PlayStation 4 - Page 274 - AVS Forum | Home Theater Discussions And Reviews
 1451Likes
post #8191 of 21079 Old 11-12-2013, 06:57 PM - Thread Starter
joeblow's Avatar
Liked: 233
Yeah, he does say that it is the "current" cap for Vita Remote Play, but it is still bad news right now.
Los Angeles Lakers - 16 NBA Championships!
joeblow is offline
post #8192 of 21079 Old 11-12-2013, 07:02 PM
RemoWilliams84's Avatar
Quoted: 56 Post(s)
Liked: 300
Anyone here using remote play with ps3? What's you're experience been like. I may look at picking one up after crhistmas.
Xbox Gamertag/PSN ID: RemoWilliams84
"I started out with nothing, and I still got most of it." -Seasick Steve
RemoWilliams84 is offline
post #8193 of 21079 Old 11-12-2013, 07:03 PM
TyrantII's Avatar
Liked: 833
Pretty much what I thought. Got to figure 60fps is double the data sent, and probably hard to offer a lag free experience for anything not connected directly.
There's a reason most internet services are still streaming 30fps, and they only need to deliver the packets.
TyrantII is offline
post #8194 of 21079 Old 11-12-2013, 07:07 PM
lordxar5's Avatar
Quoted: 1158 Post(s)
Liked: 929
PSA. Playstation app supposed to hit Android and assuming Apple devices tomorrow.
lordxar5 is offline
post #8195 of 21079 Old 11-12-2013, 07:07 PM
TyrantII's Avatar
Liked: 833
Originally Posted by bd2003 View Post
It's not just polygon, I've heard it said in so many places by people that I trust. (And I don't have any issue with polygon either).
If enough people complain they'll add a lower res option to bring the FPS back up, it's really not a big deal for them to do so. It sounds crazy but I think they really are sacrificing fluidity to hit the magic 1080p number, and I hope they eventually set it straight. It shouldn't need to drop all the way to 720p, but it's just unthinkable that the PS3 version has a better frame rate than the PS4. It's just ridiculous.
The "I can't believe cod isn't running at 1080p on both platforms" line of thinking went out the window as soon as I saw the PC version with my own eyes. It looks legitimately next gen, and with that comes along the performance constraints. People are just going to have to suspend their prejudice against the supposedly "old engine", but there's still no excuse to run crappy at 1080p when they could run perfectly fluid at 900p.
I won't stink up the other guys thread since they're enjoying it on current gen, but here's that XBone vid I talked about.
http://youtu.be/teejnxOa9jg?t=44s
Maybe PS4 is worse, but I think once ArsTechnica and DF do their in depth, we're going to see dropped frames on both. My other thought is SLI is apparently causing studdering, which isn't really frames dropped per say but the engine hiccuping. I'm wondering if that issues is popping up on the PS4 as well.
TyrantII is offline
post #8196 of 21079 Old 11-12-2013, 07:17 PM
samendolaro's Avatar
Liked: 304
This one caught me off guard...
Cravit8 likes this.
samendolaro is offline
post #8197 of 21079 Old 11-12-2013, 07:22 PM
TyrantII's Avatar
Liked: 833
#Greatness!
TyrantII is offline
post #8198 of 21079 Old 11-12-2013, 07:26 PM
William Mapstone's Avatar
Liked: 54
http://www.giantbomb.com/articles/a-few-last-minute-bits-of-playstation-4-info/1100-4785/
According to this guy, Infinity Ward is working on a patch to fix the frame rate issue.
The early reviews of Call of Duty: Ghosts--including mine--mentioned that the PlayStation 4 version of the game suffers from occasional frame rate issues. For me, it usually showed up whenever there were a lot of particle effects on screen, but it'd pop up at random, too. I'm told that Infinity Ward is working on a patch to correct the performance issues. As our review currently doesn't apply to the PS4 version of the game--I want to play that and the Xbox One version on real multiplayer servers before assigning it a number--I'm going to see if that patch makes its way live this week and see if it helps. Currently, I'd call it a toss up between the Xbox One and PS4 versions--the Xbox One version has a smoother frame rate, but I'd rather play the game on a Dual Shock 4. Getting that frame rate pegged would definitively swing things in the PS4's direction, even over the PC version, which is sort of a mess. Of course, we're talking about minor differences in a game that has much more significant issues than mere frame rate, so you probably shouldn't take any of this as a ringing endorsement of the release without reading my review first.
PSN: UndeadREDD
My Racing Seat
William Mapstone is offline
post #8199 of 21079 Old 11-12-2013, 07:37 PM
Cravit8's Avatar
Quoted: 1151 Post(s)
Liked: 610
http://www.avsforum.com/t/1459375/lightbox/post/23940339/id/309436
Originally Posted by samendolaro View Post
This is kind of how it is on the vita.. You can dump all of your downloaded apps to an external drive, then you can swap your hard drive and load them all back in.
So no hurry to change the hard drive right now..
Brilliant!
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #8200 of 21079 Old 11-12-2013, 07:40 PM
Cravit8's Avatar
Liked: 610
It's about time! I had made a European Apple ID about 8 months ago to download the PSN app on iOS. Which is annoying because everytime I sync/backup my iDevices it never finishes without me clicking some buttons to ignore wrong apple ID blah blah.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #8201 of 21079 Old 11-12-2013, 08:34 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Nvidia cards record 1080p/60 at 60mbps, which the vita wifi can't even handle. At 720p you'd be expecting more like 30mbps for good quality, and even that is going to demand a damn near perfect connection. Unfortunately the vita wifi supports only a single stream of wireless N, which is theoretically 65mbps IIRC under perfect conditions....and if there's any one device that never seems to maintain a solid connection to my router, it's the vita.
