 Post(s)
Liked: 193
Before starting the backup utility, go to the accounts section and 'deactivate' the system. This turns off all the account access for the machine, but it also frees up copyright data like PSN games, so they can be moved around. Restore your HDD, then reactivate when you're done. I do a reformat once a year or so because it's the only way to defrag a FAT32 HDD, and the most recent was November 2012. Everything on my backup restored just as it was. I have about 100 songs ripped from my CD's, a few Plus games, lots of game data and saves, and even my GT5 save (which is locked afaik), all restored without a hitch. Not sure why 'deactivate system' isn't the first instruction in the guide but it should be. Remember that the backup utility will only restore to the PS3 it was copied from, so if you buy a new machine you'll have to use the data transfer utility.
Crash44 is offline
Reply PlayStation Area