I'm going to assume this also means the game DVR is also capped at 30fps, prob 720p.
Hate to say it, but it feels like yet another way in which PC leapfrogged the next gen right before they come out...that's been happening a lot lately!
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #8202 of 21079 Old 11-12-2013, 08:56 PM
Liked: 304
http://www.polygon.com/2013/11/12/5096682/injustice-gods-among-us-ps4-netherrealm-ease-of-developing
"At NetherRealm, we loved the PS3. Like, I know some devs really didn't like the SPUs [synergistic processing units, the hardware architecture of the PS3], but we have a tech team that spent eight years really perfecting that thing. So we had near-100 percent SPU utilization for Injustice," said Adam Urbano, senior producer at NetherRealm.
"That said, we were willing to give it up because the PS4 is so easy," Urbano continued. "It's just — the tools are great, the hardware's great, it's super-elegant to work on. So getting code up and running is substantially easier than it's been in past generations."
post #8203 of 21079 Old 11-12-2013, 09:02 PM
Filipinoyakuza's Avatar
Liked: 33
Filipinoyakuza is offline
post #8204 of 21079 Old 11-12-2013, 09:10 PM
PENDRAG0ON's Avatar
Liked: 574
Still waiting for my order to say shipping soon...
PSN - Pendragoongp
NNID - Pendragoon
PENDRAG0ON is offline
post #8205 of 21079 Old 11-12-2013, 09:14 PM
TyrantII's Avatar
Liked: 833
TyrantII is offline
post #8206 of 21079 Old 11-12-2013, 09:20 PM
Liked: 33
post #8207 of 21079 Old 11-12-2013, 09:23 PM
TyrantII's Avatar
Liked: 833
Originally Posted by Filipinoyakuza View Post
Filipinoyakuza and BAMABLUHD like this.
TyrantII is offline
post #8208 of 21079 Old 11-12-2013, 09:26 PM
Cravit8's Avatar
Liked: 610
Screw it, I'm showing this to my wife. It is too great.
Filipinoyakuza likes this.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #8209 of 21079 Old 11-12-2013, 09:44 PM
TyrantII's Avatar
Liked: 833
PlayStation Google App is live
@ GooglePlay: https://t.co/VIs9octAhh
@ iPhone: https://t.co/G1WY2PXwzT
TyrantII is offline
post #8210 of 21079 Old 11-12-2013, 09:55 PM
PENDRAG0ON's Avatar
Liked: 574
PlayStation Google App is live at Google Play: https://t.co/VIs9octAhh
Installed, now to figure out how to sign in...
PSN - Pendragoongp
NNID - Pendragoon
post #8211 of 21079 Old 11-12-2013, 10:07 PM
TyrantII's Avatar
Liked: 833
As a trophywhore, those percentages of players with the trophy make me happy
TyrantII is offline
post #8212 of 21079 Old 11-12-2013, 10:17 PM
Liked: 33
Anyone know what time Apple and Android updated their app store's ? Midnight maybe ?
I'm asking because the Playstation app is coming out tomorrow.
post #8213 of 21079 Old 11-12-2013, 10:20 PM
PENDRAG0ON's Avatar
Liked: 574
Only 3.0% of Dogma players got the Plat, nice to be a member of that club, even if it is an easy one..
0.1% of Star Ocean players got that plat... shocked anyone got it.
PSN - Pendragoongp
NNID - Pendragoon
post #8214 of 21079 Old 11-12-2013, 10:21 PM
PENDRAG0ON's Avatar
Liked: 574
It is already out on Android.
PSN - Pendragoongp
NNID - Pendragoon
post #8215 of 21079 Old 11-12-2013, 10:22 PM
TyrantII's Avatar
Liked: 833
Check out my Platinum for Twisted Metal
TyrantII is offline
post #8216 of 21079 Old 11-12-2013, 10:22 PM
TyrantII's Avatar
Liked: 833
TyrantII is offline
post #8217 of 21079 Old 11-12-2013, 10:33 PM
TyrantII's Avatar
Liked: 833
Crap
Playback of the following types of discs is not supported.
  • CD
  • BD-RE ver.1.0
  • BD-R/RE XL
  • Blu-ray 3D™
Yeah, they're really going to have to beef up the MM capabilities over the long haul. I'm now guessing it doesn't even do photos or MP4/MKV file playback. Boo.
PS3 looks like it'll have a place in the entertainment center for a while along side it's big brother.
TyrantII is offline
post #8218 of 21079 Old 11-12-2013, 10:51 PM
Epyon415's Avatar
Quoted: 649 Post(s)
Liked: 393
Reading the manual and excited about being able to go back to the home screen without quitting current game or app, so overdue. Liking what I am seeing about the streaming apps. Nice it is including chat view direct on screen.
PSN & XBL: Epyon415
Twitch.tv: http://www.twitch.tv/epyon415
Twitter: @roguengames
YouTube Gameplay Videos
I am the greatest MGO player eva!! - http://www.twitch.tv/epyon415/v/24236420
Epyon415 is offline
post #8219 of 21079 Old 11-12-2013, 10:57 PM
Liked: 33
Here is the link for the Playstation App for IOS:
https://itunes.apple.com/us/app/id410896080?mt=8
Cravit8 likes this.
post #8220 of 21079 Old 11-12-2013, 10:59 PM
PENDRAG0ON's Avatar
Liked: 574
My copy of BF4 arrived today. My copy of Ghosts has been at the postal center for days now. (To be delivered tomorrow) and AC4 shipped today.
PSN - Pendragoongp
NNID - Pendragoon
Reply PlayStation Area
Playstation 3 160gb System , Playstation 4 Camera , Playstation 4 Console , Playstation 4 Dualshock 4 Wireless Controller , Playstation 4 Games , Sony
